HMS Victory Mantua 1:78 (first build) by Grant Tyler [COMPLETED BUILD]
Hello Grant, Completely agree with Doc (a.k.a Poul), the rigging looks great but...if I may make a small suggestion to cut 'flush' with the carriage the trunion. It will make the cannon erotic...:cool:
See red circle
True Story- I see that in the photo now.The cannons and the trunnions are not glued in yet still want align etc. The trunnions came pre cut with the kit and this one did slide A little foreward. I centered it looks better (see photo below) not flush tho. All are like this. I will try remove one and not break the rigging - Filing them down probably the best option? Thanks for the tip Jimsky.....I thinkRedfaceROTF9BDCC55E-6599-4C61-B736-6FA02B0C87E0.jpeg
Thanks Paul. Appreciate your comment.They are better. My carving is sad tho- 2 more to go. Jimsky has given me a challenge on my cannon Trunnions tho:eek:
Don't take it as a challenge, Grant. Sometimes those small errors are just simply overlooked while working on other things. ;)
Thanks. Love your advice on mine and others logs it is invaluable. The challenge for me is not to break the rigging connections to bulwark when reinserting the trunnions. It is the detail and knowledge which you have That is so appreciated. I tend to miss the detail. I read someone comment “that a good model is all in the detail”ThanksThumbsup
Good morning. Consolidation time. Going back and adding small details. Going to finish everything I have done to date 100%. Going to loose track here as I did not make a list as @dockattner did.
Firstly re did my cannon trunnions as per @Jimsky advice. Then added forward cabin window doors and the decoration to the cathead. Plenty more to do:rolleyes:
Just great work Grant! You have done a beautifully clean and neat job of decorating the cathead and your trunnions look A1! Tight, young man, tight!
Love it! Falling asleep with the sound of the ocean in your ears ... aaah man...
Thanks guys. As you know the colour of the Victory was and at times still is hotly debated. I went for the more softer salmon pink with a touch of ochre in. It does look better but is very light "sensitive" and at times can appear a little too pink or a little too fleshy depending on how the light catches it. However I do enjoy the overall look and appearance of what I managed to achieve.
Good evening. Crows nest time. Planked and framed - used the 3mm x 0.5mm deck planking wood. I used wood glue and super glue “nails” for the framing and the 0.5mm planking bent around easily. As I am going to stain the decking I was careful not to get glue on the planks.
On having a look at various builds -yet another Victory by Bernd (Deagostini) and Jotika (caldercraft) website (has some good instructions and some drawings) it is clear that the frame needs to be higher than the base of the crows nest. Removed framing and redid.View attachment 272986View attachment 272987View attachment 272989
Stained planking with Indian Ink as it shows the wood planking better than painting. Added the individual “strakes” (Sorry guys cannot find what these are called) as per Mantua instructions. A little cleaning up and then dead eye installation.
I am debating wether to leave the wood effect(not authentic) or to stain these black as well.
View attachment 272990View attachment 272991View attachment 272992
Great work on the crow's nest Grant, and well done on the re-work to raise the border edges. It's one of those things that probably would have kept you up at night if you hadn't made the extra effort ;)
Good Morning. Not too much work on Her Majesty’s ship lately as I have been getting my Husqvarna ready for Kalahari rally. Bike ready not so sure about myself.
Quick update on my build.
1. Skylight.
@dockattner siren was forced to come out. Kit directions just looked horrid and far from anything close to authentic.
What the directions suggested
I have also run out of 1x2 walnut (kit limited with wood) so the skylight made from left overs in my off cuts. I ensured I kept the last remnant of the wood so that I could line off the skylight. I did manage to finish it off. Stained the wood darker to match my ladders and achieve a little more authenticity. One coat of light Matt poly will be applied to finish it off.
2. The gallery hand railings. Nice toes GrantROTFROTFROTF
I fitted the stanchions I made and rather than using a brass wire I used a 0.5mm thread. It looks more authentic and Fits my model better. Used PVa glue on the blackened part to stiffen it. On the real ship this is curved wood and I could not make this- did give it a go tho :confused:.
First CA glue blunder circled in redCautious.
3. Painted and fitted the Flag pole, the Transom knees and the flag lockers. Went for the look in the photo below and brush painted the white to try get a canvas look.
A few small consolidation item shown in this picture - shutter on stern window, decorations on hull finished and the closed upper gun port lids. I will have to redo these closed gun ports. The hinges on the kit do not fit snugly for closed lids. Will have to rethink this.
Anyway a quick update. Cheers all and enjoy your weekend. Couldn’t resist- she is readyROTFROTFThumbsupThumbsup
Hi everyone- reading my post I sometimes seem to criticize this kit. It is Not intended and it has made building my ship way more fun and rewarding calling my siren(even tho my skill at scratch building is at a beginner level) to have to make and research these changes. A huge thanks to everyone on this site whose models and sharing of how they do things has helped me massively. Cheers:DThumbsup
