Freidrich Wilhelm Zu Perde 1/48 scale by Euro Model
Moderators: Aussie048, zoly99sask
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Re: Freidrich Wilhelm Zu Perde 1/48 scale by Euro Model
Post by Aussie048 » Tue Aug 08, 2017 3:46 am
John
Another fine build.
yes you are correct with the translation"Friedrich Wilhelm zu Pferde" does mean "Friedrich Wilhelm on horseback.
Cheers
Geoff
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
neptune
Petty Officer First Class
Contact:
Post by neptune » Tue Aug 08, 2017 4:30 am
First job after the cleaning was to locate the positions of what was left of the cast decorations,
so I took photo copies of the areas that had to have decorations attached, I'm only showing
one but I did do several, this is one of the bulkheads.
The painted decorations in place over the drawing.
Now this is what I mean about showing one thing on the plan and giving you another, big difference in size.
and also with the capstan.
Now for the up side of things, these are the cast decorations for the lower beakhead, I think the top casting is from the other side, as it looks kinda flat to the lower casting, if you see what I mean, my mistake.
and sitting over the plan.
Some of the castings for around the quarter galleries were not too good, so I made a casting plaster mould of a good one and cast some more in white metal, which the original ones are made of.
neptune
Contact:
Post by neptune » Tue Aug 08, 2017 4:33 am
G'day Geoff and Janos, I'm sure I put in a post thanking you for your visits, must not have submitted it properly :angry-banghead: , so thank you both for taking the time to respond to my build log,
best regards John.
User avatar
janos
Petty Officer Second Class
Post by janos » Tue Aug 08, 2017 4:41 am
John
these castings are not bad at all (not talking about those which you had to replace) - probably the best cast decorations attached to a kit which I have seen. The next level up what the kits are concerned are the CNC pearwood carvings from the ZHL kits.
Janos
User avatar
janos
Post by janos » Tue Aug 08, 2017 4:43 am
John
yes, I can see what you mean about the differences between the drawings and the reality of the kit. Unfortunately commercial interests win!
Janos
neptune
Contact:
Post by neptune » Tue Aug 08, 2017 4:59 am
First up was to repair the coat of arms badge and the Lanthorn
which were both loosened and damaged by a knock on the transom awhile ago.
I removed the lanthorn for repair and while it was off I repaired the Coat of arms.
To repair and make it stronger I cut a thin piece of brass to the size of the total coat of arms,
I then CA glued the top broken part onto the brass piece and glued the brass piece with the top part back onto the coat of arms
After the repair.
after this part is gilded again you wont even notice the repair.
The lanthorn back in place after replacing two of the stays.
neptune
Contact:
Post by neptune » Tue Aug 08, 2017 5:07 am
Next job was to re varnish the whole ship, view of framing after re varnishing.
view along the decks.
The two forward cannon.
She looks a lot fresher now.
neptune
Contact:
Post by neptune » Tue Aug 08, 2017 5:14 am
I have started planking the main deck, I had some nie australian pine wich was very good grain wise so I used this for the planking.
Closer view.
View along the deck
and another
nearly finished.
Down low.
neptune
Contact:
Post by neptune » Tue Aug 08, 2017 5:25 am
The forward Knights head ready for attaching.These knights heads I cut from some wood and just drilled and shaped with files to obtain the shape of the sheaves.
Turning up the mast coats.
another view.
Mizzen mast coat in place.
The mizzen mast and the coats for the different decks, these are not glued yet so I can slip them down into place as each deck is fixed in place.
Turning up the main and fore coats.
main in place.
Fore in place.
Looking down on the main mast knights head.
User avatar
GaryM
Senoir Chief Petty Officer
Post by GaryM » Tue Aug 08, 2017 3:11 pm
That is some very nice work. This will make it a great model when finished.
Happy modeling,
Gary Maple
Current build: Sergal Sovereign of the Seas
In Que: Sergal: Cutty Sark and Amerigo Vespucci; Billings Titanic
Completed: Amati: HMS Prince (old 1:78 version); Billings: Norske Love and Vasa; Mantua: La Couronne; Sergal: Mississippi Riverboat and La Soleil Royal
Post Reply
