Hello Markus, This is real photo from USS Constitution. Take a look herethe last picture looks quite "creative"![]()
* taken from Quora.comHow would they get the hook of the cathead tackle into the anchor loop? Someone in a small boat?
I would tend to agree at that scale. I just used a big restraining rope for the cannons on my Connie.Hi Vic @Vfordyce ....after much thought, as I explained in my Black Pearl build log, I decided to not put any blocks on my tackle ropes...I didn't have blocks that were small enough...the ones that I did have were disproportionately too large...I felt that to most observers, they will more likely notice the too large blocks than the absence of them.View attachment 185294
Hope this helps.
As I know the carriage side tackle was for outhaul only, not breach hawser restraint which passed through the carriage sides an was eyespliced to iron eyebolts in the bulkhead. The inhaul tackle to bring it back in for the reloading process was much more simple depending upon the weight of the gun which for a 32 pounder was around 5,500 lbs and took a significantly sized/manned gun crew setting the distance between gun stations for working room.I would tend to agree at that scale. I just used a big restraining rope for the cannons on my Connie.
I simplified the full set of commands that Jean Boudriot includes in one of his four volume set, under "Gunnery - The Crew at Work". pp 123 - 32. My addition here is that he identified gun crews on his 84 gun ship as: 36-pounder - 14 men, 18-pounder - 9 men, 8-pounder - 5 men, all not including the powder monkey and those boys carrying up additional shot. Lots of moving around! PT-2As I know the carriage side tackle was for outhaul only, not breach hawser restraint which passed through the carriage sides an was eyespliced to iron eyebolts in the bulkhead. The inhaul tackle to bring it back in for the reloading process was much more simple depending upon the weight of the gun which for a 32 pounder was around 5,500 lbs and took a significantly sized/manned gun crew setting the distance between gun stations for working room.
The traditional gun commands were:
Draw back, Out Tampions, Load powder. Load wads. Load shot. Load wads. Ram home. Out guns. Aim guns. Prick cartridge. Clear away. Fire!
After firing with the gen carriage inboard from recoil:
Stop vents. Worm. Swab. Load powder, Load wads. Load shot. Load wads. Ram home. Out guns. Aim guns (windage and elevation changes). Prick cartridge. Clear away. Fire!
The number of gun crewmen varied with caliber but the assigned duties were carried out individually or some by the same crewman all under the Gun Captain. Noise and smoke added to the need for attention and clear working space at each station.
In the builds it seems that there is insufficient space given for the gun-crew and their actions with the tackle and falls associated in the operation. Just some thoughts. PT-2
