Thank you so much for sharing your special and fascinating project. I will continue to follow your work with great anticipation and curiosityToday I was going to attach a thin piece of veneer to the edging of the dragon head and keel that runs up to it. Seems like I take two steps forward and one back. I didn't like the way the keel looked where it butts up against the scroll work. The piece the kit tells you to glue there is too thin to match up to the scroll work. So I am removing those 4 small pieces and will find some wood that matches up to the thickness better. Slow work as I don't want to damage the inner surfaces of the keel.
Thanks for the comments. I am probably a lot slower than most ship builders but enjoying figuring out how to handle problems that arise during the build.Thank you so much for sharing your special and fascinating project. I will continue to follow your work with great anticipation and curiosity![]()
