Royal Louis - Mamoli
Hello all and thanks for following.
I’m not sure where to start with this latest update, I’ve been happily working away on it, making quite a lot of progress, intending to post the work as I went along but I never got around to do so. I’ve decided rather than explain what I’ve done bit at a time I’ll just tell you all in one go where I’m now at.
I made up and fitted the bow platform using the grating comb strips provided. I made the steps for the side of the hull and at the bow bulkhead. I’ve done two bitts and two pin racks, the cat heads, the cast decorations on the bow cheeks, some eye rings on the main deck, finished off the capstan area, and fitted the head rails which turned out rather well, probably the best on any model that I’ve made. I’m now in the process of panting the figurehead. If you look at the pictures you’ll see all of these things done. I'm loving this build.
Hi Ken your RL looks fantastic it makes me want to start mine straight away. Did you have any trouble fitting the castings, did they require much bending. This has given me some problems in the past.
Tony
Looks great Ken. The paint work and particuarly the choice of colours make her stand out.
Love it JJ..
  • Like
Reactions: Ken
Tony
Hi Tony. You'll have no trouble shaping the cast parts, they are nearly as soft as lead.
Love it JJ..
Hi Jack. Thanks for your kind comments. The colours were a bit of a gamble but I think they worked for the effect that I wanted
Good morning, thanks for being here and giving me your likes and comments. I've pretty much completed the bow so now my attention is turning to the stern. I've shown the area that needs to be built up using the cast pieces that make up the transom galleries and the pieces supplied to do the job. If you can recall the film Apollo 11 where the crew had to assemble a device to absorb the carbon monoxide from the air using only what bits were at hand, that's how I feel about these galleries right now. I've identified the parts and their positioning, cleaned them up, made and fitted mahogany inserts for the lower parts and fitted the simulated window panes. The windows aren't ideal but at this scale they'll do for me. Newer kits would no doubt have PE. frames but again for its era it's very acceptable.
Hello again. Here’s my latest progress update. I’ve managed to put together the puzzle that the castings for the stern galleries presented me with. The drawings only provided a view of the finished galleries but didn’t show how to actually do them, they only said that they were difficult and that I should study the parts carefully to get an understanding of how they might be assembled. The facias for the stern cabins were easy enough but the side galleries with balconies proved to be quite a challenge. The castings although malleable were almost impossible to bend into the required shape, they needed bending around but also needed tapering in at the top and sort of splayed out at odd angles towards the bottom as did the railings, however after much filling I got an acceptable end result, though the swear jar is now full. I added the cast decorative figures then finally painted it, it looks okay unless you get up very close so I’ll accept that. I then made up and fitted the hand rail at the rear of the quarter deck as well as fitting the smaller strakes along the rear part of the hull. To finish off I fitted the two boat cradles. I think it’s starting to look quite good.
Hi Ken
The stern gallerys look very impressive, I'm not looking forward to this part when I get around to making my RL.
The speed at which your models progress is way out of my league.
Tony
Hi Tony, Thanks for the compliment. When you get to the galleries give me a PM. Having done them I would be able to give you a few tips, knowing how they were done would make them fairly easy. I wouldn’t have any difficulties if I were to make them again. I’m not really a very fast builder, I’ve been retired for a number of years and I tend to build models as if it were a job so spend many hours most days at it, it passes my time pleasantly, especially in the winter. Ken
Good morning and thanks for continuing to show your interest.
Today’s post is about the making and fitting of the deadeyes and channels. Because of the kits age the hoops and strops supplied were cast and not PE. but they were pretty good. Being cast they were brittle and couldn’t be bent so you couldn’t prise open the hoop to fit the deadeyes in which meant that I had to file out the hoop leaving as snug a fit as I could and add a drop of cyno to hold the deadeye in securely.
The supplied channels were mahogany ply and due to age they had become very brittle and crumbling at the edges this wasn’t a great problem as I was going to plank and edge them anyway.
After planking and fitting the deadeyes I stained them a dark oak, sealed and varnished them. I painted the edges blue to match the hull, then attached them using both pins and glue. I’ll add the strops after the gun port lids have been done.
Hello, if your still with me here’s the latest update.
I’ve fitted the strops and chains to the deadeyes. This was a bit tricky, as they were cast they were quite brittle and could only be angled slightly, great care was needed not to snap them. For a 1:90 scale they are way too bulky but they were what was supplied in the kit, if I were to do it again I would make up my own from brass wire, as they are they are just about acceptable.
I made up, painted and fitted the port lids, using nails to mount them instead of the tabs at the end of the hinges. There wasn’t enough boxwood to match the hull so I used lime and stained it with a light oak which worked out quite well.
I then fitted the canons, keeping my fingers crossed that I had set the mounts correctly when I did my version of the recessed ports, happily all lined up perfectly, I was very relieved.
It was about now that I wished I was building a frigate instead of a 120 gun three decker, but at least I haven’t stalled yet.
Hi Ken,
I just found your build thread. You are doing a beautiful job. It is amazing that you started your build in February. I will be following along and enjoying your work.
Bill
  • Like
Reactions: Ken
Splendid and colorful work, Ken. I really like how you used wood veneer on the cast gold decoration panels on the stern. It tends to subdue the contrast between the metal and wood and blend the parts together, so the decoration do not appear to be just pasted onto the wood hull. :D Thumbsup
  • Like
Reactions: Ken
