Panart: San Felipe 1:75 Scale Build Log
Moderators: zoly99sask, Aussie048
Post Reply
User avatar
Donnie
Master Chief Petty Officer
Contact:
Re: Panart: San Felipe 1:75 Scale Build Log
Post by Donnie » Mon Dec 26, 2016 6:32 pm
Thanks Eric for clearing that up for me. If anyone would know, you would know !
Got the Bulkheads cut out just running the scroll saw by the "tabs" and all is well. My exacto and my hands don't do so well.
Final before progressing. I noticed at least one of the Bulkheads slips right (almost falls in) in without the use of any force, hammer, or otherwise. (which is great as far as I am concerned).
Donnie
Current Build: Panart San Felipe 1:75
Completed Build: Santisima Trinidad
Main SOS Site: Ships of Scale Website
"War Ships are safe at harbor, but that is not what they were made for"
User avatar
paulv1958
Petty Officer Second Class
Post by paulv1958 » Mon Dec 26, 2016 6:34 pm
Hi Donnie
A box cutter with a little pressure on each tab ( flipping ply) will works well on 4-6mm CNC cut. Save you using the SS and risk damaging the parts and cutting up good ply.
Wait till you try a Jotika Kit thats all CNC.
Already built:
Occre Albatros
AL Endeavour Longboat
AL Spanish Galleon Heritage Kit
Panart : Between Gun decks ( bashed)
Caldercraft Endeavour.
AL King of Mississippi
Corel Victory Cross Section
On shelf
AL Santa Ana ( Next Build)
Caldercraft HMS Victory
User avatar
Donnie
Contact:
Post by Donnie » Tue Dec 27, 2016 10:58 pm
Thanks PaulV. I will remember that.
This pic just shows that I temp installed the Bulkheads - no glue. I have to make a building board for this next.
User avatar
Neophyte
Seaman
Seaman
Post by Neophyte » Fri Dec 30, 2016 9:07 pm
Check out HobbyZone.biz
I have the small version I am using for Le Renard.
The large one will be ordered in the near future.
Very impressive slip for ship building.
Rick
I've reached that age where my brain went from "you probably shouldn't say that" to "what tha hey, let's see what happens". :cool:
User avatar
Donnie
Contact:
Post by Donnie » Fri Dec 30, 2016 10:54 pm
Rick, if the one you are talking about is the HobbyZone PSM01 Professional Ship-Building Slip, which I did look up - it is unfortunate that it is out of stock at this time. I like it and wanted to order it. I already stopped at the Home Depot because they have small pieces of MDF and not have to buy a whole sheet.
I got a piece of 1/2 inch 4 x 4 and will cut it up later. If I have time, I will draw a 3D of it and post it here. It will be very simple.
Donnie
User avatar
Donnie
Contact:
Post by Donnie » Fri Jan 06, 2017 7:40 pm
I got my Building Board made. It is not elaborate. Just a simple base 24" x 10" and then two separate pieces cut with a rabbet on each one. The rabbet forms a channel so that the thickness of base will not interfere with the Bulkheads. I just need a little relief area. The creative part of my brain is not working well, so, it is what it is and will have to work.
It is time to get on with the project now !!!
Donnie
User avatar
Donnie
Contact:
Post by Donnie » Fri Jan 06, 2017 8:43 pm
It didn't take but a few minutes to install the Bulkheads and the two layers of decks. I am really amazed as how all of this fits together and is really a tight fit. The frame is really solid even with no glue. The two layer pieces really make the Bulkheads line up square.
Donnie
User avatar
Undersea4me
Petty Officer Third Class
Post by Undersea4me » Fri Jan 06, 2017 9:11 pm
Looks like it's a tight fitting kit! Sweet!
User avatar
Donnie
Contact:
Post by Donnie » Sat Jan 07, 2017 8:48 pm
Well,
everything you saw was just a dry fitting. I really wanted to glue up all the Bulkheads at one time and while the glue was wet to install the decks 1 and 2 so that the decks would provide a nice platform for being square.
As I was applying glue to one of the Bulkheads, I realized that this is not going to happen as it is difficult to manage the wet glue as it flows - so, I thought that I would wind up having a mess on my hands. Just decided to do things the old fashioned way and use clamps galore and 3" machinist squares to make sure things are square.
I am showing this 'one' as a procedure and won't show the remaining as it is just the same.
Donnie
User avatar
eric61
Chief Petty Officer
Chief Petty Officer
Contact:
Post by eric61 » Sat Jan 07, 2017 11:30 pm
Hi Donnie, don't forget that on the laser cut parts the edge is at an angle.
As an example on the Mayflower the bow keel and beak will be off at an angle of about 30 degrees, so should one use a "fill in" or sand the "proud" side level and then maybe have to reshape a whole lot of other things.
Regards
Eric
Cook's Endeavour - current,
Sovereign of the Seas - current (deAgostini)
In queue: Marina II Fishing Boat by Artesania Latina
In queue: Mayflower by Model Shipways
Post Reply
