Triton Poseidon Cross Section POF Scale 1:48
Moderators: zoly99sask, Aussie048
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Re: Triton Poseidon Cross Section POF Scale 1:48
Post by Aussie048 » Sat Sep 09, 2017 4:03 am
I have been busy cutting out the parts for the frames still.
Currently I am working on frame 8. Most of the frames have had been sanded with a course sandpaper and are just dry fitted. I will dissemble them and sand them with a fine grade paper prior to gluing and pinning, I have not place the false keel in the jig as yet as it will need some work done on it. I will need to stain the frames as the colours of the different timbers varies quite a bit. As yet I have not identied the type of timber used in the frames.
Cheers
Geoff
Aussie048
Current Build Link:-
Mamoli - USS Constitution
HMS Triton Section Poseidon section
On Hold Builds:-
Santa Maria
Norfolk Sloop Delxue
Member
Ship Modelling Society of Victoria
User avatar
Mike41
Petty Officer First Class
Post by Mike41 » Sat Sep 09, 2017 7:33 am
Hi Geoff,
You are off to a good start. Cross sections are an excellent way to start plank on frame modeling.
Mike
Mike41
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Sat Sep 09, 2017 7:42 am
Thank Mike
I think it is the best way to do a POF, something fairly small in a cross section.
Cheers
Geoff
Aussie048
On Hold Builds:-
Santa Maria
Member
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Sat Sep 09, 2017 7:46 am
There has bee a fair amount of sanding involved so far. I have glued a few of the frames and the rest are dry fitted.
The box is full with the 9 frames.
Cheers
Geoff
Aussie048
On Hold Builds:-
Santa Maria
Member
lauckstreet
Petty Officer Third Class
Contact:
Post by lauckstreet » Sat Sep 09, 2017 9:46 am
Hi Geoff,
Interesting kit. Is there a photo of what it will look like when finished? The frame construction looks to be historically correct which I really like but that does make the build a little more difficult. Good job on the frames construction so far. I look forward to seeing the kit evolve into a finished model.
Take care,
Bob
Bob Hunt
Lauck Street Shipyard
https://www.lauckstreetshipyard.com
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Sat Sep 09, 2017 4:43 pm
Bob
Thanks for visiting my build log. I have posted some photos of what Triton should look like at the start of the build log.
I have been admiring your work on SOS an look forward to seeing many more of your builds of exceptional quality.
Cheers
Geoff
Aussie048
On Hold Builds:-
Santa Maria
Member
lauckstreet
Contact:
Post by lauckstreet » Sat Sep 09, 2017 4:49 pm
Bob
Cheers
Geoff
My bad Geoff. Don't know how I missed those photos. Senior moment perhaps.
I'll post some photos of my Fubbs model soon. I have to reduce the size as most are much too large to upload to the forum
Bob
Bob Hunt
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Sat Sep 09, 2017 4:52 pm
Hi Bob
No, you did not miss them I only included them this morning.
It looks like it will make a stunning model. Just hope I can produce to a standard near of what is in the photos.
Cheers
Geoff
Aussie048
On Hold Builds:-
Santa Maria
Member
User avatar
Mike41
Post by Mike41 » Sun Sep 10, 2017 7:27 am
Hi Geoff,
I like the way the frames are assembled. Could you post a photo of the end view of the frames in the box?
Thanks, Mike
Mike41
User avatar
Aussie048
Chief Petty Officer
Chief Petty Officer
Post by Aussie048 » Sun Sep 10, 2017 7:43 am
Hi Mike
I am only using the box as storage for the frames at the moment to keep them in order.
The fitted the keel in the box yet. The box is that tight a fit I have not glued it at all except for a bottom sheet
Cheers
Geoff
Aussie048
On Hold Builds:-
Santa Maria
Member
Post Reply
