Model Shipways Kate Cory Whaling Brig (Completed)
Bought this kit along with a set of plans from New Bedford Whaling Museum many years ago and finally decided to build it. I saw the kit listed in the first Model Shipways catalog I received in 1986 when I was considering the hobby. I decided on a starting with their KATY, 1/4" scale Virginia Pilot Boat. Since then, I have built several other kits along with my other hobby interests. However, completing the Kate Cory has always been one of my primary goals. I needed motivation.
Unlike the Charles W. Morgan, there is not a great deal of historical documentation available regarding this specific ship. The New Bedford Whaling Museum, New Bedford, Ma. (USA) is the only resource I could find that offered credible documentation. This is where I obtained plans by Erik Ronnberg, Jr. which provide significantly more details and views then the kit plans. Additionally, I obtained copies of the Nautical Research Journals referenced in the Model Shipways Catalog regarding Coppering techniques, i.e., "Copper Sheathing of Whaleships", etc. I coppered two other kits using this technique and feel it provides a more realistic appearance. However, one could argue using this process without some weathering of the rest of the model is inconsistent.
Despite all the research and obtaining all the documentation I could find, I still felt I needed a good visual representation of the ship. Finally, a key motivating factor for me to starting the project was the 1/4" scratch-built model by Thomas J. Lauria, (https://tjlauria.com/gallery/whaling-schooner-kate-cory/). Tom has many other excellent builds and has been helpful answering my questions.
So, it begins! After shaping the hull, thinning the bulwarks. Next step will be to plank the Hull.
Finished the hull planking with some detail. A couple of details I had an issue with are the cabin lights and planksheer. Because of the small scale I decided not to worry about the trim on the cabin lights but simply drill a scale size hole which will be filled with clear canopy glue to represent glass once the hull has been painted. To finish the planksheer with some detail close to the plan profile, I added a piece of half round doll house moulding (Northeastern Scale Lumber Co.). While not a perfect match, once painted I think it will enhance the ships profile.
Next steps will be deck planking and bulwarks. I'll start the coppering when I basically have completed the hull. From my experience this results in less handling mishaps because once the hull is coppered it will be mounted. I find it harder to maneuver and work on the model once it is mounted.
First, I need to take a break and get back to finishing another project which was delayed because of items "lost in the mail.". Lowell Grand Banks Dory Diorama, need to add the crew (https://shipsofscale.com/sosforums/threads/lowell-grand-banks-dory-diorama.13415/#post-359372)
Finishing the deck planking. Items of note, "on all whalers the main deck was covered with a pine sheathing in order to withstand the wear and tear of the cutting in process, the planking was somewhat wider than the deck plank and was usually holy stoned bright". Unlike the main deck, the quarter deck planks are laid parallel to the waterway and not the centerline.
I used individual strips for planking the quarter deck and a piece of scribed decking for the main deck which will then be covered with scale 1"x12" wood strips to represent the pine sheathing. I felt it was necessary to add the bottom main deck planking, despite the fact that it will not be seen, to maintain the scale measurements of the bulwarks. Also, I wanted to make sure the plank sheer matches with the level of the waterways.
As I was planning out adding the pine sheathing for the main deck, I realized I'll need to add the waterways first.
Another issue I have been trying to resolve is the correct color of the bulwarks and deck structures. The instructions reference using "medium green" paint and grey. Well, define medium green? There is no historical standard and the only reference I could find was a "verdigris color" paint which is sort of the color of oxidized copper being used. Also, New Bedford Whaling Museum offers a print of Kate Cory which includes greenish blue color for the structures and bulwarks. From my perspective using a medium green paint, which tends to be darker in scale, would not be practical. Especially on a working whale ship.
Floquil Paints had a line of Marine Colors, historical, which included verdigris. Fortunately, I still have the color chart and will try to match it.
If you are still looking for inspiration check out TJ Lauria's website for his completed scratch built Kate Cory. It is amazing!
I guess he has most of his work on youtube now but you can search youtube for his Kate Cory. Totally worth it
Oldmate
I mentioned Tom in my first post, actually contacted him before I started. He's been helpful in answering questions. If you check his website there is a gallery of his work.
Thanks
Finished much of the bulwarks and various railings. Used my new Mini Dremel on the pin rails, great tool! I was amazed at how accurate it is, very little vibration, made the task easy. Putting in the gangway was more challenging than expected, plans were somewhat hard to interpret. But it adds a nice detail.
I was struggling with the shade of "green color paint" to use on the bulwarks and deck structures. Fortunately, Tom Lauria shared some helpful information on mix ratio's he used for his 1/4" scale build (you can find Tom's build on YouTube). I use only enamel or out of production Floquil paints and after some trial and error feel I have a decent period color representation.
As I progress with the build and anticipating next steps, I have found the kit plans are lacking in detail. I am continually reviewing the plans from New Bedford Whaling Museum as well as the two books noted in my initial post. Interestingly, both sets of plans were drawn by E A. Ronnberg Jr.
whaling historian.
My next step will be coppering the hull. I plan to use a "checkerboard" appearance. It is a tedious process involving attaching individual plates. First the copper is heated to produce variations in color, "yellow metal" I'll add more background about this process in my next post.
Started coppering the hull. This is a very tedious and time-consuming process, especially preparing the plates. There are many posts regarding "how to" but they basically involve using copper tape. This process involves applying individual plates.
For reference material I have books and copies of NRJ articles as noted in my prior posts. These are in addition to plans from New Bedford whaling Museum. The color of the plating is a modelers choice, I choose a dullish color similar to "yellow metal" or" Muntz metal" because after the early 1830's a composite zinc/copper mixture metal was used, Kate Cory was built in 1856. The reference material also contains a comparison of how copper plating was manufactured and stored which also impacted the color, dull versus today's bright color copper used on yachts for example.
I made a template from .020 plastic stock to mark the belts. To prepare the plates, first remove the adhesive from the copper tape by soaking the tape with backing attached in a jar of lacquer thinner. Once the backing became loose, wipe the adhesive off the tape with a clean cloth. Then, back in a jar of clean thinner. After the second cleaning, pass the tape over a heat source, I use a small candle to dull the color. This process will not produce a uniform color effect!
Next, start cutting, these plates are 1/4" x 3/4" which is close in scale (with overlap) to the 14" x 48" plates used on the Kate Cory. I estimate I cut approximately 400 plates. Once the plates were cut, back in the jar for cleaning, remove fingerprints, etc... Excluding prep time, I've spent 4 hours applying plates, long way to go.
Still need to address the gore line.
Coincidently just finished coppering the hull, finishing the rudder. Need to clean and seal the plates, will post pictures shortly.
Thanks
Finished coppering the hull and then mounted on a temporary base. It is important not to use a cradle as it will damage the plates. The thin wood strip is a "wood guard" added at the water line as noted in the Whaling Museum plans. Next step is to finish the rudder, hinges, and give the copper a good cleaning before airbrushing a coat of Dullcote lacquer.
This stage of the build was very time consuming and I am anxious to start on the deck structures.
Time for a quick update. Completed the rudder and working on remaining hull/deck detail. This is an old "Yellow Box" kit, so no die cut pieces. The tail feathers and catheads aren't difficult to build. However, the issue is the absence of detail in the kit documentation and Museum Plans. Also, the original kit does not contain the correct anchor(s). The Museum plans note it was common practice to carry two types of anchors, Kedge (secondary) and Bower. Fortunately I was able to buy them from Bluejacket Ship Crafters.
Starting on the deck structures. Fortunately, the Museum plans contain more detail and views then the kit plans.
Haven't made much progress of late, some life issues interfered with my hobby time, imagine that. The Try Pots have been an interesting project, more involved than I expected. Everything except the pots is scratch built. Fortunately, the Whaling Museum plans are very detailed. I still have some minor detailing, then a coat of Dullcoat lacquer will help bring color consistency.
I think I did a post on the brickwork some time ago. Started with a piece of scribed deck and using a small screwdriver added the lines of bricks. Sealed the wood and painted using a rust color. When dry, a wash of light gray watercolor to highlight the mortar.
Finishing the remaining deck structures. When building these small deck structures, I have found using various size precut small wood strips, HO and N scale modeling supplies, make it easier to reproduce scale trim and framing pieces. Also, poly rod was used for the window bars (have to post another photo).
GReat result with the mortar walls - very good looking
very realistic appearance Thumbsup
Finishing the deck structures. Decided to open up the chain hole and will display the anchor chain running out of it to the anchor. Started on the masts and shaping the whaleboats. Still trying to get a more realistic trywork copper finish.
Thanks
Tom Lauria, is a friend of mine. He is always willing to help you on your project's
if he has the time.
His YouTube videos are a wealth of information. Also, put down some cheap pine boards in front of the try pots. They did that to save ware and tear on the
deck.
His Katie. Cory and whale boat build are great teaching videos.
Also his videos on making Sails are well worth the view.
Also check out Kevin Kenny’s videos. They are also great teaching videos
Tim Murphy
Thanks Tim. I corresponded with Tom when I started my build, he was very helpful. He also gave me some tips on the L.A. Dunton, a future build I am considering.
Visited the New Bedford Whaling Museum numerous times during our years in Newport. It’s a lovely area and I miss it a lot. Your Kate is beautiful.
