That a big Aai …….You know that nagging feeling in the back of your mind something is amiss? Well, I am all too familiar with that feeling and this project has little gremlins allover the place, with plenty of opportunities to get reacquinted with that feeling.
A while ago I was busying myself with the fuel tanks, adding a battery in one tank and an on/off switch in the other tank. I performed a dry fit and what struck me at that time was that apparently the measure between the aft of the tank to the tank attachment on the aft cross brace of the skids appeared to be somewhat too small.
For one reason or another I dismissed my observation, since I couldn't positively position the tank relative to the fuselage, stored it for later evaluation and went my merry ways. Yeah, right, that decision came back to haunt me big time. Last weekend I joined the tank with the battery to the tank with the on/off switch and again performed a dry fit. Lo and behold, the same phenomenon could be observed. Either the distance between the fwd cross brace and the front of the tank was way too large or the distance between the aft of the tank and the aft cross brace too small. Initially my idea was to make it work somehow, but that didn't sit right. Instead, I started taking some measurements. Too may great dismay I found that my initial sketch I used to produce the torsion box sidewall was rather spot on, but... my transfer of the sketch to the hardware wasn't!
The torsion box ended up being 5mm too long and the pitch between the front and aft cross brace watch 3mm too large, the length of the fuel tanks was spot on, by the way. After some days of contemplating, I decided to take apart the torsion box and make a new one, now (hopefully) correct. That's were I'm currently at, again making a torsion box...
These were my observations: the aft tank attachment was too much aft on the fuel tank.
The findings after checking the actual dimensions with the sketch:
And these are the sorry remains of my little hummingbird, after demolition of the torsion box:
(In the mean time work on the new torsion box started.)
Yep...Ouch.
From the looks of your demolition, I would conclude the torsion box was a sturdy stout structure that you can at least feel confident of its stability when remade in the corrected dimensions. I agree with Peter, 'you have the guts and energy to rebuild it'.You know that nagging feeling in the back of your mind something is amiss? Well, I am all too familiar with that feeling and this project has little gremlins allover the place, with plenty of opportunities to get reacquinted with that feeling.
You're right Dan, the torsion box is rather robust and can take a lot of handling forces. I changed one detail, see my post #147 above, to enhance the robustness, but other than that, I'm quite pleased with my decision to go for a CA-bondend, brass torsion box. Thank you (and of course Peter) for your vote of confidence, but I couldn't live with the faulty torsion box and hey, if I can build and finish the YQ Bluenose, I can do the same with this little bugger.From the looks of your demolition, I would conclude the torsion box was a sturdy stout structure that you can at least feel confident of its stability when remade in the corrected dimensions. I agree with Peter, 'you have the guts and energy to rebuild it'.
Thanks, Heinrich.Johan you know that I am not new to redo's and if something does not sit right with one, there is only way. I have built tow WB's and twice have I stripped the planking from one side to redo them. As to the pros and cons of scratch building, I believe that is all part of the discovery process - a process that I will be part of or partly part in the not too foreseeable future (hopefully). In the meantime, respect!
So looking forward to that moment!Once I retire, I hope to do a scratch build. My goal is to design my own ship, either 17th or 18th century and see what I would have done as a ship designer, the deck layouts, levels, cannon locations, shape of the ship, ornamentation, etc. and let my creativity go wild!![]()
Scratch building and redo's are almost synonyms, at least for me, like the engine for the Fokker Spin, which was build three times before being acceptable.
‘3x = Scheepsrecht’ ……. Well done, Johan. It’s looking very nicely detailed.The rebuild of the torsion box is well under way. I did a couple of dry fits and this box seems to be a lot more to scale than the previous one. Still don't have the foggiest what happened with the previous one.
I was able to use parts of the previous box. What I also did was to add some pins to more positively locate parts relative to one another and it also gives a little more robustness to the box.
The pins were use to locate the top- and bottom skins to the side panels. Also the aft lower skin attachment to the mast boom has now been relocated to sit inside the box, instead of on the outside and was located to the box with a pin.
For the LH side panel I am waiting for an Evergreen order; there's an idea I want to try, not sure if I can get it to work.
View looking fwd and to the left, the bottom mast boom attachment can be clearly seen:
View looking aft and to the right:
I started adding "rivets" to the tail beam; that now gives a real sophisticated look:
EISH!You know that nagging feeling in the back of your mind something is amiss? Well, I am all too familiar with that feeling and this project has little gremlins allover the place, with plenty of opportunities to get reacquinted with that feeling.
Many times I have had to have 3 attempts at something. Once to see how to do it, a second attempt to do it properly, and a final one that passes inspection. So I know how it feels.
Sounds about right, building parts 3 times to get it right, Scratch building is very similar to building prototypes: a lot of trial and error.‘3x = Scheepsrecht’ ……. Well done, Johan. It’s looking very nicely detailed.
