Halifax Build Log: Lumberyard
Moderators: zoly99sask, Aussie048
Post Reply
User avatar
Mike41
Petty Officer First Class
Re: Halifax Build Log: Lumberyard
Post by Mike41 » Wed Aug 16, 2017 9:36 am
Hi Don,
It is nice to see you have started a build log Your model is looking good and I am looking forward to watching your progress.
Mike
Mike41
donfarr
Post by donfarr » Wed Aug 16, 2017 10:00 am
THANKS MIKE, DAVE NEED HELP WITH CANT FRAMES BEVELS, AND HALF FRAMES.....ALSO HOW TO DETERMINE THE UNDERSIDE OF RAIL FOR THE CANT AND HALF FRAMES. Don
donfarr
donfarr
Post by donfarr » Tue Aug 22, 2017 9:58 am
Hi Everyone, Have not posted in a while, pictures to follow on the progress sometime this week; ...update all whole frames are installed, dry fitting stern Half Frames, and Stem Cant frames,...some mistakes were made will not in this build gloss over them, will show them and solutions that I have come up with to fix them hopefully, and any sugestions for improvement will be greatly appreciated. THANKS Don
donfarr
didit
Petty Officer Third Class
Post by didit » Tue Aug 22, 2017 12:04 pm
you can see the pencil lines where Harold drew in where the wales will go.
the way he did this is to take measurements off the plans and transfer them to the model
for the Halifax you measure up from the jig to whatever you want to locate either the wales or under the caprail.
Take a measurement from the jig to the bottom of the keel to make sure you have the correct distance from the jig to the bottom of the keel.
halifax 2_edited-1.jpg (98.29 KiB) Viewed 47 times
didit
Post by didit » Tue Aug 22, 2017 12:58 pm
JosephH wrote:I was noticing what looks like gaps between the futtock joints is it just the angle or are there gaps and for a reason?
Those gaps you see are from the way the laser is cutting depending on the focus of the beam the cut on the back side is greater than the front side causing the cut to be on a slight angle.
there are 2 things you can do as don said just fill the gap. What I do is ever so slightly touch the end of the piece to the center of my 4 inch disk sander and that squares the ends off and removes the char. If you don't have a disk sander I have also used a square block with sand paper on one surface and just a pass or two squares up the end
when you place the parts together there is a gap on one side
donfarr
Post by donfarr » Tue Aug 22, 2017 1:24 pm
Happy you are back Dave, a couple of questions for you, you SAID THAT FOR WHATEVER LEGAL REASONS THAT THE PLANS WERE DISTORTED, can I still take the mesurments off the plans, when I first put together theKEEL ASSEMBLY IT WAS QUITE A BIT OFF FROM THE PLANS, what do I do,....also I elected to put the KEEL ASSEMBLY IN PLACE WIT FRAMES No. A AND V(first and last whole frame) and CLAMPED THE FRAMES TO THE KEEL NOTCHES,.....then adjusted the frames to the jig, mostly pulled up from the bottom of the jig, this would not matter as the frames eventually get cut off from the jig itself,....but would it not change the mesurments to underside of CAP RAIL AND THE WALE ITSELF,,,,,,pictures forth comming, NEED YOUR HELP ON THIS AND THE CANT FRAME BEVELING,...I JUST CAN NOT SEEM TO GET THAT THROUGH MY ANCIENT MIND, looking forward to your help. Don
donfarr
donfarr
Post by donfarr » Wed Aug 23, 2017 3:13 pm
Hi everyone, showing progress to date, all whole frames complete in place, have quite a bit of fairing to do yet, and stern half frames, and stem cant frames to install
donfarr
donfarr
Post by donfarr » Fri Aug 25, 2017 11:20 am
OK starting to post pictures
Showing a mistake and how I corected it,this is Frame No. 9, showing it wrong, takeing it apart by using nail polish remover with 100 per cent acetone, using cotton swab on the joints and an ezato blade got it apart with no damage re-did the frame corectly, this is wgat happens when you are to tired to do modeling work
donfarr
donfarr
Post by donfarr » Fri Aug 25, 2017 11:50 am
so now I know it is working again, here are the posts showing progress and questions
cant frames No. 5, 6, and 7 dry fitted, is this correct once I get it into rabbit, do I nedd any beveling yet
stern off center, will fix it when installing the half frames by pushing them in
side view wit half frame No. W dry fitted
whole frames attached to keel
whole frames installed to keel and jig
donfarr
donfarr
Post by donfarr » Mon Aug 28, 2017 11:03 am
Where are the pictures for these items how do I get them up. DON
donfarr
Post Reply
