Le Requin Xebec ZHL plank on frame kit.
Moderators: zoly99sask, Aussie048
Post Reply
neptune
Petty Officer First Class
Contact:
Re: Le Requin Xebec ZHL plank on frame kit.
Post by neptune » Sun Aug 06, 2017 12:16 am
Thanks for the info Brian.
best regards John.
User avatar
Brian077
Post by Brian077 » Sun Aug 06, 2017 12:24 am
Zoly,
you can use linen thread or polyester. They both have their pluses and minuses. Alexey Domanoff uses polyester as do most of the Russian ship modellers. But it unravels when you cut it so you need to dab the end with super glue. The advantage of polyester is theres no fuzz on the rope and it has a slight sheen and looks like its been waxed.
The linen thread sold has some fuzz on the rope and you need to remove it. Also I have found the colours are limited compared to polyester if you are sourcing it yourself. Otherwise you need to dye it.
User avatar
janos
Petty Officer Second Class
Post by janos » Sun Aug 06, 2017 6:13 am
Another aspect to thread making. Polyesther material is fine and has its advantages / disadvantages - as everything. For my liking it is a bit too stiff. It is also a bit flexible. After my misfortune with my self-built ropewalk (see in another thread) I also bought the Prosak from Domanoff although I did not use it yet as I did not need any rope for SoS at this stage. My intention is to use it with my bobbin, swivel and counterweight.
Brian if you would need longer than 2-3 m ropes the device can obviously be installed in a stairway if you live in a multi-level house. But the shorter length is usually enough for our purposes.
Janos
User avatar
Brian077
Post by Brian077 » Thu Aug 17, 2017 9:46 pm
Been working away on the main mast rigging the last few days and got the large tackle block assembly together.
Heres a few photos of the latest progress up to now.
neptune
Contact:
Post by neptune » Thu Aug 17, 2017 10:18 pm
Just beautiful Brian, that is some tackle block, the details in these kits are amazing, I'm really enjoying mine,
best regards John.
User avatar
Brian077
Post by Brian077 » Thu Aug 17, 2017 10:54 pm
thanks guys.
Basically building it straight from the box apart from my own boxwood planking material and ropes.
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Thu Aug 17, 2017 11:20 pm
Well Brian
I hope I get an invite to check out the build personally again
I have seen Brian's build many times now.
It is a great build of a superb kit.
Excellent work Brian
Aussie048
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
User avatar
janos
Post by janos » Thu Aug 17, 2017 11:51 pm
Looks great, Brian!
Janos
User avatar
Brian077
Post by Brian077 » Thu Aug 24, 2017 10:50 pm
thanks again guys for the kind comments.
User avatar
Peglegreg
Petty Officer Third Class
Post by Peglegreg » Sun Aug 27, 2017 7:56 pm
G'day Brian
Just had the chance to look in at the progress of your impressive build. WOW is a word that comes to my mind at the rigging etc.
Just absolutely brilliant mate.
Where did you get that vertical rope walker? The quality of the ropes are amazing!
havagooday my friend
Greg
The only limitations that are on you, are the ones that you put on yourself!
Post Reply
