1/48 scale Launch, plank on frame, by neptune
neptune
Well-Known Member
Australia.
#1
I bought two of these small boats awhile ago, this one is a 30 foot
launch at 1/48 scale and the other is a 1/48 scale cutter, these are the
sellers photo's of the finished boat and the instruction sheets, Cost of
the boats was approx AUD 34 including post for each one,
neptune
Well-Known Member
Australia.
#2
This is the base of the building jig, you pop out the two side pieces and glue them to the base, see next pic,
The two sides glued in place,
This is the top of the jig,
The top glued in place, also shows the keel lying through teh middle just to see what it fits like,
Next up i went to get the frames, and that is when I noticed that they had given me two sets of the same frames,
so I have had to send them a request to send me another set of frames so i can continue,
This shows the three parts that make up the stem stern and keel, note the two tabs on the bottom of the keel locate into two holes in the jog base,
To be continued,
Peglegreg
Well-Known Member
Moderator
Blandford Group Build
Central Coast NSW
#4
Good, that you started the building log of these small beauties......so I know how to do it, when I have to make mine for the La Salamandre.
I will follow with big interest (and hope, that the spares are delivered asap....)
G'day Uwe
If you follow John in his build, you can't go wrong. John has a vast knowledge in this hobby and he is always there to pass on his experiences.
This I'm sure you would already know.
Happymodeling to all
Greg
neptune
Well-Known Member
Australia.
#6
I decided to build the launch as far as I can, then I will have to wait for the other frames, good news is that the seller on ebay has said he will send the missing frames, this pic shows the stem and stern posts on both the Launch and the cutter after gluing, I like to put a bit of paper over both sides of the joins when I use PVA glue as this helps keep them together,
The assemblies after removing the paper,
close up of one of the stern posts with my finger to show how small these parts are,
The keel section for the launch sitting in the jig,
This part goes on either side of the stem,
Glued in place, with the other part waiting to be glued,
neptune
Well-Known Member
Australia.
#7
Transom attached
keel with transom attached in the jig
The first seven aft frames in place, every thing is cut so clean and precisely, the parts just drop into place,
another view,
and looking down on top of the frames,
view along the jig, the grating is just sitting there and is not yet glued,
This just shows how evry thing goes together, this now is as far as i can go with the launch untill I receive the missing frames,
neptune
Well-Known Member
Australia.
#8
The jig for the cutter
Stern post stem and keel assembly in the jig
approx half of the frames in place,
view along the bottom of the jig,
all the frames in place except for the forward cant frames,
another view
The transom, gratings and stern assembly in place,
neptune
Well-Known Member
Australia.
#12
One side of the floor boards fitted, they are just glued onto the ribs below,
All the floorboards now fitted and you can see one half of the capping rail waiting to be attached,
Both sides of the capping rails attached and I have put some paper weights on top while they are drying,
Two views of the capping rails,
neptune
Well-Known Member
Australia.
#14
The seats now fitted, I still have the cant frames to fit at the bow,
they do not provide one in the kit, but I fitted a support beam under the five main seats for surport,
and then I fitted the forward cant frames,
another view,
These little suckers go on the inside edge of the stem, they are for the planks to land on at the bow,
very fine and tiny, next job will be the planking, fingers crossed,
neptune
Well-Known Member
Australia.
#20
So now its on with the planking, this is the first plank,
Two planks attached,
another view,
Three planks,
and now four, they are going on ok, but do take a little bit of manipulating, to get them right,
another view and thats it for tonight, I will let every thing set and settle over night,
