Because the kit maker was trying to form a shape with double curvature with a wide, flat strip of wood, the resulting puckers will result. The wood can't stretch easily in two directions, unless you steam it over a form, and it just isn't worth the hassle. In fact, because plywood contains wood sheet running in two directions, it is designed NOT to stretch, or bend easily on one axis. Don't fight it.
Instead, cut the gun port piece all along the bottom of the gun ports and use only the top half, because this section will only have to curve in one direction, over a vertical axis. Save the lower half to use as a pattern later (you'll see why). The lower section of the of port piece can be replaced with wood strips just like the rest of the hull. The top strip forms the bottom edges of the gun ports. The lower half of the plywood you saved shows you exactly what area you need to cover with the strips, because it is your pattern.
The advantage is that the flatter sections of the hull use plywood for speed in construction, but the strips below the ports will form the proper curves of the hull with a lot less trouble. And, the new strips you insert will blend in perfectly with hull strips below them. Fighting a piece of plywood over a double curve is a waste of time in my opinion, and in this case, you really don't have to. Basswood strips for doing first planking hull forming are cheap and easy to find if you need more wood.
Sometimes when a kit maker tries to simplify construction, thinking they will save the builder time planking, they create more problems. Such is the case here.
- "The longest distance between any two points is called a shortcut."
Hello, sorry, have you checked the frames if they are in sequence?Hi everyone and thanks for your help. I cut the templates down and re fitted them. I’m still not happy with the results so I’m going over plank them with 1mm lime wood. Sand them then cut the gunports
Hallo @RobsterI’ve just started Amati Russian brig Marcury. I have fitted one of the gun port patterns and I seem to have “bulges” between the frames. Any help solving this would be appreciated.
