- Jul 9, 2018
thanks for confirming what i thought........cheers....
Three ways you can try: 1. spray primer the brass before apply acylic paint, 2. light sanding then thin acylic painting 4-5 coats, 3. use speed acylic paint markers like Arrtx. I will go either 1 or 3, much faster. Making a speed acylic paint markers video, I will demo the marker way in my video. Good luck!paint doesn't stick that great on the white metal, but it seems ok.......but how will it stick on the brass?...do you sand it first? or?
The upper one looks like the lantern on the side doorarch at the forward grand staircase. I’m not sure about the lower one.
I believe the fiddly bit with the conical top is probably a lantern or gas light; the other might be a steam whistle. If the instructions don't call out what they are, some hint regarding their respective uses might be discerned by where they are to be placed.
