Try to do it the other way round: colour it all with gold and then add a black wash to enhance the relief.My problem is that the raised portions are so slight that I don’t believe I could just get the dry brush on them only.
Hi Paul. Nope the photo almost enhances them a little. It is 100% to scale so they are minute. Sometimes 3D printing can cause as much consternation as pleasure. What ever happens they will be an improvement to the box from the kit I used- this is going to be fun. I have an idea though so will try something I have not yet seen in this hobby- hmmmSeeing this view of the entryway makes me wonder how successful you are going to be - the details are murky and may not take well to ANY approach. Maybe the photo flattened the details?
- I’m sure guys have done it before it can’t be that clever. I will post my attempts good or bad. Cheers GrantThanks Frank. Yep this it what I have to attempt- never going to happen with my painting though
Good afternoon Vladimir. I agree, this is also what Paul suggests. I think either way painting will just be a mess- it’s way too small at my scale. I am going to try something I dreamt up so let’s see…..Cheers GrantTry to do it the other way round: colour it all with gold and then add a black wash to enhance the relief.
Good afternoon Greg. Thank you. It was an incredibly fun journey and it is getting close to the end. It is “Grants Victory” as it has so many inaccuracies and blunders however I did modify the kit on almost every aspect to look a little like the real ship. An awesome model to build. Cheers GrantTook me a while to work my way through your build log but was well worth it. You have done a magnificent job of it. Hard to believe it's your first ship , it just looks perfect.
By comparison my first is looking terrible. I have a long way to go.
I’m going to have to agree with this approach. Paint it gold, then thin your black paint ( 1 part paint and 3 parts water, for water based paint), then brush on and let it run into the crevices. It will take many coats of the black wash, but eventually you will get the look you are after. It’s not hard at all. Just don’t put on the gold too thick, or you will lose the detail.Try to do it the other way round: colour it all with gold and then add a black wash to enhance the relief.
. I thought I got the adhesive on the raised patterns. We know what thought did…..
. Even worse is the gold leaf did not come off when soaked in hot water and the heat warped the 3D plastic…
Hey Grant, you might try dry brushing, there is a bit of a learning curve to it but in your particular situation it may be perfect. Reasearch it because it's a little too long to describe it in a nutshell. Only the higher relief parts will take on the dry brush paint.Good morning. I know painting is out of the question for my skills. The raised parts are so slight and even magnified I cannot establish the pattern let alone get black into the gaps if I painted the gold first.
So I attempted gold leaf-. I thought I got the adhesive on the raised patterns. We know what thought did…..
View attachment 373829View attachment 373830
I know it looks better than my painting would come out, however hot water, remove this attempt and try again. Man this gold leaf is fiddly stuff.
Cheers Grant
Hello Grant, I may be talking out-of-turn here, but Regarding the paint detail concern - have you given any thought to possibly using a water-based Artists Masking Fluid? It has a color to it so you can see the raised portion where it is rubbed off allowing the gold paint to adhere to only those points. Just a thought
BTW, Beautiful work. Terry
Good morning Dean, Daniel and Koch. Thanks for your input. I do appreciate help and advice especially on those areas where I am pretty clueless. I will get some practice surfaces and try these different techniques and hopefully I will get it reasonable in order finish my VictoryGrant, you shouldn't be afraid to paint. The wash technique is very forgiving. The paint is thinned out to the point it runs into the crevices like water, therefore you don't have to paint good, just brush across the entire surface and the paint runs into the low areas...and off the high areas! Be sure to do one surface at a time and keep that surface facing up, so the paint doesn't run out of the low areas before it dries. But because it is thinned out enough to flow like water, it will just highlight the low areas, until you do it a couple of times... and it gets darker each time. I hope that makes sense. You are not trying to painstakingly paint the low areas, the paint runs into them and does the work for you!![]()
Good morning Jack. Thank you. I also think it doesn’t look bad….I just wanted better. I have to get the port side entrance (they short supplied my order) ,so will get another starboard one and give it another go. Maybe some more practice may render a little bit better result. Cheers GrantMaybe my eyes are deceiving me Grant ,but at the scale you are working at your entrance looks pretty good to me as it is.
Cheers JJ..
What a beautiful display - especially with the seascape picture in the background! Would have loved to be the "Third wheel" with the two of you!Dear Friends. As you know Grant and I met up last night in Melkbosstrand, South Africa. Obviously, the HMS Victory was a major talking point and let me tell you - seeing her in the flesh is a totally different ballgame than seeing it on pictures. There is simply nothing that prepares you for the size and magnificence of this ship - especially when rigged to the extent that Grant has gone to. I am no photographer (as you all well know) but thought I would share with you my favorite views of the ship.
View attachment 385952View attachment 385960View attachment 385961View attachment 385962
The last picture is, of course, Grant's infamous underwear pic so famously displayed. Ashtyn (Grant's daughter) had never noticed that before and upon me pointing it out, immediately declared that as "the coolest part of the build."![]()
What a coincidence, Heinrich. I just asked Grant if you met each other!Dear Friends. As you know Grant and I met up last night in Melkbosstrand, South Africa. Obviously, the HMS Victory was a major talking point and let me tell you - seeing her in the flesh is a totally different ballgame than seeing it on pictures. There is simply nothing that prepares you for the size and magnificence of this ship - especially when rigged to the extent that Grant has gone to. I am no photographer (as you all well know) but thought I would share with you my favorite views of the ship.
