NHI Kolibri N-3, scale 1:48, scratch build
Finally I convinced myself to seriously work on that thrice darned tank suspension fittings.
Initially my efforts were aimed at replicating the original suspension. I used some brass sheet, t=0,25mm and started playing around with some ideas I had.
Both the undercarriage cross spars and the bolts of the tank suspension are parallel to one another. To add to the difficulties the fittings should preferably measure 6mm by 2mm.
After some trial and error I came to adopt a producible solution, instead of lifelike representation.
The pictures below show both the front- and rear suspension of the tanks on a dry fit of two of the four tanks.
Now I have to let it sink in and see whether or not I still like this solution after looking at it for a few days.
General view:
Front suspension detail:
Rear suspension detail:
Early prototype front suspension:
Als some work was done on the LH & RH nav lights.
I used 2mm transparent acryl tube, dia 2mm and inserted an SMD, used some CA to fix the SMD and applied some paint:
The current mess of the center tanks with the necessary wiring:
Just to make sure the lights work:
Still a lot of issues to solve before I can declare success…
Also, despite having gone from 1:48 to 1:16, even the larger scale doesn’t mean that all parts become easy to make.
Good to see a very nice update of the build, Johan. And as I wrote: The size of the scale is inversely proportional to the details of the parts. The bigger the scale, the more you can deep into the details. But you doing your research and find solution for the Kolibri.
General view:
I think that works well, just add a band or strap on the back and it will be close enough. And you could even add two triangles on each side of the eye shaft that join the strap. ;)
General view:
Your skill at manufacturing small brass pieces is amazing.
Thanks, Peter, she's still a very interesting and challenging project.
That's food for thought. I'll look into that, see if I vpcan obtain a more realistic look.
Thanks for the tip!
Very interesting attachment hardware in your design Johan. The aft end of the tanks appears to be able to swing ever so slightly on a hinge point. The overall detail is outstanding.
Thanks Dan, keen eyes for details you still have!
The fwd attachment of the tanks is a straight forward hinge point, whereas the aft attachment is a link, allowing fwd and aft movement. I tried to get this in scale 1:16, but even with pins of 0,5mm (plus subsequent bushings of at least 1,0mm) it leaves no room for a swivel link, so I had to cheat...
Ha Ted, thanks so much for your compliments.
I'll not start about the difficulties in order to try and get those details done. One things for sure, I really miss out on some nice miniature machining capability.
Although at a snails pace, work on this nimble helicopter continues.
I added the two LH- and RH nav lights, see picture below. I used clear acrylic tube for the housing of the lights and brass tube for the lamp fitting. The housing of the lights are painted in the appropriate colors.
The routing of the wires is also coming together: the wires will run below the floor towards he RH center tank, which also houses the light switch. There is unfortunately very little space to a) connect the wires and b) stow the surplus wires in the RH center fuel tank. Still something to pay attention to.
Another tiny detail which still needed to be added were the struts, connecting the skids to the aft cross beam legs. Additional detailing is still required for the wheels attachment, also a lot of touch up is needed...Sick
Finally, after dragging my feet for months on end, I could no longer avoid to try and use the airbrush. @Peter Voogt gifted me an airbrush, minus compressor, and after buying a low cost compressor, I postponed any activities concerning using the airbrush for as long as I could. Now getting close to the point where I have to install the fuel tanks I had to start learn ng to use the airbrush.
Below two pictures of one of the fuel tanks after two layers of paint. Not perfect, but I think it's close enough for an airbrush rookie:
The air brush on the fuel tanks looks great Johan. I have found the amount of preparation and then clean up with an airbrush way exceeds the actual spraying time which to me is the only drawback.
Agreed! I think they look great. ;)
Yup. A nice outcome.
Thank you, gentlemen.
I really thought I was heading towards a disaster airbrush job, but in the end the results are way better than any paint job by hand,at least when I do the hand painting.
And indeed, applying the paint with an airbrush is not very time consuming, but especially the aftermath is rather time consuming...
That’s my complaint with an airbrush, if you don’t have much to paint, then it’s hard to justify using it. I have become very good at painting small objects with no brush marks. It requires multiple thin coats, so I’m not sure that you’re really saving any effort or time, but definitely less messy.
View attachment 526623View attachment 526624
That's looking very nice, Johan. And for using an airbrush, it's practice ........ practice ......... practice. But this is looking very promising.
I fully agree with Daniel and Dean. I mostly collected items so I can spray more efficiently. For cleaning I have the Vallejo Premium Cleaner and ..... the most hottest water my installation can give.
Finally I was able to complete the aft pivot assembly of the tail rotor controls. To drive the entire system, the pilot either steps on the right or left pedal, which in turn, through the pull rod, rotates the aft pivot assembly. The top lever of the pivot assembly drives a push/pull rod, rotating the lower lever assembly. This results in the tail rotor push pull rod to move up or down. It's not the complete system yet, quite a few more parts and assemblies need to be fabricated, before I can call the tail rotor drive system completed.
As a test, I equipped the RH center tank, which houses the lighting switch, with a soft stop (silicone) which I normally use on cabinet or kitchen doors to stop wear and tear or scratches. It does look surprisingly good, at least when compared to the original configuration.
It still doesn't match the other three tanks, but is looking way better than it did...
Unpainted RH center tank, unpainted, with switch installed, but without the silicone end piece.
In real in scale 1:1 it’s a complex part rods and pivot points. In your scale even more, Johan. And it’s functional! Just a. Big WOW. And a clever solution for the switch.
