Halifax Build Log: Lumberyard
Moderators: Aussie048, zoly99sask
Post Reply
donfarr
Petty Officer First Class
Re: Halifax Build Log: Lumberyard
Post by donfarr » Wed Aug 30, 2017 9:26 am
Thanks John, I may do 1 or 2 planks below the wales, nothing more, just love the look of the open framing. THANKS Don
donfarr
Post by donfarr » Sun Sep 03, 2017 10:52 am
Hello all, Trying to post pictures,...AGAIN I GET FIRST A GREEN LINE THEN IT TURNS YELLOW, NEED HELP AGAIN. THANKS DON
donfarr
Post by donfarr » Mon Sep 04, 2017 12:45 pm
tryingagain
showing aliganment of keel assembly by pusing the frames against deadwood, hope it works
frames sitting on deadwood, Half Frame No 1 will be trimed to bring it in the proper place on deadwood, ALSO VERY IMPORTATNAT SHOWING INSIDES TO MAKE SURE THEY ARE FITTING PROPERLY
showing Half Frames No. W through 2 still need half frames 3 and 4 installed
donfarr
Post by donfarr » Mon Sep 04, 2017 12:52 pm
Hi All, Wish I was not so impatient, SHOULD HAVE WAITED TO SEE Kip Scoviles build on NBM, showing use of inner jig for frame construction, better way then I used, I used this method on my Caustic build and foregot about it. Don.......PS Do not know what I did with the file compression to get the pictures up, was just messing around some how got it to work, will wait until Geoff is feeling better to find out what I did
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Mon Sep 04, 2017 5:48 pm
Hi Don
I am just checking in on your Halifax build log.
I am learning a lot from the log as I have never built a POF ship before.
Cheers
Geoff
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
User avatar
Brian077
Post by Brian077 » Tue Sep 05, 2017 12:51 am
thats great progress Don. Keep up the good work.
ZHL - Xebec Le Requin
Future Build Link:-
H.M.S Enterprise 28 guns
donfarr
Post by donfarr » Tue Sep 05, 2017 10:24 am
Thanks Geoff and Brian, if anyone sees anthing not right please say so only way to learn, next post i will sow some problems and ask for some solutions. THANKS ALL Don
donfarr
Post by donfarr » Wed Sep 06, 2017 9:38 am
again
seems like it is working
Webp.net-compress-image (1).jpg (85.94 KiB) Viewed 92 times
another view
lauckstreet
Petty Officer Third Class
Contact:
Post by lauckstreet » Thu Sep 07, 2017 5:25 am
Hi Don,
Another familiar face, good to see your build of the Halifax. It's coming along, slowly but surely. POF construction does take time, no doubt. I look forward to seeing your model progress, so I'll be following along on this build.
Take care,
Bob Hunt
Bob Hunt
Lauck Street Shipyard
https://www.lauckstreetshipyard.com
donfarr
Post by donfarr » Thu Sep 07, 2017 11:03 am
showing progress on half frames No W trough No. 4
showing Frame No. 4, dry fitted, sitting on deadwood is this correct from plans, pencil line on frame is to be trimmed, IS THIS ALL CORRECT, need advice on this one
Webp.net-compress-image (4).jpg (75.49 KiB) Viewed 75 times
Post Reply
