Freidrich Wilhelm Zu Perde 1/48 scale by Euro Model
Moderators: zoly99sask, Aussie048
User avatar
zoly99sask
Chief Petty Officer
Chief Petty Officer
Contact:
Re: Freidrich Wilhelm Zu Perde 1/48 scale by Euro Model
Post by zoly99sask » Tue Aug 08, 2017 6:25 pm
Another great job of yours John,I was following your build log on the other forum on this model ,I am glad you posting it here.
neptune
Petty Officer First Class
Contact:
Post by neptune » Tue Aug 08, 2017 10:21 pm
Thank you Gary and Zoly for your nice comments, I'm going to try and get this one up to date and then carry on with the RC build and this one at the same time,
best regards John.
User avatar
Peglegreg
Petty Officer Third Class
Post by Peglegreg » Fri Aug 11, 2017 2:53 am
G'day John
Beautiful work on this incredible model. I'm very interested in seeing this trough. Are you going to put the full masks on or just the cut-off masks?
I'm planning to do this on the Royal Caroline kit that you are doing. Just waiting on the response from ZHL if I can buy all the fittings and carvings etc from them.
As you may know Greg Ashwood and I have been planning this for a year or so on the other forum.
My version will have the cut-off masks because I will be cutting away some of the channels and chain plates.
havagooday
Greg
The only limitations that are on you, are the ones that you put on yourself!
neptune
Contact:
Post by neptune » Fri Aug 11, 2017 4:15 am
I'm not sure yet Greg, I'm building this one for my daugter, so it depends whether she wants a big case or a medium one, :lol: :lol: :lol:
neptune
Contact:
Post by neptune » Fri Aug 11, 2017 8:47 am
I have to make some gratings for the upper decks and also I needed some for my River tug, so I decided to make these next
I had already made a sled for my Proxxon saw, so I decided to use this to make the gratings.
Photo of the sled sitting on the saw table.
the gratings were going to have a spacing of 1.5mm ( the width of the saw blade ) so I cut a strip of hard wood
1.5mm x 1.5mm and CA glued it to the sled exactly 1.5mm from the blade, you can see it just to the left of the letter X.
close up view.
Then I took a strip of wood that I had cut to approx 25mm wide x approx 4.5mm deep, and I pushed it up against the strip glued to the sled, turned the saw on and passed it over the blade.
then I put the slot that had been cut over the strip of glued wood and repeated the process, then I put the second slot over the glued piece and cut another slot, then just kept repeating it till all the length of wood had been slotted.
Four pieces slotted
Then I took some thicker wood ( 50mmx25mmx75mm ) and laid it long ways on the sled and did the same to them, this is the first cut.
second cut.
half way through.
the finished cuts.
shows four blocks that have been slotted, these will be used as jigs for assembling the gratings.
neptune
Contact:
Post by neptune » Fri Aug 11, 2017 8:59 am
I then changed the 1.5mm blade for a .5mm one for slicing off the grating strips, making sure that the gap was 1.5mm.
Grating strips cut off, the longer ones will used on the River tug.
Cutting the batons to size, again 1.5mm square.
Another view.
The batons and the jigs.
assembling a grating, one baton to go.
after trimming just needs a final sanding.
Grating in place on the plan.
The long lengths being glued together, the other batons will be glued in tomorrow.
Enough gratings to finish the FW
User avatar
Peglegreg
Post by Peglegreg » Fri Aug 11, 2017 10:15 am
G'day John
Excellent work mate. The result is very 'grate'.
Those Proxxon saws are brilliant, I've got one as well.
Havagooday mate
Greg
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Fri Aug 11, 2017 4:42 pm
Hi John
Excellent work as always and I know I have said this many times, I like when modelers show how a more unusual part of the build is show and how it was achieved.
Cheers
Geoff
Aussie048
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
User avatar
janos
Petty Officer Second Class
Post by janos » Fri Aug 11, 2017 8:16 pm
Great work, John!
I also make my on gratings although without a sled so it is a bit different. For SoS I made 1mm size gratings, soon to be fitted.
Janos
neptune
Contact:
Post by neptune » Sun Aug 13, 2017 10:16 pm
janos wrote:Great work, John!
Janos
be interesting to see how you make your gratings Janos, always open to new idea's suggestions,
best regards John.
Post Reply
