Thanks Uwek i will try my best))Very interesting start of your model. Never thought to use parquet for the bulkheads, but very good idea.
I am looking forward to see your next post.
I am sure it will be a very good log, especially after the good experience with your log of the cannon Jolle.
Very good start
Thanks so much that you like my topic, that's NO PROBLEM if you will use only ENGLISH, i'm seaman with 17 years experience and i have almost fluent knowledge with english language))) also will follow you topic with Royal Caroline 1749, and wish you all the best with construction))G'day Sergey from the Land Downunder-Australia
Good to see another Royal Caroline build. And a scratched build, you are a very brave man to do this bold from scratch with all it's beautiful carvings.
I will be watching front and centre on this build, I'm very, very interested in this yacht because I'm building a 1:30 scale of the Royal Caroline myself, but from a ZHL kit.
You can click on my build information under my signature line to get to my log.
There are also two other RC being build by Neptune and Maarten on SOS. Have a look at all of them. Neptune, his name is John and Maarten are way ahead of me, as I'm just starting.
It would be good if you can write down the way you approach your build and your thoughts etc. Don't worry if you can't read or write in English, just write in your Ukrainian language and use Google Translates to translate it into English. That is how I wrote this entry to you.
Looking forward to see more of your logs.
Happy modeling
Greg
Тисячоліття Сергій з землі Баундер-Австралія
Добре бачити ще одну будівлю Королівської Кароліни. І скретченими збірками, ти дуже мужній людина, щоб зробити це сміливо з нуля з усіма красивими різьбленнями.
Я буду спостерігати вперед і зосередитися на цій будівлі, я дуже, дуже зацікавлена в цій яхті, тому що я будую масштаб 1:30 Royal Caroline сам, але з комплекту ZHL.
Ви можете натиснути на мою інформацію про будівництво під моєю лінією підписів, щоб перейти до мого журналу.
Є також ще два RC, що будуються Нептуном і Маартеном на SOS. Подивіться на них усіх. Нептун, його ім'я Джон і Маартен перевертають мене, як я тільки починаю.
Було б добре, якщо ви зможете написати спосіб, до якого ви підходите до вашої збірки, своїми думками тощо. Не хвилюйтеся, якщо ви не можете читати чи писати англійською, просто напишіть українською мовою та використовуйте Google Translates для перекладу на англійську мову. . Ось так я написав цей запис для вас.
З нетерпінням чекаємо більше ваших журналів.
Щасливе моделювання
Грег
Hi Maarten the carvings actually will be made from wax and die cast from silver or brass, previously i was dental technician and yes i will take on board all tools for modeling ))Hi Sergey,
Looking forward to your build. Especially the carvings of the ship will be a hudge task.
Do you take parts with you onboard when you are at sea?
I have been sailing myself in the past and sometimes build very small models from materials available onboard.
