HMS Blandford (1720) - 20 gun Frigate based on the "1719 Establishment"
Uwek
Administrator
Administrator
Forum Moderator
Vienna, Austria
HMS Blandford, launched 13.th February 1720, a 20-gun frigate, was one of the first ships of all together 22 frigates which were built based on the so called 1719 Establishment
1719 Establishment
The 1719 Establishment was a set of mandatory requirements governing the construction of all Royal Navy warships capable of carrying more than 20 naval long guns. It was designed to bring economies of scale through uniform vessel design, and ensure a degree of certainty about vessel capability once at sea, and was applied to all vessels from the first-rate to the fifth-rate. Once in effect, it superseded the 1706 Establishment, which had specified major dimensions for ships of the second-rate, third-rate and fourth-rate only.
The new Establishment in 1719 was not simply limited to specifying the overall dimensions of each type of warship, but now set out in great detail other factors used in constructing the ship, down to the thickness of timbers ("scantlings") used in construction and planking.
The Establishment adopted in 1719 was subject to substantial revisions in both 1733 and 1741, although on neither occasion was the 1719 Establishment replaced. A new Establishment was finally adopted in 1745.
Before the 1745 centralised all design work in the office of the Surveyor of the Navy, the design of every vessel was the responsibility of the Master Shipwright in the dockyard in which that vessel was built; thus ships built to one Establishment has to conform to the dimensions and other measurements specified by that Establishment, but were to varying designs and therefore did not constitute a "class" in the modern use of the term. The exception to this was when ships were built under contract by commercial shipbuilders, for which a common design was prepared by the Surveyor and copies sent to the shipbuilder for execution; this only applied to some of the two-decker ships and smaller vessels (all three-deckers were built or rebuilt in the Royal Dockyards), and was almost exclusively a wartime occurrence.
Background
When the 1706 Establishment had been introduced, British naval architecture had entered a period of highly conservative stagnation. The Establishments were intended to create standardisation throughout the fleet, in part to reduce the cost of maintaining Britain's large navy. The side effect was to almost completely eliminate any design innovation until the abolition of the Establishments in the early 1750s.
When King George I ascended the throne in 1714, thus beginning the Hanoverian dynasty in Great Britain, the main institutions of the Royal Navy — the Board of Admiralty and the Navy Board — underwent the typical reorganisations associated with a change of régime. While the Admiralty became a much more political body, the Navy Board became populated by men who had learnt their trade during the formative years of the Establishment system. A very significant factor in the formation of the 1719 Establishment and its subsequent longevity is that the period of 1714—1739 was the most peaceful of the 18th Century.
A further contributory factor was the introduction of a new Establishment of Guns in 1716. Previously, gun establishments had catered for each ship, as there were often differences between ships of the same nominal size that would affect the armament they could carry. The 1716 gun establishment was intended to overturn that situation, so that all ships of a particular type (for example, 70 gun ships) would carry the same armament. The Navy Board highlighted the fact that there were still several ships in service that were physically incapable of carrying the prescribed armament, either due to the number and disposition of gunports, or to sturdiness of build. Essentially, however, the Navy Board resolved to undertake the task of having all ships rebuilt to common designs to facilitate the new gun establishment.
One volume of 1719 Establishment dimensions and scantlings, ADM 170/429
1719 arrangements
The new Establishment of dimensions, finalised in December 1719, was significantly more detailed than its predecessor. The 1706 Establishment had sought to constrain only the basic dimensions (gundeck length, keel length, breadth, and depth in the hold), whereas the 1719 Establishment detailed everything from the keel length to the thickness of planks on each deck. The new Establishment was also expanded in scope to include first rates, the dimensions for which were to be based upon HMS Royal Sovereign. In the other direction the new Establishment expanded down to include the sixth rates and the smaller (30-gun) fifth rates, so that all ships with 20 guns or more were covered. The dimensions for other ship types were adjusted according to experience with ships built to the 1706 Establishment.
1733 proposals and revisions
Over time, as British shipbuilding remained stagnant, Britain's foreign maritime rivals, most notably France, continued developing their own ships so that eventually the Navy Board was forced to take note. British ships by comparison with their foreign counterparts were usually significantly smaller — a practice that had come about through a combination of various factors differentiating the role of the Royal Navy from that of the continental navies, but a major factor was the need for a sizeable fleet, and the associated requirement to keep costs as low as practicable. However, by 1729 concerns were being expressed that the ships being built to the 1719 Establishment may be too small, and so a new ship, HMS Centurion, and HMS Rippon which was due for rebuilding, were built with slightly altered dimensions.
In 1732 the Admiralty decided to ask the Master Shipwrights in each of the Royal dockyards to report to them on how best they thought the ships could be improved. The responses, when they finally arrived, were conservative, offering only minor adjustments to certain dimensions. There was little agreement between the changes proposed, and no further progress was made until May 1733 when Sir Jacob Ackworth of the Navy Board — the Surveyor of the Navy at the time — proposed to the Admiralty some changes to the dimensions of the 50-gun and 60-gun ships, most notably an increase in breadth. The Admiralty accepted these proposals, and the ones that followed in later months for the other types, and these new dimensions became the effective new Establishment, though they never technically superseded the 1719 dimensions; there was no 1733 Establishment. Indications are that the Admiralty desired more far-reaching reforms that what was actually implemented, but due in part to the absence of anyone with practical shipbuilding knowledge on the Board, the Board of Admiralty lacked the ability to realise them.
1741 proposals and revisions
The true state of British ship design became apparent with the start of the War of Jenkins' Ear. The capture of the Spanish 70-gun ship Princessa in April 1740 by three British 70-gun ships (HMS Kent, HMS Lennox and HMS Orford) took six hours of fighting despite one of Princessa's topmasts being missing. Her greater size (much closer to that of a British 90-gun ship than a 70) gave her stability that the British ships lacked, and her build quality allowed her to withstand the pounding from the three British ships for a long time. By way of response to the now apparent individual inferiority of British ships over their opponents, a previously abandoned update to the gun establishment was called upon to increase the firepower of the ships. With heavier guns came the need for larger ships to carry them, and so Sir Jacob made a new set of proposals for increased dimensions—slightly less conservative this time around. Additionally, the new gun establishment made some changes to the types of ships that would be on the navy list in future. The 70-gun ships would become 64-gunners, albeit with heavier guns as compensation, and the 60-gun ships were to become 58-gun ships, again with heavier guns. No first rates were built to the dimensions of the 1741 proposals, but one ship of 74 guns and two of 66 were constructed.
An additional side effect of the war was the collapse of the system of rebuilding. Until the outbreak of the war, it had been the practice to rebuild ships periodically, to maintain the size of the fleet without alarming parliament with requests for new ships. In reality, many of these rebuilds amounted to just that, with little or no timber from the original ship surviving into her rebuilt form. In some cases, ships would be dismantled years before they actually underwent the rebuilding process, but remained on the active list for the entire time. Rebuilding a ship was a lengthy process, more time consuming and more expensive than building a completely new one. The pressures of the war meant that for drydocks to be taken up for long periods of time whilst a ship was surveyed to determine what timber was reusable in the new ship, and what could find a use elsewhere in the dockyard, disassembled and then rebuilt was counter-productive. Ships intended to be sent to the West Indies for service in the war required the use of drydocks to have their hulls appropriately sheathed to combat such problems as shipworm, and other uses of the drydocks for servicing the fleet meant that rebuilds were given a low priority. It was at this time that the British practise of converting old ships to hulks for expanded storage space in harbours began, as instead of wasting effort and dockyard space on breaking up an old vessel that was still perfectly capable of floating, they were converted to serve the dockyards in this new capacity. Few rebuilds were started after 1739, and none at all were begun after 1742, although any that had been started were allowed to complete.
Individual ship types
A different set of Establishment dimensions was defined for each size of ship, other than the smallest (i.e. the unrated) vessels.
First rates of 100 guns
Second rates of 90 guns
Third rates of 80 guns
Third rates of 70 (later 64) guns
Fourth rates of 60 (later 58) guns
Fourth rates of 50 guns
Fifth rates of 40 guns
Fifth rates of 30 guns
Scale: 1:48. A Georgian full hull model of a sixth-rate sloop (circa 1730). The model is decked. The initials ‘GR’ appear on the stern. Twenty ships were made in the style of the 1719 Establishment. They were 106 feet long with a beam of 30 feet. They weighed 428 tons burden and had a complement of 140 men. They carried twenty 6-pound guns. Around 1730 two ships (the ‘Sheerness’ and the ‘Dolphin’) were built to a modified design, being 2½ feet longer than their predecessors. This was an intermediate stage in the development of the 1773 Establishment 20-gun ships, which were of a similar size but with a heavier burden.
Sixth rates of 20 guns
General characteristics for 20-gun sixth rates
Type: 20-gun sixth-rate
Tons burthen: 374 49⁄94bm
Length:
  • 106 ft 0 in (32.3 m) (gundeck)
  • 87 ft 9 in (26.7 m) (keel)
Beam: 28 ft 4 in (8.6 m)
Depth of hold: 9 ft 2 in (2.8 m)
Complement: 140 officers and men
Armament:
  • 20 guns:
  • Upper deck: 20 × 6-pounders
The 1719 Establishment for sixth rates took as its model the highly successful Dursley Galley built in 1719. It revised the dimensions of these ships from the 1706 Establishment dimensions to those shown in the adjacent table.
Three sixth rates were new built
the Greyhound and Blandford as replacements in 1720 for lost vessels,
and the Rye as replacement in 1727 for a discarded ship
and seventeen others were rebuilt from existing ships to this Establishment specification
the Lyme and Shoreham in 1720,
Scarborough in 1722,
Lowestoffe in 1723,
Garland, Seaford and Rose in 1724,
Deal Castle, Fox, Gibraltar, Bideford, Seahorse, Squirrel, Aldborough, Flamborough and Experiment in 1727,
and Phoenix in 1728.
Two further 20-gun ships were rebuilt at Deptford to a slightly enlarged specification in 1732
the Sheerness and Dolphin - with the beam increased to 30 ft 5in.
The 1733 revision made no change to the gundeck length of the 20-gun sixth rate, and actually reduced the keel length by 9 inches. It substantially increased the beam by 26 inches from the 1719 dimensions and the depth in hold by 3 inches as follows:
  • Tons burthen: 430 46⁄94 bm
  • Length: 106 ft 0 in (32.3 m) (gundeck)
    87 ft 0 in (26.5 m) (keel)
  • Beam: 30 ft 6 in (9.3 m)
  • Depth in hold: 9 ft 5 in (2.9 m)
Two 20-gun ships were rebuilt at Deptford to the 1733 dimensions - the Tartar in 1734 and the Kennington in 1736. In 1739–1740 another fourteen were ordered to be newbuilt by commercial contractors to a common design - the Fox, Winchelsea, Lyme, Rye, Experiment, Lively, Port Mahon, Scarborough, Success, Rose, Bideford, Bridgewater, Seaford and Solebay. Two further vessels to a slightly enlarged design - the Greyhound and Blandford - were also built by contract in 1741.
The 1741 revision further increased the dimensions to:
  • Tons burthen: 498 36⁄94 bm
  • Length: 112 ft 0 in (34.1 m) (gundeck)
    91 ft 6 in (27.9 m) (keel)
  • Beam: 32 ft 0 in (9.8 m)
  • Depth in hold: 11 ft 0 in (3.4 m)
Fifteen ships were built, all by contract, to a common design and to these specifications - the Lowestoffe, Aldborough, Alderney, Phoenix, Sheerness, Wager, Shoreham, Bridgewater, Glasgow, Triton, Mercury, Surprise, Siren, Fox and Rye. Again, two further vessels - Centaur and Deal Castle - were built to a slightly different design (without lower deck gun ports) while still meeting the same 1741 Establishment criteria, while a single vessel - the Garland - was built in 1745–1748 at Sheerness Dockyard to a somewhat longer design.
Once more an overview of the 20-gun ships based on the 1719 Establishment
1719 Establishment 20-gun sixth rates 1720-1728:
HMS Lyme 1720
HMS Greyhound 1720
HMS Blandford 1720
HMS Shoreham 1720
HMS Scarborough 1722
HMS Garland 1724
HMS Seaford 1724
HMS Lowestoffe 1723
HMS Rose 1724
HMS Deal Castle 1727
HMS Fox 1727
HMS Gibraltar 1727
HMS Bideford 1727
HMS Seahorse 1727
HMS Squirrel 1727
HMS Aldborough 1727
HMS Flamborough 1727
HMS Experiment 1727
HMS Rye 1727
HMS Phoenix 1728
Modified 1719 Establishment 20-gun sixth rates 1729-1732:
HMS Sheerness 1729
HMS Dolphin 1732
Here the overview of all ships with the related measures from the source "Threedecks"
https://en.wikipedia.org/wiki/1719_Establishment
https://en.wikipedia.org/wiki/List_of_frigate_classes_of_the_Royal_Navy
https://threedecks.org/index.php?display_type=show_class&id=219
http://collections.rmg.co.uk/collections/objects/66398.html
HMS Blandford, launched 13.th February 1720, a 20-gun frigate, - Data on Threedecks
The data are available on the web-page of "Threedecks" which is an extreme good reliable source for searching individual ships, persons, actions, yards etc.
The search for our HMS Blandford (1720 - 20) gives the following result:
https://threedecks.org/index.php?display_type=show_ship&id=7498
The principle main historical data (usually with resource) like
Ordered 4.7.1719
Launched 13.2.1719/20
First Commissioned 9.2.1719/20
How acquired: Purpose built
Shipyard: Deptford Dockyard
Ship Class: 1719 Establishment 20-Gunner
Constructor: Richard Stacey
Category: Sixth Rate
Ship Type: Frigate
Sailing Rig: Ship Rigged
Sold: 28.10.1742
and also the technical measures:
Dimensions
Dimension Measurement Type Metric Equivalent
Length of Gundeck:
106' 0"Imperial Feet - 32.3088
Length of Keel: 87' 3"Imperial Feet - 26.5285
Breadth: 28' 5 ½"Imperial Feet - 8.5471
Depth in Hold: 9' 2"Imperial Feet - 2.794
Burthen: 375 18⁄94 Tons BM
Armament
13.2.1719/20 Broadside Weight = 60 Imperial Pound ( 27.21 kg)
Upper Gun Deck:
20 British 6-Pounder
Crew Complement
Date# of Men Notes
1719:
140 Design Complement
in addition we can find timeline and data the commanding officers (with links) and partly Crew members
and relatively complete Service History with date - Event and Source
and at the end a listing of all used Sources
HMS Blandford, launched 13.th February 1720, or sisterships of 1719 Establishment of a 20-gun frigate, - Drawings etc. from the NMM
Date made circa 1730
Credit National Maritime Museum, Greenwich, London, Caird Collection
Materials brass; gilt; mica; paint; fruitwood
Measurements Overall model: 195 x 785 x 210 mm; Base: 102 x 880 x 195 mm
Available in the Archive, but not online is also (excerpts see the first post of this topic!):
42 page specification for the 1719 Establishment, dated 11 November 1719, addressed to Jacob E. Acworth, Surveyor of the Navy and signed by the following Master Shipwrights: Richard Stacey (Depford), Benjamin Rosewell (Chatham), John Naish (Portsmouth), John Haywards (Woolwich), and Assistants to Master Shipwright: William Rosewell (Deptford) and Thomas Fellow (Woolwich). On each page the data relating to the scantlings are divided up in 9 columns, respectively for 100, 90, 80, 70, 60, 50, 40, 30, and 20-gun ships. The different categories are: - dimensions (general) - parts of the frame - in hold - gundeck - middle deck - upper deck - quarter deck - forecastle - round house - without board - topps - trussle trees - crosstrees - iron works for masts, yards and caps - caps - masts and yards - rules of proportion of masts and yards - how to determine the burthen in tunns [initially dated 6 November 1717 but sent 13 November 1719 to Admiralty by Navy Board, re-dated 18 November 1719 and finally 27 November 1719 when sent to the yard - signed by B. Rosewell, Thomas Fellow, William Rosewell, John Naish, Richard Stacey and John Hayward -see above] - dimensions and weight of iron standards - weight of standards amended after the building of Torbay (1719) and Nottingham (1719). Has been photographed: Repro ID: L9113-001 to L9117-004 ADMB 0784
Scale: 1:48. Plan showing the body plan, sheer lines with some inboard detail, and longitudinal half-breadth for Bideford (1727), Squirrel (1727), Flamborough (1727), and Experiment (1727), all 1719 Establishment 20-gun Sixth Rates.
Scale: 1:48. Plan showing the sheer lines with inboard detail, and longitudinal half-breadth with lower deck details for Bideford (1727), a 1719 Establishment 20-gun Sixth Rate.
Scale: 1:48. Plan showing the body plan for Bideford (1727), a 1719 Establishment 20-gun Sixth Rate.
Scale: 1:48. A Georgian full hull model of a 20-gun, sixth-rate sloop (circa 1719). It is a rare example of a model fitted with sweeps for rowing. The model is decked and rigged. Although built on the scale typical of Navy Board models, this is an early example of Georgian models. The model does not relate to a specific ship, but is representative of one of the fifth-rate ships rebuilt as sixth rates in the early 18th century, like the ‘Blandford’ or the ‘Lyme’, which were launched from Deptford in 1720. Vessels of this type were approximately 106 feet long, 28 feet in the beam and weighed about 375 tons burden. They carried a complement of 140 men. They were armed with twenty 6-pound guns.
Date made circa 1719
Credit On loan to the National Maritime Museum, Greenwich, London, from Maidstone Museum and Bentlif Art Gallery.
Materials brass; gilt; mica; paint; varnish; wood
Measurements Overall model: 820 x 1060 x 400 mm; Base: 70 x 840 x 235 mm
Scale: 1:48. Plan showing the amalgamated body plans, and the sheer lines with inboard detail, and longitudinal half-breadth of both the Dolphin (1732) and Otter (1742), both early two-masted Sloops. This plan was then used for Grampus (1746) and Saltash (1746), both 14-gun early two-masted Sloops.
Scale: 1:48. Plan showing the body plan, sheer lines with inboard detail, and longitudinal half-breadth for Grampus (1746), a 14-gun early two-masted Sloop built at Hull. According to ZAZ5037 the body plan is the same as for Dolphin (1732). Signed Jacob Acworth [Surveyor of the Navy, 1715-1749].
http://collections.rmg.co.uk/collections.html#!csearch;searchTerm=1719_Establishment_20_gun
http://collections.rmg.co.uk/collections/objects/66372.html
http://collections.rmg.co.uk/collections.html#!csearch;searchTerm=Dolphin_1732
Book Review to be found at
https://shipsofscale.com/sosforums/...ship-series-by-peter-goodwin.2843/#post-51510
Book Review:
The 20-Gun Ship BLANDFORD
(Anatomy of the Ship series)
by Peter Goodwin
  • Hardcover: 119 pages
  • Publisher: US Naval Institute Press; Anatomy of the Ship series edition (March 1, 1988) or Conway
  • Language: English
  • Product Dimensions: 10 x 0.8 x 10.5 inches
  • Shipping Weight: 1.8 pounds
SYNOPSIS:
This highly acclaimed series aims to provide the finest documentation of individual ships and ship types ever published. It is a radical departure from the usual monograph approach, which concentrates on either the ship´s service history, its technical details or external appearance. All of these aspects are included in the "Anatomy of the Ship", but what makes the series unique is a complete set of superbly executed line drawings, but the conventional type of plan as well as explanatory perspective keys. Although elaborate drawings are extremely popular in aviation publications, this is the first attempt to document a ship in similar depth - literally down to the nuts and bolts.
These drawings are accurate, visually exciting and totally comprehensive, offering ship buffs, historians and modelmakers a novel insight into the technicalities of each ship type covered.
THE AUTHOR Peter GOODWIN:
A Polaris submariner, Peter Goodwin counteracts the boredom of long underwater patrols with research into the technology of an earlier sea-based deterrent. He was been interested in wooden shipbuilding since his days as engineering apprentice, and his depth of knowledge is now widely appreciated by the ship preservation movements like that involved with the Victory. His first book "The Construction and Fitting of the Sailing Man of War, 1650 - 1850" was the fruit of over ten years research into the building process of wooden warships. In the meantime one of the basic books most of the ship modelers have in their shelve.
Contents:
Foreword and Acknowledgements
Introduction
The Development of the 20-gun ship
The Blandford´s History
Construction
Decoration
Layout
Accommodation and Steering
Ground tackle / Pumps
Armament / Shot
Mast and spars / Standing Rigging
Running Rigging
The Sails / Boats
Sources
Bibliography / Appendix
THE PHOTOGRAPHS (page 25 to 33)
THE DRAWINGS (page 34 to 119)
  • Lines and general arrangements
  • Hull Construction
  • Internal Hull
  • External Hull
  • Fittings
  • Armament
  • Mast and spars
  • Rigging
  • Sails
  • Boats
Comment / Review:
The book with the descriptions and especially the detailed draughts is giving a modeler best information to build such a model in scratch.
As most AotS series there are small inconsistencies. Overall a very good addition to the series. Do not forget the book is already 30 years old.
It will be also helping the modeler to better understand the construction of a ships type like this and especially help to build the Cross section model of the HMS Blandford 1720, maybe with some add ons etc.
As often with this series, this book is recommended for the interested modeler
Here is the link to our Blandford Cross Section Project here on SOS:
https://shipsofscale.com/sosforums/forums/blandford-cross-section-project-group-build.105/
