Thanks, Greg, very nice of you!
Currently struggling with the cannon barrels. I wanted to turn individual brass barrels, tried a number of different things and all failed - apparently the setting of my lathe is not correct. So I gave up this and started turning brass masters for every barrel size (will be 4 or 5 different ones) and as it stands I will cast them from white metal and then paint.
Janos
what is the square tubing made of.Great build. ThanksSome update about this slow build. The decks have now been re-planked. Gunport-frames made of square tubes, glued into position and thinned to the thickness of the primary planking. I also marked the frame positions (every second) on the hull to be able to create the right plank-pattern. Then I started outside planking. The material above the uppermost wale will be Swiss Pear and Pear Wood below it. The planking will consist of planks, the length of which is to scale (wales are in full length though). I am going to continue with the Swiss Pear planking up to the point that I can start carving and from there on these two things will happen concurrently. The bow section will be covered by 'strips' as opposed to the kit's deck planking. Some parts are already manufactured for this (as are gratings) and I will do the bow as soon as I reach its top with the planking.
Janos
