I've just reached the masting phase of my build and sadly discovered that the lower mast dowels for the Foremast, Main Mast and Mizzen are warped significantly. They all appeared fine as packaged in the kit, but displayed this problem after removing the elastic bands that held them together. I'm looking for suggestions for straightening these. I've used the following technique on sample pieces of maple (which these masts are made from).
A. Soak the dowels in water for 24 hrs.
B. Remove the dowels from water and fasten to straight/flat surface with "correcting shims"
C. Blow dry with heat gun set to 300ºF till dry (about 2 minutes)
D. Apply a penetrating oil (non-tinted) and reset the clamps and shims
E. Let sit overnight then remove.
This corrected the warp and the penetrating oil should stabilize the dowel fibers - but I'm uncertain if the warp will return after these dowel are installed on the ship.
Looking for suggestions please
Reg
Reg
