|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
Thanks Khonrath. I did use both the Microset, and Microsol on the decals. They decals are pretty old but seemed to go on OK. Unfortunately I really prefer flat paint and bought a ton of it but later learned I really can't use it for the hull. I also learned the hard way I can't use Tamiya Panel Line Accent on flat paint. Actually, that stuff ate through my gloss paint too so I won't be using it again unless someone can tell me what is impervious to that stuff.Your decal work is good, and as you have learned a gloss surface is a must to get them to adhere correctly.
Micro-Scale makes two solutions to help get decals to settle snugly against details under the actual decal like rivets or seams. The are called Micro Set and Micro Sol, google them online.
Best of luck getting decking kit, if not available, try photo of deck and printing to proper scale to use as template to cut new decks from.
Thanks Kkonrath!Looking good, keep up the work!
