Novice builds Artesania Bounty 1/48
Geelong, Australia
The outward-facing surface of the hull frames for my Bounty model are naturally all parallel to the false keel. So if the planks were simply glued to these surfaces, there would be very few frames where the planks make full contact with the face of the frame. Is it common practice to sand/shape those outer surfaces so they essentially follow the contours of the hull and therefore offer more surface area where the planks are glued to them?
Cheers, Phil (newbie)
The attached Simple Hull Planking Techniques is a valuable resource. I've read through this several times as well as watched a number of How-To videos. I'm getting ready to do the first planking on the Polaris once I complete the bow and stern bulkhead blocks. There is an excellent thread here in SoS called Basic Training with more good information.
Yes--the more you sand the easier the planking will be. I'm not familiar with the Bounty kit, but it might be a good idea to shape some blocks at the bow where the plank bend is extreme--that will give more surface area for the plank to sit and for more glue. Good luck!
Excellent guide! Thank you…
To kick things off I am making a jig to hold the keel in place while I glue in the hull frames. I used the “other side” of the keel ply (the board from which the keel was cut) as the shape to precisely support the keel. I have yet to construct the brace that will ensure the frames are fitted square and level.
Nice start. Jigs are good.
Square is good.
Looks like your workbench is too clean. Or is it the kitchen bench
Great idea to use the ply sheet excess.
A build log of your ship is helpful for you to document your build and learnings, and it is nice to go back and reflect on after months and years of effort. It also encourages others to follow along and provide advice and encouragement.
What Bounty kit are you building?
Using filler blocks, often with balsa wood, between the stem and stern bulkheads is very helpful to get good contact with the first planking layer, especially after fairing (sanding) the ends of the bulkheads to get an even contour.
The Bounty has a very rounded (bluff) bow and is very challenging.
Michael
I am a complete novice and this is my first model ship. It is the Artesania Latina 1/48 kit.
I know it is ambitious but I always do a lot of research before taking action. This website is priceless!
Regards, Phil
Good plan leaving the bottom edge of the false keel attached to its plywood sheet. I have often done similar but with less foresight so I have had to re-attach the cut out piece. I endorse the suggestion by Thomas and Chestcutter to fit bow blocks. Lime wood is good: easy to shape and firmer than balsa. Or perhaps you would use eucalyptus down there?
Thank you for the Planking PDF. I printed it and have been reading it. I am ready for that stage on my Amati Bluenose 1:00 model.
Ok, thanks Uwe. Looks like I am ready to go. :)
I am still fiddling around with the home-made jig to ensure the frames are glued vertical and level. I am paranoid about making sure this is done correctly, as advised on many posts. The jig is turning out fine, and looks like it will cost me about $50AUD (about $35USD). It will only be useful for the frame alignment, and I might try to adapt it to assist in holding the model while it is planked. More photos of the jig coming soon.
What I have learned so far....
1) Read the supplied instructions and study the assembly photos BEFORE DOING ANYTHING.
2) Number all parts as they are broken/cut out.
3) Study other people's logs of the same build.
My log is going to be somewhat drawn out. I am a novice, I am slow, and I am doing a lot of research before diving in. Thanks to Chestcutter for some invaluable tips and tricks before I kick off.
My jig is now finished and I have attached a few photos. Its sole purpose is to ensure the frames/bulkheads are glued in perpendicular and square-on to the false keel.
I used a couple of T-section aluminium channels as guides and some adhesive-backed measuring tape to ensure the sliding vertical panel could always be set up at a perfect right-angle to the keel. I have not yet actually glued anything in place.
The base is particle board and most of the other material is 5mm ply.IMG_2339.JPGIMG_2338.JPGIMG_2337.JPG
The base is particle board and most of the other material is 5mm ply.View attachment 446696View attachment 446695View attachment 446694
Hi Very nice jig with t-tracks and calibration adhesive. Taking the time to ensure the bulkheads are square is time well spent.
The sliding upright looks great. You are off to a great start.
I will follow with interest.
Michael
A document on Planking I just read suggests that the fairing process be carried out BEFORE gluing the frames onto the keel.
Any comments on that suggestion?
Regards, Phil
Hi Phil,
Which document gives this advice? I can see a start to the fairing process being done off the ship for the foremost and aft most bulkheads, but to get the final fairing so everything is exactly in line would be extremely difficult if attempted before all the bulkheads are fixed in place.
Thanks Allan,
Agree with your assesment.
The document was by Dirk De Bakker titled “Simple Hull Planking Techniques for Beginners”. Page 5 talks about dry assembly of the bulkheads.
That name sure brings back nice memories. I have not been in touch with Dirk in about fifteen years when he retired and decided to have a family walk about and as far as I know gave up ship modeling, at least at that time. We discussed many things and framing and planking framing techniques was one of them upon which we disagreed, a little. :) No reason not to give it a go, but if the bevel is overdone, a new bulkhead will be needed.
