Also invest in a set of small drill bits they are silly cheap from the likes of EbayHi, I place a very small amount of CA on the very end of the rope and smooth it in a little by rubbing my fingers. It only takes a tiny amount of the glue spread over a mm or less. Once it dries a little use that glued stiff end to thread through the hole. Once reeved I usually cut the glued end off. You’ll probably find many of us use this method. Hope this helps.
Great job on that build.
I used these for a few models, but found them frustrating as you are trying to pull a folded over rope through a single rope hole. PVA or CA the end and cut to a point as described above. Looking at the drawing you posted, I have to ask.....are the blocks in the kit actually shaped like a box instead of a block?Needle threaders
Using this method but adding a angled cut through the glued area provides a nice point to start through the block.Hi, I place a very small amount of CA on the very end of the rope and smooth it in a little by rubbing my fingers. It only takes a tiny amount of the glue spread over a mm or less. Once it dries a little use that glued stiff end to thread through the hole. Once reeved I usually cut the glued end off. You’ll probably find many of us use this method. Hope this helps.
You can get a “bulk” order of these from Amazon - the metal threading bit does have a propensity to detach from the handle.Thanks to everyone … and I also just bought a needle threader, arrived today, having tried the CA route, and the needle threader works so well I’ll stick with that for now
After the CA dries, I cut that end diagonally with my X-acto knife to make a sharp point.Hi, I place a very small amount of CA on the very end of the rope and smooth it in a little by rubbing my fingers. It only takes a tiny amount of the glue spread over a mm or less. Once it dries a little use that glued stiff end to thread through the hole. Once reeved I usually cut the glued end off. You’ll probably find many of us use this method. Hope this helps.
I use needle threaders too. I bought a lifetimes supply for next to nothing on Amazon (other market places are available). You can bend them to different angles which is useful for this hard to reach places.I used these for a few models, but found them frustrating as you are trying to pull a folded over rope through a single rope hole. PVA or CA the end and cut to a point as described above. Looking at the drawing you posted, I have to ask.....are the blocks in the kit actually shaped like a box instead of a block?
For a first build, your work looks really good. One big point, as it is very visible, for the future, the battens on the gratings always run fore and aft, not athwartships.
There are a number of posts here at SoS regarding this feature that should be of some help.
