Santìsima Trinidad (Cross Section) by Jack.Aubrey - De Agostini Partwork- Scale 1:90
Cinisello Balsamo (Milan), Calci (Pisa)
On May 3, 2009 I officially started to build the Santìsima Trinidad's Cross Section.
It is the second part of the De Agostini partwork made up of 160 weekly issues in which you build
A) the entire model and later
B) the Cross Section.
It seemed me quite simple to build and I thought to follow with due diligence the kit instructions. This was my first cross section and I didn't want to take any risks.
In that period of time I had another project still active: the Armed Launch 1803 by Panart and it was in concurrence with this one.
I published the images of the finished model of the armed launch on the gallery here: http://modelshipworld.com/index.php?/gallery/album/210-armed-launch-1803/
At that time I didn't have a workshop where to progress my models so I was working at home, on the kitchen table . . each time i started something I had to put out everything and at the end put away everything . . heartrending !!
That's all for now, cheers, Jack.Aubrey.
01 Cross%20Section%20Santisima%20Trinidad/P1050512.jpg
y4mjJknU4Xsdzt3-NkMHC2mF2pNg_cHVlMRE6lxCcIzCaZ8Q8p16QrOluUwipLDA-qyU0OsQdv_9v1tj3Isr4y3rkwlI0PdMVwF4gPPYJ503ryQzz2NaGnfqR4TNGmSsE1Y__W0WT87rtSRAeAszxSeLFJSHcZdhefPaBn64idG_Ii59TrVfWoFkS42b3eJM5k1TCFvmuWvFs815fXBZphATg
02 Cross%20Section%20Santisima%20Trinidad/P1050513.jpg
y4mLH218AUQS-qCA4b7VUS231O0vLTDWjjoSPVjyOWzh9CXwu3N1EanDbKd0Fg55DBcrI9M-v3x6YUmpRp7SrD0w6-dM-oZApflgrlSskuA1CqQFMo1aH3CKKV0Vo95NP5VZwsUfNYfsfnD9DTPHQA8sHBjDdwh2jJQM46DwLLVocA1nQhMJSkYVrH79gjBQRDR3I-wpMuD4d0NM-ddu9ZW6w
03 Cross%20Section%20Santisima%20Trinidad/P1050514.jpg
y4mKPvfMib3xmSZcnxDGM4MyczwOeJRNgNqQz5k2n_ihbhcg769DQ_MginWko9n0Bhmg77U8B2IfSd3mNycRkD9C5tJ3vDbiY5kaKM7ROF9m27FtQb23vfQZzluUc9bsLXmj1fIISPOgrLw20OV5kODb8uSwG30S30ppMIKkWqpceC79CM6OsiYdHbtJxJrn1JvJ3PSXNuN16ohj1cBquYLhA
First of all I needed a basement that allowed me to mount perfectly aligned the two frames. I built the one shown in the first two images.
01 Cross%20Section%20Santisima%20Trinidad/P1050516.jpg
y4mthP-nN0pTEAzaPwyN1YkNx8yPUqX4fuRLCd3Ah5Lxsah3Mm8sMMzzc8vUuHJaaSBP5tg4-ab_kZuvffoFvPIvFczTg2XfW_dpOYF3iGKtW2Cdf3KJkXLkxBhNj6zZHbF9PDzBntnpGwvc6A9NKPtBb6kJ2ykIvmkzEYkFgLtp8wp6bo1ZqbOYuJ3_4n1TnBjjR2-kO988iQS-ZEp0dZiZQ
02 Cross%20Section%20Santisima%20Trinidad/P1050517.jpg
y4mSb-YtaBcqHEytK6zoNTFrmPWU4BV1G130FdwvrsgvFfTho2y_m6Ve6679AALCk_3h0DXnUrJ2KqOYtCsbest_DmSG7-5Kn-ese0G7UFR5P8Ctxzr0OJvm1Q8awOZmQ1XzFYvaMOD6lZ93gjg0YSDZgw5vle2mhLYjAhOkuiPoo4ctuEiZIpez_dA_FyEkbv0tECGlWdPCqz6XlFK3lvZmg
Here below you can see how it should work. The frames and the keel are simply positioned, not yet permanently.
Kind regards, Jack.Aubrey
03 Cross%20Section%20Santisima%20Trinidad/P1050518.jpg
y4mDtliCedevO4xV13BX5_TlTL0MMjFwwz9PK2dyZX36SnFXUSkrIcUDA_QwM8dlPB1tlLr6YRn-9SygLf4OY1bySB5s4mI5YEBvCldSMH906Yd0Ns2c-6-JIUO37K2oJ_BGEEhx3qf2v1686re-YFjEx5_MuRB_l3vo6sJ8sIPnTEHdyRj0g2QwD0IK5pI2v_ab1j2_AzJHk-GMi05ofh66w
PS: For this project I decided to use the aliphatic glue, instead of the vinyl.
Additional images showing the frames installed on the basement from other views. Now its time to glue them . .
01 Cross%20Section%20Santisima%20Trinidad/P1050519.jpg
y4m6Ek8fdavf1l2f0pEMGMeytqPr2IupCHxRmOr_lorp3Cx2uFNGqi0HJnXpnx9QSAAQTXtAvFG_kHfwkSYslyLAS0HqxsxZtWL4Cz3JbBjzIRkancW1mRS09GH_3zNgt7kne5quqrMJn3627hTXDpbWhbuOh7uDK_o_gGTrLAaVyqVI2oXv-x-G2kQdvAQ4FllYd_njENguHv08wdOvKyoCQ
02 Cross%20Section%20Santisima%20Trinidad/P1050520.jpg
y4m4KeyTaSrDY7ddkrLyxLMakIt-Oj3ASAK0f6V9VOUWctQDFZ6r37uUPFFGEYS5I1Vir2IlA2NZT0G_Pjn4tI_OIjJ8YZqpOmN8M5KoTMI0A61y_rDtXUBmSTFlMTGSuoc9wLwpmivb3jT-1UxTV4P7RDwjK3G9EZq2o2msC_TAIpWrmS21jIMH4CrwGLbqVm96Bd7vZHFNsjTITzN1QqxnQ
03 Cross%20Section%20Santisima%20Trinidad/P1050521.jpg
y4mFeeyFi1Yt1tzumN6y4P72KxLLq0z4NGklfLg0ij7DULAlIUeYS4sXikxnBs3Ta7N8wiwF4fX3WZFo1ydrAaVc5uUhneEsmcJhf3vrOQxtt8bPwBaB2R-uC5f8BC-oo2cbUqTh3VSWZH2ZF8Ej--ydUuQ5bTJrjGEokZPLTt-e4aAapXgM4CCaT47m_qDGxkOxXCSowlMOHKpV7FOTbX3_Q
See you next time. Jack.Aubrey
PS: my first experience with the aliphatic glue is positive. It works in a very similar way of the vinyl and it is quite fast to grip and dry. I slightly changed the basement. As soon as possible I will show these few changes . .
May 5, 2009
The crop of the keel distributed with the kit was not right, so I made a new one; on it I have fixed the two frames.
Then I started to plank the inside of the hull, using pieces of mahogany of 5x2mm.
01 Cross%20Section%20Santisima%20Trinidad/P1050523.jpg
y4mM_1yd4bHAinExll4BMnlAUbtxMPNU7a8C1S9cd-Qxp1sTNyl0Wt_aklUHCQ-azz75U_D8TtTKgZY44HTyyqd4u9eL_8zwk0IC0e4QjHCEGcNr5NHD6KCpnz73zfsDvixdgQwOYFHtjC3wufID7bF2f8b2TqUII23y6eX_TlfVWRId49nj8Cnk8Uw6mdAIaAvpvTQUeHcjE8uiSfenGE7DA
02 Cross%20Section%20Santisima%20Trinidad/P1050524.jpg
y4mL5WC6zTw6RzjbCiDIw3Z_DrPVLtVHAO366dPEJkmaeAWNji8Uc8nnYuaxarKHlyB91dzuQOyE9qUKJo6u3p4e0BOBti9VaY1c_Pq-KTrczPiNEP0Uus8nQd7LqHIsXMErk3Ms1tpYFVujQM1c45hl-9TRoqKAchdm4mfyc7hpfdaTE2u1jhWAzlnANQsX3juEpKU8ibyLyAeK5C6t1Sd3A
Here below the "phantom" of this model without the basement used to mount it. It's very weak, in a particular way in the upper part. It must be managed carefully, at least until the internal and external planking will reach the right position to ensure enough strength.
03 Cross%20Section%20Santisima%20Trinidad/P1050525.jpg
y4mI_RVug-GX-Q-YRhR6CUy7ERdWBB8UQZwP_p6ea2xLGfpTTQesJR3nhmRjJlM7SdbWlyxKsVAE8oiVg9CQxxFaAdAduTKFFCclwyTX5CkCLTWjOLGqM7OrDHVQIl-7q1s_9Wa1gGsOHsNnGIKovjINtUNNCuXzX7HbUapX1CsBBZ5S3kRDNQC8Iw_GBo7h609BdCsGXxKy23w83l9FmLQOA
04 Cross%20Section%20Santisima%20Trinidad/P1050526.jpg
y4m3J5fOKQCj7zfXaqtexB094l4OsPiwQJWiAFhhp2uzsgzOBxfQJjqjoBDCXHBHwwq_IoSvrnq_z6ab2RSEpHw7COYhiaDySkPZjNWjgzsOuL5UNdXd9a-Y-oyVTdlnGUV4HW74OKfCzeki9AhNq31m2-LOEtinfMQXN32QEZ7MkGrx_cFXU37_d6hrxP2CeRa7NJ3HUNWF3G5gfaKdv-BpQ
That's all, see you next time, Jack.
May 6th, 2009 - further small advancements
First let me speak about the changes I had to do on the basement. This because I discovered it was not possible to remove the model once I installed some pieces of the inside planking.
By difference with other images you can sort out the changes I made: this changes allow me to extract the model when I want.
Now let's see the new things: I have built the woodden block where the main mast will stay, after I started to install the outside planking, starting from the bottom near the keel upwards. At this point there are seven planks installed outside. This task was done with the model extracted from its base.
Last I have finished the planking inside the hull reaching the first deck, the hold.
01 Cross%20Section%20Santisima%20Trinidad/P1050528.jpg
y4mogSg2Cq4CqOZDLX2bwmn-GkYjspF_3NDnxJXA88hiBhs3OVBCV9UmIInMFDeMee62ufR44wtfMlcyPi3MUAkPt3fToV6TmJrRFfP5tJr7LAFYpt2wt6JCV4q7NH54WpsWcT4kRUiHFfQk_ZkW0lbKcFYB0XOMcP2kFoFzkMALK_tJ_kuo_TzhAt8YFpFbiZ22r17s29mH4WYQnmr829yNw
02 Cross%20Section%20Santisima%20Trinidad/P1050529.jpg
y4mSCKCtDtYVT2IDiztnlJiQ6cEgga1PnrjR0ajeKZcHo1JSSBSGlgYkxMYExNYkDgIlbcIVh1Bfy2W1E60fvwLLEeLq1P8GIZ_gsO-Vnq6sxJcQHke42BDyzZAWM0mD1sOWyA4uXRlGip_L8CoeBo8eaP4V1H0uJpmjVtkPlzoDlBUfjby03DsFsYw90xLKf-3rdCS3gQVrTZA6HZJxOZ7AQ
03 Cross%20Section%20Santisima%20Trinidad/P1050530.jpg
y4ms63Pxv7dQoP4WEIdkC3Hxfke_z171BaHFXV4P32DK_SA0Xqmv8LrnlA1Qsgg6qg820Rr3vR4akD9oYUa9bbQ4X7cUSkLFTNNfJVYYtU7pJzGY0Rtx7l11Ss-9G0QT2ujkldsehStD40bWtIj9N3L2qCaDL6_rGvCwYG0LV4jdfswAzI-rp9Wt0mBk_hE5ILsUnlX4xTcPeT8EeRv0Cb-CQ
04 Cross%20Section%20Santisima%20Trinidad/P1050531.jpg
y4mdIFp3zs3GLqJMQDS9RwNuTxUmdIldfVX2309jP80jJwiHLMCS0_c0nywMySWibSC3aNK7dy1ZiPpzd6U-cda_uZrVOJgpkSvmzFnLVCdme8jddtlceNpDMT3eVQq319kG9IODe9r7996Cfi0-r1WzBjV9fOWJRiAQzMU1IDCZPvx1edACXX9n3pXHb3gVa_xV_o0Z1nDhO0sSGO4wZTydw
05 Cross%20Section%20Santisima%20Trinidad/P1050532.jpg
y4mKPQCqT2VMQulEi8_q86vQvNUXzEf_oeRC8a35Yoc9mqcazdoM5GY8spvnR4wVucNwA8Q-6za0ZnThJuE4AjJpfePNuewxbVZtqjVOhHfVfkocRwdRBwhkUuvrsUHCE5H99vl38bbaVI224PZy01l5GH5yggga4NN7aYcNMd1h78TLEgvh_R_Ljeif-UTZsSOCkbj8WKC4X9PzM7r8CAa2w
See you next time, Jack.Aubrey
Friday May 8th, 2009
I definitely use the kitchen to build this model. It is a bright room and generally I work just after lunch. My wife is happy because I help her to clear the table and I'm happy because she is happy . .
Let's start with the first image where there are two products: on the left side the aliphatic glue I'm using and on the right a new entry, at least in this project. It is an oil for wood, available clear and also coloured. I use the clear one instead of the various kinds of enamels, wood fillers, acrilic, poliurethane and so on.
01 Cross%20Section%20Santisima%20Trinidad/P1050534.jpg
y4mUJzFQVQ4WO7TQSZN_YoDjLM268hVXa1AgON7PDIDKx42VrBSju0tsEA9vULM19FrlMI2yovEucUwS7m-KKBepsfQzzFdVv3JZNm9izOcUjX0ZUgOkCfCfBOfulYNAWFH-BZ7-1jmgbdNEZ6A0tqwY3P2boIy9qVzu5XrZKA-q1G-AIiTekhkRCienlNPornLcJW8JxSHKVXj8IfPJ3b-XA
To apply this oil I use a brush of medium size and, when it is absorbed by the wood (+/- after 1 day) it is perfectly dry and matt. I think it is a real alternative to painting.
It is obvious that the surfaces must be properly prepared with sandpaper and removing traces of glue that may interfere with the oil absorbment. The result from its usage is that the wood takes a very nice, natural colour. This happens in a particolar way on dark woods but I used it also on fair woods, like beechwood or boxwood.
The main advantage by using this oil is that the pores of the wood are not closed and you can use the aliphatic or the vinyl glue after its usage without any kind of problems. And this is a great thing . .
02 Cross%20Section%20Santisima%20Trinidad/P1050536.jpg
y4mbuMEWMPZ9vuIiprZ6L3kVjLVYjm9lFNXFRGEngTTz6-ZcpAmU1EkWyXjdFbUdx7qN-9lfOigfI9MEusXKP4VEG1lY58kbbd0QtxXqSBGfiPi9BHp15C7qQFKA5Er_0BYJpiI3js8ONsimnaSkBYfOoZr49Lpdx5cmS6YfRbchTMh5A1CBjuw88MqRNYpOFbklwBX5u_jtBEO1J1naHHuqw
03 Cross%20Section%20Santisima%20Trinidad/P1050537.jpg
y4mIYCyIOgMF9kOEa_urgC-6-Z2ix6iHOaAsUmmAU8axDC3YOIVg6i-g11Ie-lNf9dEuJ_qce6Q5RUsVbWKi0ImMwUvVSLmInP40Qcyz3emXnuztj41IFpHmwMR1gA1vIF7Y-oEO8-8nleCph-JKqvoYGI8T1LkvhsnxtYmkDAj-kp6_lu5UDXO7iDe5DbyWRs5mTtub_9dTB50zT03FZcC0w
04 Cross%20Section%20Santisima%20Trinidad/P1050538.jpg
y4m81h0yU863mJmaIv-8UglCG2JQBLexw2We3Jo56JAz1pGmlWLG9FudtUJNAIBMV8E_-dOCtgY2QcFshUPz2FA3LP2PUXIHLoEHi6butmboACb5nRfu6VkzWSDSa49H9I9pZVUvBCnTNdoin1_nbk5MAOxaW4NZq2kX-VxRvRBTxC8ir1aJ-4Yg6EInGVClWV_DFZNql0acnmY9JpsGxkRuA
I have added some few planks on the external side, now it is at the same level of the internal planking . .
I have also installed, following the instructions, a third beam.
Now I'm working to prepare the hold deck.
Two additional images to better appreciate the chromatic result of applying this oil . .
01 Cross%20Section%20Santisima%20Trinidad/P1050539.jpg
y4m1LvgoRwSW09Miq7hdBiVl0Tiy1dbXTnohlbtsJtUKN4si4NZy4UXlork2rTGpCJ-ydcms9a_AurKJWYIoaceLsm9Eu6vdwiyrvudNUpREMNpKln7aSH_OJc8Srij9cFtatmsUScSf66o2f5TF8h13DUQ7AI20D2-7o4Qj0CooqLb3PgE7zsKhZqEcACLjbPNcEtv_olNmR0nhDI5dY3Xnw
02 Cross%20Section%20Santisima%20Trinidad/P1050540.jpg
y4mR__C0AbFT-2u2jH8eOM9-sOMkXHiy9wFX8G9J-pypJr5IAWASbIhFOysiT3eOTRLm_sDo9BhYtPHrtdueuhaTp3F8yiY0jLweCTTKnopmHj_5wzghp66OW0Gt4JlEBHm6t5EggkJtprVtb45idNo2EGBL1THVnZy1c4hDs5WEW9ARlvjaO_8ndVH_zqkN5NQE16hJvSDF3zUhhNXv81NXQ
Sunday May 10th, 2009
Now it's time to further continue this modelwork by building its first deck, the lowest of this ship. The raw pieces are 1) a precutted ply representing this deck and 2) same strips of fair wood 3x1mm.
For the deck planking I have selected a pattern that will repeat every three stripes. At the end I leveled the deck with sandpaper. The colour of these stripes of wood, provided by the kit manufacturer, is really "random" . . I installed them without regarding to their colour and the result is not the maximum . .
01 Cross%20Section%20Santisima%20Trinidad/P1050541.jpg
y4mNGyexWDBLzIeiig7t5sPE_qyTrYCVY3ApBNl4vc1o138vTFojSxluel0KNdFnb79zCnC0Ab5qO1B-CVzdWQVEa4Kzm-P3aYLjX5Ec4VTJC4G7QVi6n3TxC3pcVIGG8kgxxw3tO1-9aKI0bOXLK81MFz2v7bf9qoP68m1SjPJkA76TNkEkU2bKJyiAg48dyNjFnJZhDQDApiTsMOo28fuQw
02 Cross%20Section%20Santisima%20Trinidad/P1050542.jpg
y4m4PKqEUKDHosKHlLwBl2v6RA41Mvl15ddQx5j2n2AtSgD-XBKCcfRTSqK3LYKCkV5GefSjBGqlBmE9GMjDtKfgCmIllVLh2bL0PN_5hbKm44oQRQNhecXvYAanwB0kBpBtq7erhpEkEtehxiq-RdkSkuc2U5f-2yG7kt1fR0DyfcJeZTE0kd_lVi1FiLT22XhxEhAn3Fh24mz9qN-2VyA8A
Before mounting the deck above the three beams already in place, i decided to reproduce a more realistic situation below the planking. The real things were not so simple as proposed by the kit.
The result of this "customization" can be seen here below . .
03 Cross%20Section%20Santisima%20Trinidad/P1050543.jpg
y4mMgZGb-uh76xIkwRY08XQWV9EISOs4A_JVr_XounWWcTov9okgCXml7yiGQ0YmkSDTp8EC6LWIU851CpCIyO_x5wwCShTL1nRGRPCrH9iH4UqbSfF6lWjExQkITXVI7-1shFuNDy_8zUEYBTfnjCMtOJODw43V2mR4QLjgLNl4r7ad7pi0xYLvlYoKhqAmuwNw0kFpxTglLP0MQI9c90wLg
04 Cross%20Section%20Santisima%20Trinidad/P1050544.jpg
y4mHQtluPR5_QPSHESNHCw7_v8XZrQNWyttYvQ1kElFkwJOeRQzuEgefh5THA_57I55nn3_RZUapKBMn0dKsDryQ5PjrV2utSksmNpLfRR9rIY_tKLXH6urR0RQ-w_Nm6tF4qwv5hX3LTDzG1D2rUIgZcyN8YG7pjtf0X3EMmAbfYRAWFC_XjqyaLLldmU1v320WqZr2mPL5J2AQ7ic2takgQ
On Monday 11th I have also definitely installed this deck in place . .
05 Cross%20Section%20Santisima%20Trinidad/P1050545.jpg
y4mGT15EdhpgofLCIRhhltKlg4-zbCgOBfWYyZxVmQuGL-yjfauwAtC7w6yzKCKjVKD1wvVpCthu1zLfHdMn3nRLpEFrRfyD1V1XuqgqDeZE3TX2JHNIlnfQnsTbb3leF-0ivFi0-TbYWxWPf4AGDRaVzQFQ0cj0vtPoBU1ZmEWN2Z0LlPa8Gr3-4LedVES42uaz2QKnbHVAKnEbn8WNOqzLg
Cheers. Jack.Aubrey
Monday May 11th, 2009
New additional images, with more details about the deck viewed from the bottom side. The colour difference is very evident, but I think that, later, there will be a lot of things (packages, barrel and something else) on this deck that will probably hide this problem, or, at least, will decrease its visual impact. Anyway, wood is wood and the nature plays its role also on the colour of the same wood . .
01 Cross%20Section%20Santisima%20Trinidad/P1050546.jpg
y4mIw5tMYCZHK-2aI2ufkftYScT6d9kYWLFhMUaf-Ikny2dcCE5z0YjEGhif7U1qwU57ywUJxIkkqWrIG3fYwwnVKjnOj45U4ocqiayPWMiMiqQiiSO9gUBcXxnl_9gnmiOPnBLb-rLJgerJPwthmuSLnhJ_yqmJsRdMQuseqeCuCVbBsBP_BBZY2BSNil7JE3IXTfC6n7rhFgC6qo_NOWIxA
What I like much is the work on the lower part of the deck, simulating more realistically the deck beams. These last four images show these little customizations . .
A view from the poop side . . .
02 Cross%20Section%20Santisima%20Trinidad/P1050547.jpg
y4mJSB_SSEw2qN2i-uZ6P641qTevHO_o_-R7n2T-Aj08wapcotrV4lXLW5HJHNEU9-wXIiUJvIubqv382Ait2JwRUP4eoc43DqNcp85YWOp5EkadO1OxsrgIxC1gWpvCXsthMW83RRQVYmwJP9MxMJ3A-2Hh7L1FiZAdAKADjw4-Q70KyXlYDINxB_DOyLzr88t-5jWXQKGbCK4NObuBEg6Ew
And from the bow side . . .
03 Cross%20Section%20Santisima%20Trinidad/P1050548.jpg
y4m6IzUOTvG_QC4fovjyZiL-_GJjumSMlTA2Pg4S1iS922FU1dXCap4vlbDmv2YTi-ihZcS8QWuJHnW_4Nbemc-DZUV52CtzvVQ1phPW9pjpzgs_4N44k_7kXs3MUS4TUe_mF6PO03NJMD8wh5VQPePSEBrF4Sx5Ili7v4iyFR_DStkMzU9uj_1V59gRjjfBbC_oSHUsHMM5C0Sb0rD4UmeqA
A partial attempt to take a macro . . .
04 Cross%20Section%20Santisima%20Trinidad/P1050549.jpg
y4mboQ3w0o-z5YEWkaYCyx7AEWwg3FAdWljX1E_jROi6IFjSC7x6Ygh7oArb5M2eit_kdX3_f0E3hzyuIX8xjyFWOO49XlZNCET0ism1zWMtPtG1OKPQ-Qd2cltPtIVpNJt3DvDzyOo0sdoGwK9QZsMAglpNtNXmio4MJOBc7-HWA1qlcdMIwjGffresRhY3Vh4mtvWgTRG3GEnDHsPHKCo1g
And last a more traditional view . . .
05 Cross%20Section%20Santisima%20Trinidad/P1050550.jpg
y4mYtAqpsS1WDiNQOa_R9YmAY523Po_3ARr4jkjZNmNMZGCDmdqU-IyUJn_lg8I8cjeYQbSxe6N_U_nawbq4uc_P2CYfEgLMH7PEcnJI-pRhrHwYD1FQFCdMUn8q1mh-QlsC8oXstyTOvGBTBO0q0e2d9pIw0ByXskp_NeDgmjRBceXno1egkxDcmM8OThLV_A8sveWx6R8C1NIdZT6GlTIkQ
That's all for today, now I will go further with the next deck. Cheers, Jack.Aubrey
Tuesday May 12th, 2009
As anticipated I started to work for the second deck . . more precisely the lower gun deck, where the thirty 36 pdr guns were located. At Traflagar these guns were thirty-four.
Here below the visual documentation of the work done: the planking of the internal side above the hold and the first two beams of the lower deck.
Is is also possible to notice that I have temporarily applied some reinforcements to the frames . . they are very weak and i am afraid to break them. I used the cyan acrilate glue that is easier to detach than other glues.
01 Cross%20Section%20Santisima%20Trinidad/P1050551.jpg
y4m_O_vXrcL3bOZWDfMfVMRj8PJAnYU9wU1jLXp0IG7ZSbPPLbjvTTYVYyHtTDnzJyOzAB1Rm1bhIQHLUMADWIuZJkBM9cEeEevpIecUgFyU8xho0hMFUJInRaEXWIoZVlOEl508z0kTch91oPnXB5-zHrRUqgDNK3Kczb9KRzjRhRfM6-nlYC0AB942P_Y46ggi4Qq45deUvkSHJdPjgrQSA
02 Cross%20Section%20Santisima%20Trinidad/P1050552.jpg
y4mgfpJYYlJB4CpwUEc9vrFb4wDnsZtBy3RJsPz7bNyhbGltsPxApKZJCtwnioEVJNI-u5ya2OjHl-IlI_lRBl_ZzAo8MTMDl62KaO56VXtWQ103OghtcxUV0Qq5Zmt66JAp8Bb4ZOHHqpv5LTBq39fbqMUH2WDIOr3dJVHhfIYWIVCGYKI2QDCNJET-b3pTPccgPuXQPnwlXQovJ32AsunJw
03 Cross%20Section%20Santisima%20Trinidad/P1050553.jpg
y4mCpl_acun7GVDQJJYiZTHGsKB2H7Wz6epXOPNkPq_1Zr5QCm62Q8O2qcRfxrVqD_uLjZbk5Tt3pDtkkwiaNrNhme7GwHDAf6HRPYTvcUTSFFdbT3AHcvPbtERa7Fi97UNaZ6ga5IRq6mZLX9TogdpMTGhjzC_J54o046YzNn_8eQP0mxuzaOxijDBWybs4ddHqMFc6RoqGQfrenwawubcQg
Again two new attempts of macros . . I decided to learn how to use the manual focusing, looking at the results . .
04 Cross%20Section%20Santisima%20Trinidad/P1050554.jpg
y4m4qq_IrZJfX0L5GnRL89HqrNwvhW61dceHzF2hz2btU6sQ7qqA73Qp9Wy4dOeVx0UXWH8uOd9ck3ZQAr1oFp7H4ROuUQccLkYTBNO1xGB1T5xV56mBB7kay4StuTZxglLzyHo_lTU0QgblRtw5NqxUcY60WAQriVjXsSpyRE6FBWDhTEIAz0idXPWVDTlJ_POd_tnxUi-hx1hNxLjnW9OIg
05 Cross%20Section%20Santisima%20Trinidad/P1050555.jpg
y4mvzBKc50Yb2-tETNeHhb3_7sh5-osdjGvzaj_WLIRbGoZuTbm-QeAyjgUdMn8V_FEcCBfnjNFqfbbeGrNGGhjKWztbM0Gy58M6qwmGDe6rYompWXZ0OO_mFDBtdpEQTAgFdrPmzY0BO8YJCPXsttw79TITiKgplGOUn6ZzdJuSJER-H6VQhydsf6oPA9Xs5EiCzBtlumtNWh3XndyEoY9lg
See you next time. Kind regards by Jack.Aubrey
Wednesday May 13th, 2009
Now that I have reached the level of the lower gun deck beams, in the internal side, I can proceed also on the external side by installing there the same 5x2mm mahogany stripes on each side.
But, instead of speaking about this work, very easy to do, this message is aimed to highlight to important points:
  • Again, the nice appearance of the wood after the application of the oil. in addition I have discovered another important added value by using it: in general, if you do not remove well the glue, the paint and also the oil finds difficult to locate its right way between the pores and you can easily see that the colour is different comparing to that of a clean area. But, and these are the good news, I discovered that after some days, this oil finds another way to soak the wood, below the surface of the glue, and the result is that the colour becomes equal everywhere.
01 Cross%20Section%20Santisima%20Trinidad/P1050556.jpg
y4mL4MFOa2ZZRjJKddScTYBZKLT8BP2sTH8jgJg-D6MzIuNiduuSnXsFI7hymsZhZ_8xHpPaR7738Px7lsZRQh4XJoaAncFtpkTodR-hNDqqaKZ5l2NN8X8VhYmCZaNBhZWEbPvoP7CYhhml-dJ3Pf76_BxL-aFhAR8lYX0TewQ1fpZGgTSHsK5y0oYJ-7RBDirzEcca_Xxt--bFC_EkdwVJg
02 Cross%20Section%20Santisima%20Trinidad/P1050557.jpg
y4mFjTNF_FQkiJmu4ed6DjF_1T1YqYBSNmHmt5aPJ2EHUKEH4h56jFdhedw-0St_GeTGCwIwoJ4PGU2y580kszOuoiIcr_zfbrfHuuPJtVZqI4HVAcX52IKEae5lAV6pD_JKv7dABPYmJ5BuYKeUMVoIVvxUbmxCZTHmWjaAzYEx7Y-w_1ogS8rn3A_btQmsJ9GhHaGP9pL-yPStZZCpP8RgA
03 Cross%20Section%20Santisima%20Trinidad/P1050558.jpg
y4mDW-sSTTdtZfDjmBhldYCBJcjjDV1D4NKI9OoiCcIzXwvEXJVni4NARcsBm4wVH_t2sT4ssT1J_veUp_JWppF4muRPGCBSXtmYqH4_iOv0XfEBMU8WlpTTlQZgCm4ovZk_bvth7O150G7X3hZeKr_p4leu8-og3iInPi5FgcWimbKMe4pJOvhEIHRq5EnRQ-2KXOqSk25FJGG_o2H3KDxow
04 Cross%20Section%20Santisima%20Trinidad/P1050559.jpg
y4mA353EcSlVGUsG4rFKgr0yaMegZaWUMwgtI217IQikQB677q_BDE7J6G6VyntaBj-9PUHHzHUzV4urDlX_G4Mg2UShDp1bBX0A7npSdd7lXvxp9Ipm06E9OK5a_JO8_5Q7fKu2ttKGB4eQT4vRLeKw9AOu7WE8pamA_ue7pea8bp34GKszeKYqqptvYrfm3cnyLqBixSOm_FOofjVxpLHXQ
  • The second point is that my basement must be rebuilt in a different way, If you look at the following image you will understand why. As result of applying the external planking, it is now too narrow and the hull cannot enter entirely in it . . I need to rebuild it with a different method, and I'm confident that my first experience will greatly help to achieve a good result.
05 Cross%20Section%20Santisima%20Trinidad/P1050560.jpg
y4m_vnuhESV8_uIw4kIevyPKfhG3VMC_tysJiUGTdW1Vjf84lOh0XXPuJMyaxnlwtlf5RMjMPrsICxSK0v6lLL0hgIvvfORaA0KW9Xvb8zK4dwlN41vgh2CPGWp8B9UB3G5EphuCD9nggMP7K1uZNJtUQkIMUSnxoiSePPfsKZ-cqjgRlxjrLG2v6fwVUgEjeEP5BNNkev-LCXWoMIXetKiuQ
See you next time. Kind regards, Jack.Aubrey
Wednesday June 3rd, 2009 - Lower gun deck
Today I started to work to build the lower gun deck. First I had to plank the preshaped ply with the supplied stripes of fair wood 3x1mm. And here rised the same problem: the different colour of these strips. This time I decided to concentrate the darker ones at the extremities of the deck in a symmetrical way. The following images show the result.
This problem is recurring with this kind of kits. The fact that pieces of the same wood are sent in different issues, instead of all together, exposes to the risk of great dissimilarities in colour and something else.
01 Cross%20Section%20Santisima%20Trinidad/P1050663.jpg
y4myPrPF_JXrsMXjwqX21pCXjSVgKcPeGJWXJlBCoQpsB1Z317jdMN-6Jd0h8E1j8MKWvSDIrByfqYPzNnQRkl9G7w_diI4xEbkeW9jLd2OUNxfZua8lnH48GmXILwAhfV-lsVB0SksgmwgCwGtmD5hRwQczTt0zDyVdSBLjsymDI7KM7-4OyD0aqZp0E6gBkp-CBAxlcbDsj7AwTWSRf_DYw
02 Cross%20Section%20Santisima%20Trinidad/P1050664.jpg
y4mzrLQVGpYjWU1DiaSqmzBm8WEdZm6YuJ5ErdETUuFYPMWbsvjuNG0IoycbBlUbhvGWuO7y9mcpFJ8ks9qtal2myHdxdtJ7MZ3S4nXFcLDlZ82925pkS-ZRVpcbJm6mLFx0udjgPk4yurbTLcYp0EQTF3wzkQzYFNTjzZ9ZUa6e-jpvb-XefhUdec1Z7ehJzoZXXtKUUVkoWkTMu1IRwuI6w
Again the "customization" of the lower side of the deck, same concept used for the hold. At the end of the planned work, about 6 hours divided in 3/4 sessions, I applied a coat of oil and let him to dry before continue.
03 Cross%20Section%20Santisima%20Trinidad/P1050665.jpg
y4mwYfdUwcMvGVh-tkJr0JBYWy09BiBrrRJPS8ZIyl39a0YUXP-44Yc1jCDqJ3UdvjrIOLAoqIpPXCvjDMnSvVGnxrNcaHZ2ZQOYRnLqoN4q63i2eTlm5K7uylqXoXvleUWF0Bn0uU6C88L-76-jg9GvvuKW69orFK3r9fTQXJCZ8-2DCFLAEcICgqbrdPx91yIdNhrw4MsYlDMe9NVwh2p_Q
04 Cross%20Section%20Santisima%20Trinidad/P1050666.jpg
y4mR59diBFCaOYsePkmQNRHn46FaGNspxWk9RSEjOwXHrf1W6YbwI_U9mO9XE9wIdsPueHbpmoKy1Rvsafj3DmyKZSCt2DZ30sogTGC7af9bGjBVFYBft14ARCP_SaHIFNy9LYyxg1B_XNocM4ptIzrU12R0Fkr0YLDjUDhgCgeOhXWXhWLLWeRF9o9ZTnG_Rvt-tM0j5jvt9dxDjSbB0lSHg
Next I built this kind of hanged loft, described in the building instructions. I don't know the nautical term. The image shows the piece much greater than reality.
05 Cross%20Section%20Santisima%20Trinidad/P1050675.jpg
y4mCk6zMOI4afx6PH0hQ6lBYZ14mX1ioJe2xXaGzwLfbn_OzQI0afIg-9hcg0Er0phmq_HFWcxkicQtgHeWF7Cr3TEbuDSdpupfUmzOSaIzfQcqc9M0awml4Qcz02YoOVaAb-YhhlSJOX8SDZscRHcD3OrE5M3gaQXTjbsZkNt30w5gWYS2ZBOG1BFQ0WTcFw_TBJwhXEJwjCfzXhdU_vWayg
In the next message I will describe with texture and images the new work done. Regards, Jack.Aubrey.
Friday June 5th, 2009
In a couple of short sessions I have prepared and painted the pillars that support the beams of the hold and the lower gun deck.
The first image here below completes the last one of the previous message, showing the "loft" in a capsized position.
01 Cross%20Section%20Santisima%20Trinidad/P1050676.jpg
y4mXO7YPb7kCHMb80hTgb_CTSWG8jgsdHfkh7_iiseIGpr50eyX0rzntwuWZkkyCKwYDpcwqdVRasCYJIk4mTrzsI7Az1QWqqwHgLIN6yOLLdi0oyoPLfQhTlFVqSCARe6BIwaBlAZNKus8IK52GPNRT1ExOXD2o6wQU0GZMlbtrHGbkfiCj-s_b4Ni91xtlQajg7QQ8LCEIgGs4I9PZ1K6Hw
Next four images show the gun deck installed in place and some views of the whole, painted pillars included.
02 Cross%20Section%20Santisima%20Trinidad/P1050668.jpg
y4mJ55kbsxmK23uDcTc5VvTeZQvV98mZk6pVsFmOuXJ3SVc7pHcbDdu6v-ay8HJtnDpjgT1Kuv7eBrt3jXOyXd-OC7dNdZog7ImAhsRHrirtln7oCUkqD5mqZhIM04GUYuwaDzw9M9HcFKPVSnzR2iGBwtuyT8w2OjpGcjpEKLX3rjvT93xeCJImb4z-6oOu6IMYWZXCrwwmiMoxPaPfVOQ5A
03 Cross%20Section%20Santisima%20Trinidad/P1050669.jpg
y4mcM5TkjEbVD2FvIqkX2BmjGAxYjoSSBbjmSqhTUS7ItynlZaIn1WRgXDbFjry-9y5ccgGnHN3ISsPuOlUt8Jx8G93TQbMie1msEdpQo85kyBZ9XuW7q_oItJ_txqX5ls9wenUebZ07OFPf1Aec3Pt5tfypyARHdY3MFoMz6dOpn1R79_9ywSN-C6-abSCSecQmfP0G_QhHSJmYXlxHepXTQ
To highlight the "admiralty" simulation of the beams visible below the decks.
04 Cross%20Section%20Santisima%20Trinidad/P1050670.jpg
y4mSjhVa_e6SFvwqIBqKnkShVB7sxJBc_a4SxXQ1hbnIdmrQTu9SAAtI8_zVuBpAJwaBHucUCx32vue_qkZUnxR0qpgvLgk-VAuV33OdaJS2KEk8VXpAbGktqYJVwuEd1dqLy-f1i2Re9Pj1xkAgE3TG3p0gl6RrxBYuIIV_RJcpfqsywTfKH6bgyfHLX585NAxg62jwJtDSSxq8vZzA3zA4w
Here below the pillars are not yet installed because I need first to install the "loft". Anyway they are ready.
05 Cross%20Section%20Santisima%20Trinidad/P1050671.jpg
y4mmOwtMfVSluMpCp1WvC0WMNbZMbFV6g7vLkZS6EiCYeE-SWXBJNX_giZHsg2kLxiKYCET-2t_v3KFi6M9B47Qjf2AVTFMeX0_qY_oOvcMFoWHsxlLu2esxquPeBD0zdaNhyWUcHN3qq1cdKqZUBLBdlm9e2DITAglkSuTh4La9PwsQZm1g0X-Ts4v0xN9E18fu9d2-HByQQ__ptgAzGDFXw
Wednesday June 10th, 2009
I spent some time to organize my next tasks about this model. I had to think about two main points:
  1. the new basement; I need to develop one type that will be usable until the end, stable and possibly to be held to a table when useful;
  2. the way to build the gun ports; I defined some solutions in the meantime, finally deciding for the choice I will describe soon, particularly different to the solution from building instructions provided by De Agostini.
Now lets discuss about the basement.
  • First I planked the external side until the first plank of the lower wale. This strip is of walnut of 4x4mm size.
  • Like its predecessor I used the same plywood, 8mm thickness and 10 cm wide.
  • I have calculated the right position of the lower wale on the real model and with these measures in mind I have done the vertical supports, applied at the proper position.
  • The section now enters perfectly in the base and the wale holds it.
  • Then, on the horizontal side of the base I have installed two strips to hold inside the keel, plus two locks to avoid the keel to move forward and backward.
  • Once inserted in this kind of cradle, the model doesn't move in any direction and, to extract, it is only necessary to lift it up.
Two views of the base from two different viewpoints, I apologize for the comments in italian language:
01 Cross%20Section%20Santisima%20Trinidad/P1050677.jpg
y4m7KrVmNYljZQNlhHWf0jZzxbVtNJYfNcR_koyUqIgCq0ne2pGPWGldLx7efzXAw6tQiZc16XaN5cMM2EvEXSpKzLT6N_Xwe1GcULMocx6MNXJEQTJA88yWxkOohhJQxpZzsLzKNkKSgwrciC-cFW2Z5QS9tZICU-Fets-89P70T8y84b5t3BZl9TYPzZYwcvGgLRiYKxyivMCQw6bLFrujA
02 Cross%20Section%20Santisima%20Trinidad/P1050678.jpg
y4mdJCW0VYpzmFJt_DyCcsS54PqpaiAyc0OA91luBRFq9YZCkYkTG9HR4kq9-oRHwDDBxGDyuhzQ5EGr3slZkM6Ok63gQPZf0Fsyirdf4m9QV97no7QR4lqJLIY_uGOHoY8aGLfLAEJ8x6vOHNGJZ3lwidZc9EHThk-cnBGa9ddktUT7lO2A7PpRWxnRe1cM2TR-dWVR8H0h1NeiWlyVJVhvw
Next two images show the model in the "cradle" and highlight how it rests inside it just below the wale.
03 Cross%20Section%20Santisima%20Trinidad/P1050679.jpg
y4mplJecZIzc7fPMK6Ha3cUN2CHpbgwXItE78PkFX3aYd8jyxJUTB97_K1ee0BanoFqnTv7JI8zRkJcqbcHrQyUjfcws8_sIxNfbKMjM3Y-JynN5T4bnzh6xpR3AFtpep6KUNjW9UehyXrxKJ1km2xNijDzTztMTa1CSUCKYVKN4uHkCYOu3FBpbrgI0QvpOMb0Cv9yyVfLqT3kYVHgNUU9_g
04 Cross%20Section%20Santisima%20Trinidad/P1050679b.jpg
y4mv96_4YsL9To7DFBYF1XV2jfKdnFi3XUbjkjJ6Z3jJCWNbVY8m7ZERh0W5LAtYpQWOljJmd7PFC4Fid9Ar4igNWy1cB0b2XNeFHvTRa8Hd9sGjL8uCC0IMwwzLcM_LnblJ-k8VNOl5ERavDdcJ5Mrx8nmMzfo3Fy5v9eSgSfidT4G9Ko7uN9pQ_9ltci4GH6qX2OKIFyP4r-Br_AZZpkGAw
Kind regards, Jack..
Thursday June 11th, 2009
With this message I want to go more in deep on explaining some pictures shown in the previous message.
First of all another image of the basement that shows the model inside it with all the relevant points of support well visible and highlighted.
01 Cross%20Section%20Santisima%20Trinidad/P1050680.jpg
y4m35YeQtSxpcEn1dyCjBlwbH0i20QmFdrjjgcvb2F3GruMhsHSHJzGRlp32_zQ2GC6oTWv2Xoi5UzegwwRU96g57JCtB2wpqMuMIwY_ow6dRCFpQBzaiCQc9Wm6WiMjbUyd-MCv4uDXvrfXDFnXMsT1V39HqQ1470r0aOftYDPSoDl91orqBw9amf3JRU8Mk_7TS3ZkRNe5bSrEr0bukrnGQ
And now let's show the solution selected for the gun ports.
There is an internal, not visible template, of the ports made with strips of 7 x 6mm. the frames are here 7 mm. so this template fills exactly inside them.
02 Cross%20Section%20Santisima%20Trinidad/P1050682.jpg
y4mREk2m3nY5NXe64JwieEXH63W3XQUso9HwqlclzNfW5CKPo5dv82N8KrGeDouuMo1JO1-kZlK9-P_QsiZwoKO-_-bZHhe6FlnZm5kJvyqJGFh4p1wQOAXJIpu7puCIdMJqJi2os3328gCzzDvz9FMEe1rhsnykB6i9EKOWfUwlsZWsBiu_b8IBxYiUZkqz-Ban3F7afML6BeDsoqq5tp8xw
Outside I have installed the planks (5x2), taking care to cut the gun ports in the right place in a way to leave only a small part of wood to remove with a file. This refinement is not yet done here.
03 Cross%20Section%20Santisima%20Trinidad/P1050681.jpg
y4mOQEBVuzKpKR52xDn9XrMnZNYu48z4nw42I4bP4qQ6SLntkoEhyAv2DDX13eL9q6jI5oum8SKZIDwYd4lq3qgGgUznQXYrZoEELA0XE3lLa8TSKED3y89JqPV9mSOVAEfE8eUd-gvK8KCd6u5oHKuB9bZPEudpTwK3uYtXNKZqSutOHcm5spsRwtH8Cg0pPROTxnRjRMDTkwfNwIGvNHF2w
Last I need to explain that all these pieces of wood will not be visible once the gun ports will be complete because ther is another layer of planks to install inside and outside.
I coloured them in red just to make a test. My intention is to paint the Nelson's chequer (I think it is named so) in red, as it seems they were during the Trafalgar campaign. I decided to use not a red paint but a red stain over fair strips.
The visible result is under your eyes: I like it very much and, although now it may seem too light, with the oil it becomes more listless. I made some test and this seems to happen every time. It is also important to use properly the glue, without leaving any of it exceeding . .
04 Cross%20Section%20Santisima%20Trinidad/P1050683.jpg
y4mH0NjteXrUwFS87O51VkovvNGE1KXVsmk4v4rAj-tGOptLAc23zhJqCrXZcPSGRnEEt55t6Bpw7rieBbGPLZGciSix56u4xO-WolEibv0IbXR9Sy9E1AyeC7HLV7rwmnu2kt5hA-4euvCqj4YO-_rHxKT8GpbgqFtaOvtxdtnUNAuciiKfwGM6s2_pAYT22uSVfKkH3VsYNhPkMG5CzkIag
05 Cross%20Section%20Santisima%20Trinidad/P1050684.jpg
y4mL9cLEG6IxF1s6_S6n7cdqqr1niybC_tvrkpCzU5RO3rc4oWZTTvG5423ZrUCxkB1KF3FQwlCPO358baoe0UrJWkKBvb68Jg56fHlKhG4QOTaNX3Yw4hBHW_qNPXvuPhGWSbMm7p4nY_3pMwOFbpQMVEK5bEaWdjyrVKeUXX3jE021upp-SSAYhYaNUcFJt_xUnQrJbob4VbhEqOn8y5BTw
Friday June 12th, 2009
After my last message I completed the planking of the external sides upwards, with red stained lime wood. Now the entire area is planked and it is now rigid and strong. I removed the preshaped upper deck and in its place I put two strips of 6x6 fixed with the cyan glue, that is easier to remove if necessary.
01 Cross%20Section%20Santisima%20Trinidad/P1050685.jpg
y4mNpA_rYy7bXZz_0j2fSJA0mP1L6HKqtt5lSYRsB75IsDh3sOaqqae_bJlH4rk0nyoRAJ_SUxB6EQ9-w61s8S24kPj2Uc91jFtH0F6pSz-Fn72UyqdwqLiO-bmQ1c9-gcT5N5S2Hu7ptUNylAdeu5b5pbOz6IE_mbq83dN9KB8wRheu78amtNq1x0tfnudOhk6EsuCqZoyuQS9SMb0mtDXIg
Now the first wale is complete: it is made with a total of three square walnut strips of 4x4
02 Cross%20Section%20Santisima%20Trinidad/P1050688.jpg
y4m7lMOBX7FWXSfHH_8_4KisgO4qWZ5NwbS4zB4LRyg-iwntEia8LvoyBh4R_UouvGQICN4F7yfjhexTXrM0cg2-TZYMMzORqE9Y_K1Mb8Cgvp_0lMqFXldUuGy4H8vVpVpNIanrAeL_XtzSw2ZDKcUs9RAsGBWNeN50g0XSfAnw6L-P2QkQ0rzcpn0z9feXjoZjU96qYgildAlda-e34K8aw
03 Cross%20Section%20Santisima%20Trinidad/P1050689.jpg
y4m-eBYmckzASd3DwW1TZVERmGu4jGrPQM6QjkxFpd1sQeWeiXzNuN2Pdan4ER_bE-PWGA6FWNjIMjlTxoy6yu1-jIlJ0HVqrKU8d3ysZLbVrj7f397u5pNc8ojrPyXtXA9eY5nb7NLySEm2xkRMb9j7xDdARmc8bVJkIA4sexsYqUoZZD8PQqAF5byg2oqbT4LA49Wbg3rFet36YyyufkxGg
I finally experienced that the red colour is not the right colour to take perfect photos. If there is not the right light and exposure all the shadows and many of the details disappear.
04 Cross%20Section%20Santisima%20Trinidad/P1050690.jpg
y4m6oRHKyYapNZo-X3eT1brjJ6qC-xk3wbJghu0msodEp3dSLuyiaIHxaSmZdGRSI80QcpZ9vFE-NtM2FX2JPXxvuLT_1mzHQ8j9M-7v5g5zZu1-VYqIKk8dRQo9DABKDiLy--OPGBOW1sx-jx1DfCah7BYQ2zmwTxYmLsNAPn_ngONMcviu93Sdz_ahveAJEaegrXx6GFpzCZuEihbDFJFGQ
Here below the "loft" definitely fixed in place.
05 Cross%20Section%20Santisima%20Trinidad/P1050691.jpg
y4mJ4zupHBYnfVsGYcrNFdsNRUMBZw3D896iEf8_dvLm3qm8d0Ge6OqmCc4SlWq2icqjT-CphfVFFEYEm7girMopU4N7kblTsy-dFUiy1RATl-8VNqPr_ef7u6Owkk0YdoA_rCmz9bGdpj3USh0wb4MIJ1ncSCqreX18W1YIecJUjvsGRkkRoJA8NATpxOayPQNFLcIY480pycER1-qFrcd8w
Last two images of this sequence . . .
06 Cross%20Section%20Santisima%20Trinidad/P1050687-1.jpg
y4mZmEgprW93k_3rLal5kxFCZCIaT6Wj5gDjAPoswGxnvjcjH81wcCq5idqmzlzJxTyqKhdMUQthHkQHiKDyFDFvHYKhRJCOFSyxbrVkA-QSh5Jp94tvKmFeGyDf_7IxJtRbYk-6Sr3-QiMQZaZFyssIytZK7ZB5eqqvC2uQqV4aHxYLEKuBpO6L0RDg8ScOmg1fgjWfl8jE_baiEshryf96Q
07 Cross%20Section%20Santisima%20Trinidad/P1050686-1.jpg
y4mAgGhkwxzhF8NFJC2SGquXTvePCtGHNnnaRy4pr__BfuLKsFyB_60sAoPGBMo3dABnLrdW2aLzsW4LLMSv0gi0Sd_NhCbZvw98aI_7Ebb4oeZ7xwufoqkrIzFdyLr9HAG-zvEzp48_PMjwYubHK5goHFO9q5KAejkB43efZLZzasJJSX6elrS7UflxVNLrgjQgRDOiQ60oHDZuN1zbi295Q
Wednesday June 17th, 2009
During the five days past from my last message I was able to finish the external and the internal planking at the level just above the lower gun deck.
Is is not a great step from a quantitative point of view but it was for me an interesting and very practical experience as I was able to understand that this method should be the right way to proceed for the gunports opening and, later, also for the gunport lids.
Again I used lime wood strips, coloured with red stain before installing them. I like the result. It is a work that requires a lot of patience, working with small pieces of wood that must be prepared in the right shape and dimension before installing them.
Here a close-up view of the zone described before, from the outside . . .
01 Cross%20Section%20Santisima%20Trinidad/P1050702.jpg
y4mjVa94odCNsDT-_-4sm9kXACka4xzwiFHPrG1NblHq5VjRSUV5feFLMdxcnmKuowErUJ4kMHNL7dN584D95qmNdADX72_WSitOnpFxuT7NfGlu4q7aPwx4dR1-OhEq6g_gioABy1B_M1wHI3eV3ugoJFpU4QMowkj0i_VR0dwKusUY8cvuTI3xHc4ayzJDqRVTre_8aPW_may5lRP2UdT7Q
02 Cross%20Section%20Santisima%20Trinidad/P1050704.jpg
y4m6RASbpaAuDHLYPp0VW2X2ENQik6YCi96yWLx8a_oqIzr23gWwPDupVZX9UasplXE3LkaW3K5-cYu9Ct0sBNxzT6J6runPUgvAr46Brt58acyH7vfjEahpsJKw6gs6T8pb2c_FdbqIExDpjxnFP_V0x7gAopFuCZbgXCq0UsmxwFdcOiQ3wbZvlVXmf_1S4cE26JDnqPmINxFhdADgkJPLg
Here, instead, it is possible to evaluate the internal side . . .
03 Cross%20Section%20Santisima%20Trinidad/P1050703.jpg
y4m_zWkB6OsH7w9AOoc7rB6zMvWsewjQvfEwMU2SX-U5xkoq0_cOUj_TzhBkkELJElFkrB9EKYXZxV8-6zK_UPrurmIu3RsvrKTXJwNhOvevYm8F8eiFpIZoD894QOcar_8jyoVdKmzFSi-urVKKCamLFaTEVBhvWo9c-i5aRP_SkHZNSi4gPEWcPwuUd_7CaErUBWgO6exMeO9o2871OM1uA
And here below, a couple of overall views . . .
04 Cross%20Section%20Santisima%20Trinidad/P1050705.jpg
y4mS2j-ZJlY_qKAvfoql-OziwZF8AmH4BhYiO9xOIbcElbajtB7kHnby_eAgkyqwepzrpAmSyTVkQi5CeDe55-K1vgT6GvYkrYolQnUMPpWBB0EH-yKSuvqV7api0vHys1RqkixZ9oUgew7H4vxFJCD5UQJdTK7vONosKXOa10Ti8ezjcYB_OoF_DBLkL4vSRdrhOSIJM54VwpoIPMx13GKtg
05 Cross%20Section%20Santisima%20Trinidad/P1050707.jpg
y4mrzhn9ywFI4IE6qv4zwdo3yb5P3lls7xDvVzVFEJaime0WyEO9YejkfGbOi2MH5ey7RLpRPk96cilsrmTQD0UAvqwpRXZ0fKyduguMCamtWi8M8qQoIhzlh7tjsMkOBj65BtxqqsoPrtvx4P3A7vMsWcWfcYmTYZpbDeKWkhG7sAsOlPMLQnvg6ZXh9peGSifFg81h_AnffmG01-rsxixYQ
Kind regards from Jack.Aubrey
Additional details of the gun ports, belonging to the same time of the images of my previous message.
01 Cross%20Section%20Santisima%20Trinidad/P1050711.jpg
y4mRfyJdVX8wSBLwyX1b_QQyaGtOfPPzQcTtnVpbe7hG-6nqn4ah7mPXmzgSLdMhYNT6_-3LnGzpVKB6621yfZc2hKw4Yg12YDZS5iJGyd6XiVbezrNXygQSQkVgOMVdkEtk9Qlvi2GmeCTG_Tp6iFM5MJo_dY6x7-vfS_EiNVe0qMvh_vF0uccmRE1nzhCfYFHoueRVzWlwzQvkm-AFWbweg
02 Cross%20Section%20Santisima%20Trinidad/P1050712.jpg
y4msGKkKcTUQN3cMWhtJrB4PvuqnB3RE8dg0F0VkHILpDAdLjDB-36LcUxJAzFUus9zckp43eBeBr_F_35l9Xxsek-LVdEy7L7dVWEA_QpoKA89OLxWhevqhRT2OilEfrRY-b9SaUJoaoEZGfXhGI3hjqIuMhG8votMGbuo1hW4gwNdNNO6DxnWTOjGFGJx1iOdv9kI0LULRateAxuo4hF5Dg
03 Cross%20Section%20Santisima%20Trinidad/P1050714.jpg
y4mofAICtmuNcBIRRStg3ps8xZbiWWP6CEBJSEFHzJmLs3Jw0DDHPalN45FoJIiAq4wc7l4u-Yfsc-hKbfDUOpRn0bihqJEa2C84HIbAh8Pqs4ryb-Xb9AAuv2PD9FAMItP5J7fTgjVLJcSfFmbIry1i_7jRnrYrYyuXZ54q4OyvVMoialgAjQwN2aOXx35TDyQOaktozmBhYlu9udn_AXqxw
04 Cross%20Section%20Santisima%20Trinidad/P1050708.jpg
y4msE8yQErNc2PpyNYuoSRgeCWXvYdpBJWsqrSNyQV8qHluh-we8aJ-_hshbsgddQdhBVNq7A52NKfv5DeRU5qCHLg1xDwVAl2_Uf_0v-f08C4kus0jufXS3XJz6HGMbeSgKuaSK6Ps9RHWVFyxORY1XajKNATR18v7qh580th5tRMbKcNfeFG0KHPrTrmv2PhYYZ-hdlN_avn9Zp4EwGP6wg
05 Cross%20Section%20Santisima%20Trinidad/P1050709.jpg
y4m-5mPJrCrm9X_hd5nI7_Q--u9P_KL1B-5h1g50jIbE7Pv54-WfRawMQ8d0fjxVu_mUzadcGLSwJou3ABAHoCPaIY5b8KgnnMwQMWWw0sSyXxVWb-nr9ar02hsjpssbni1PCGwmDoue3XNXZWv2U92zPV030YFgxIJy28Wx8p3IY4j_dJlMo65o70OxBzVPEKptck-K67gC_XNQNK1zDXrng
That's all for now, I spent a couple of days at the computer to work on some plans for another model I think to start as soon as this cross section will be finished. Cheers. Jack.Aubrey
Saturday June 27th
Ten days are now past since my previous message showing the progresses made on this cross section. Now De Agostini's instructions suggest to continue with the installation of the middle gun deck, and so on. But in this way it becomes evident that it will be very difficult to install later the guns.
More specifically this approch makes totally impossible to install fully rigged guns as it is in my mind !!!
For this reason I decided to start a new task, not difficult to achieve but time consuming and boring: the installation of the 36 pounders guns in number of four.
The simplest task was to paint che gun barrells with a gun metal enamel. In fact these guns, on the real ship, were iron cast, not brass. Then I painted the trucks in red with the wheels in brown. I modified the trucks to install the ringbolts for the blocks.
The boring task was to prepare the single pieces to rig the whole. I use the smallest block available on the market (2mm, one way) joint to a ringbolt that will be fixed on the truck or on the deck and the internal sides of the hull. To correctly mount four guns you need 24 of these objects: each gun uses six of them, 3 on the truck and 3 on the deck and the bulwark.
Here below you can see the four 36pdr guns, ready to be fixed in place on the lower gun deck. Unfortunately the trucks are metal cast and I don't like them too much. I thought to change them with the same but made with wood but I decided to postpone this idea to the guns that will be fully visible, and this will happen only on the last deck.
01 Cross%20Section%20Santisima%20Trinidad/P1050715B.jpg
y4mq2DRf5B_HD6l_oKH9oYPG35sxSJHcaEOA5l4tinhlvvgi1TOM0YMdRzFo3BLpNlnQrc3ndC2o5fD-CSeCDTzjG4IuVoeX3xuE_mT1m4buWEH5ZcWiWtzcMQob5HJwk6lklLRwk_G_pv2i7wwFc84KNKRZyqZmzX-jM-sow3ZdadDC2UeSuzDLIc4Ts6g-cAx1H24wOCSp2DpXBVRLfq4VQ
02 Cross%20Section%20Santisima%20Trinidad/P1050716B.jpg
y4mM3jA9E4T1c7uHNbSp5E93IYIDd3N6_oN40JF3qnVlPEeJ2eetTrH6FGLIku8a3FJeHXl5p7_CtWdZI9pcvheWPnHei_T4eqFOqTj52wSZbkXtAGgbN76KsGafzZmOe_DfudmMdYJTyK2WnImLqVvZ3ZwFd_-sHdhc2Sdu-objS5xnlcXQ80klQDheyGffAhTpXwLtvOK2GuZPRsjA4AJjw
03 Cross%20Section%20Santisima%20Trinidad/P1050717.jpg
y4meWJdZuTQUsqHJY-EQSe9ZYt6sKM518pySUwUAXs5LwKY2r2ghX_DJ6bnS4cIO8Nm7_aGjBIv5fBgVLdls3TPnZ49twPDWYJkuEnV4S7fsjt8w4b0oo8yfqh4ZgasLRDty3BBAny7G1Q-njiStqdgLnqSo-7enKUDVQaMU7aCGjyuMCqfTIeDsPnv6sSM7S2yH8FKMBuTiWEO3vOZht68mA
Here below a test to see the guns positioned in place, just to see the visual effect. The work is still continuing, not too fast anyway.
04 Cross%20Section%20Santisima%20Trinidad/P1050718.jpg
y4mo6N25_QgIem6DRddfWunIJgLRGA6vjB73m_KiKBoHTH4YnBmwBRSLWqew_MNTY4Ek9iUjCcE_2gJ09C2SXwPoznOt93B-UVzhxZX43Mu1O-hZMtIQg71R8cPmbz7RCwH8gkOBi3rOLzdbbO_L5SOK76IukPD9OGCt0HcCWcB5I8uHIZEODp6YS-UTE-Rg_-hIXV0Sjl8hnHcM4CEuySVVg
05 Cross%20Section%20Santisima%20Trinidad/P1050720.jpg
y4m65mai93ARqRb10NHiwniWzmM8cinLDDJJz6pH9r_lg5yIFYd31VmZ5vdd4Xj85fnieI6vrofMYswUHCZXn5Glzg6qSDz5lys4rzLqC0tej0NJBg0kIg_PgSALQwL4tsaIymgueBwPYw2D7L6rqPje0JjGfC_C7IUc1Tm-pq4PXl3jxTnp5iM82DQ344y0LxSqmca_FyPjLhkCr8eZtVRHg
Cheers. Jack.Aubrey
Saturday July 4th, 2009
Today I started the installation of the four guns on the lower gun deck. At the end of the session I was able to install, partially, only two of them,
The following three images show the work done. It's a task thar requires a lot of patience and time. They are close to be finished, the only element still missing is the recoil rope. It is not a big job but I need some time to relax myself before next session . .
Cheers, Jack.Aubrey
01 Cross%20Section%20Santisima%20Trinidad/P1050728C.jpg
y4mmnyABQL02ThepCciRz4ql5TGsiRazGOC2UAkeGhL9BoOmx3xsU2x8vqj5cF8suN-lh9kfOz8QATCZQA2L1P6UUoKbiXEId5vyLio3QXT_OWQfROAcQtZ6jgdQQzBeg1JF8mnTuX-xwfZl7CICBkp6FUCTnTx_nbo_uRzfANxrrTA2akxa8SRvbpoSy0JJxv7tZA5ACua99gkOSbo8PnQew
02 Cross%20Section%20Santisima%20Trinidad/P1050729C.jpg
y4mR8QkNmHRO48aTJiyXVLLd8zuPkiv0TV4DEvdCkdCKhqp3ZRVm6Gu5sTpHZG8g7L_SvrKXuTIHWAZxIxCn5jM7he7O6WJ6vEcTgSzjX5ToMnNuMJqcxp4yvpn89mtglbnHBD1VheIL6VdbPu0OsRC1SmoyrA-GQG5T_-RQxACCr7RoHxSpGCoV2e0jX7WWdlad1PhV2PKX-_Ax0U2ptPdNw
03 Cross%20Section%20Santisima%20Trinidad/P1050730C.jpg
y4mJced5Vly9qoAsLLU17tXsjMnECkP2l07XN-P6jujlL5lk8dSdAZIKFbV-XTm_P2z79vMsf3ioDjN3xYyTzlHlPKiqGQ4x7I3PzWfILArFUpEXX-oAiQVhVgFFwCa8msgTp8vt27EDVu3sWSCgr48_-FwZliQAwYgsCB7PeoEDn7cunK9sCg3xjoCkDrrACv6QFeYNXLgfL0Fs0T3gFHGtg
