Zoly,
Nicely done.
Great joinery, Zoly! I’m envious!![]()
thank you guys!!
Zoly,
Nicely done.
The margin planks not glued in yet,I need to figure out how to use black silicon for caulking.Yes deck planks will be teak tooHey Zoly, where you use any 'blackened' on scarf joints? The deck will be also from teak timber?
...why not use black paper instead? In your scale, it will look great (IMHO)The margin planks not glued in yet, I need to figure out how to use black silicon for caulking. Yes deck planks will be teak too
I seen some videos using paper ,looks painful,also can’t find the silicon method...why not use black paper instead? In your scale, it will look great (IMHO)
I cannot find any silicon methods on Russian Forums as well... Still lookingI seen some videos using paper ,looks painful,also can’t find the silicon method
That is some serious wood jointing Zolly.My interpretation(which maybe wrong) is that the scarphs are to reduce failure due to keel hogging.As the vessels keel can deflect this causes tension/compression on the deck structure which in turn puts planking fixings under sheer forces.This helps stiffen the structure and prevents failure of the fixings.This is quite common with English practice as you do not have binding strakes in the deck structure like ships from France.
Kind Regards
Nigel
Hello folks...why not use black paper instead? In your scale, it will look great (IMHO)
Yay!!!!!!Hello folks
So I did a trial using black paper for caulking on the deck planking and came out pretty good,the second image shows watered deck planks to bring out the real colors.
Thanks Nigel,I will experiment more with this method!The black paper route looks good Zolly.I have done this before using black tissue paper.The important thing is to ensure the paper is well impregnated with glue to avoid it dragging or furring when you scrape or sand the deck
Kind Regards
Nigel
Thanks Uwe!I like also using paper to imitate caulking - The positive thing is the fact, that both, the deck planks and also the paper are out of wood, so with using a good wooden glue, you can sand the surface easily -
Looking very good in my opinion![]()
