I am in agreement with Peter, this is not an easy part to make, and the result is well made.
A major re-do at the stern with a nice result, Jan.Update 24
The stern is now planked to the top and updated a bit. It now sits to my liking.
This is seen from the side,
and this from above.
That weird S-bend is out. And the first deck has also been laid. Here you can also clearly see the tiller controls. It looks like the tiller is sticking up above the place for the mizzen mast but the tiller can still slide back a bit.
This is the beginning of the deck above the galley and "dining room."
I want to leave the door to that open to give visibility. But that also means that the turret on the deck should be open from below and there should be a set of stairs below it. So this one.
And the steps in the "dining room" are a little unfortunate in relation to the table and bench with an eater.
After planking the deck closed, let's check how it will look.
The burning galley is easy to see.
Now I made a start on the middle foredeck.
But first I made the frame for the large hatch. The planking closes against that. Because I made a mast track for the fore mast on the plywood, very hard to see, and the deck above it already has a grommet, the location of the fore mast is already determined. And I have to fit the intermediate deck around the mast. I cannot plank this tightly and then put in a hole for the mast somewhere at random. Hence the mast is already loose in there.
To be continued.
My WB2 is in oak so I am pretty familiar with its characteristics. I agree with you on the historical accuracy part, and I did not find the bending to be a problem either; my main gripes are the tendency to splinter (cutting the walnut results in very precise and clean edges) and the coarse grain. On the plus side, the oak sands into a beautiful, smooth finish, but overall, I just like the darker look of the walnut.Thank you Heinrich. Oak is a hard type of wood. But when wet you can form it, with heat, rather easily in almost any curve you want. But when dry in a not correct bend you cannot bend it with force in the correct way. It is then hard again. Then you have to wet it again and correct with heat. That makes it work and time consuming. But oak is the historical correct type of wood.
Hallo @DeedsVery interesting to see how you're progressing!
I'm from South Africa and did some research into the origin of my family - Marais. Charles Marais sailed on a dutch Fluytschip (Voorschoten) from Delftshaven, Holland on 31 December 1687 and arrived at Table Bay on 28 April 1688. Therefor this ship has some sentimental meaning to me. I was excited to see that there are sets being sold for building a fluytschip, however as I have no experience in model ship building, it looks like it would be an impossible task - at least for now. I'll start small and maybe one day be able to build this
Until then, I'll enjoy following your progress here.
Best of luck with the build!
Update 27
First, I tackled theforedeck. By cutting the deck beams to size. I thickened the forwarddeck beam because the bowsprit actually goes right through it.
Theknight and nail bench are also ready to be installed.
I chose toplace the deck around them.
Unfortunately, I didn't take photos inbetween, only of the final result.
The bowsprit isalready in place and attached between the cleats on the deckbelow.
The next step is the pacing the wales. The first walewent fairly smoothly and is on acceptably. Except for a crack but youcan fill that.
I used a couple of nails to get the first wale onsmoothly. Then I thought it would be nice to nail down the entirehull. As has been done by others. So that resulted in thefollowing:
This disappointed me, they look too coarseand conspicuous. So I decided to replace the nails with sate-prickdots. And that's what you get:
This will look familiarto a number of people.
Then the second wale. Fixing the ends witha nail is handy. But oak is much harder than lime so you have to tapharder. And that does not always go well.
Take a look:
I had pre-drilled the wale butnot the plank underneath. It suddenly buckled inward. When pushing itback from the inside, it broke off completely, leaving a hole. I washoping to plug that with the wale and some malleable wood but thatwon't work. That it really is a hole you can also see when the lightsare on:
To make matters worse, I tapped the figurinethat was just behind this at the heads too. So I'll have to fiddlethat back in. But first, fix the hull under the wale after taking thewale off. Fortunately I had not yet mounted the framing of the cabinwindows.
To be continued.
After Pandora ...But in retrospect, I think the difficulty of this kit should then have been rated 7 stars.
... and grained wood, out of scale (my observation)That break of the wood is exactly why I don't like oak - the brittleness and splintering.
