Latina 1/65 Carabela Santa Maria build log
zoly99sask
Well-Known Member
Administrative
Moderator
#3
I have the Mantua version Santa Maria under construction,check my signature for the build log,I am also looking forward to see your version.
epicdoom
Well-Known Member
Baltimore, Maryland USA
#4
I saw that build I love the Mantua and Mamoli ships so I cant wait to see your build complete after looking at your kit and mine I wish I had bought the Mantua kit. I got the Latina very cheap so figured I'd have at it.
zoly99sask
Well-Known Member
Administrative
Moderator
#5
Thanks ,but I made a lot of modifications and used different woods to build her,basicly almost scratch,I have ditched most of the kit content,especially the cheap and ugly plywood parts.The Mantua kit larger than the AL kit.
epicdoom
Well-Known Member
#6
ahh I have a love for those brands I built the Thermophile a couple years ago and it was one of the best ships I have ever built. Ive also built the Golden Hind and Flying Cloud. I speak Italian so I understand the kits easily. I know some folks hate them though because they can be hard to follow. Was the wood not good in your kit? I have fould them to be fairly nice for materials with the ships I built.
epicdoom
Well-Known Member
#7
Progress So far got the frame built, Trued and Faired For once I didn't have to lock the main frame into a jig to hold it straight while I installed Bulkheads It was true and remained true throughout the process. 20180810_163547.jpg 20180810_163703.jpg
Used a Pencil to edge color the thin plank strips this is the easiest way I have found to do it. 20180811_133129.jpg
Planking complete and sanded smooth. All Butt joints penciled in. 20180812_101836.jpg
Here is how I like to do this step once the lines are drawn on I go back and cut the lines with a sharp #11 blade The cut is only half way through the strip 20180812_101903.jpg
Next I take a mechanical pencil and go back over the cuts so it gets down into the cut 20180812_101915.jpg
Now I re sand till the lines blend with the caulk lines between planking 20180812_102147.jpg
Got one side done minus sanding and my favorite little buddy came over he wanted to help so I let him sand the completed Bulwark while I worked on the other side getting it planked 20180812_122256.jpg 20180812_141807.jpg 20180812_141818.jpg
Should get the deck clear coated and Bulwarks installed and get the planking of the hull started tomorrow.
epicdoom
Well-Known Member
#10
Nice planking there,but you have a good helper thou ;):)
Thank you Brother. I'm happy he isn't the type that wants to sit and watch, he's a doer for sure. He learns fast and at times seems to understand better then most adults I talk to almost like he is an old soul and lived many lives prior. He just knows stuff he shouldn't at 4 Years old and he takes to things very naturally.
or is it epicdoom by himself sanding ...... ;)
Good to see that you have already follower in your hobby :cool:
LOL now that made my day a bit brighter
He loves doing anything I'm doing. We fish a lot together and I cant wait to get him out hunting with me. Teach them young to put in work for the rewards is how I plan to bring him up, no participation trophies.
epicdoom
Well-Known Member
#11
More Progress on the Build I have the Primary planking done, now lots of sanding and smoothing to prep for the second planking
Bulwarks installed and some more decking 20180813_202000.jpg 20180813_202040.jpg
Planking going on 20180813_202136.jpg 20180814_201011.jpg 20180815_171849.jpg
Planking was fairly uneventful no surprises and went down easy. I do hate the tiny brass nails they bend so easily. Next up is to sand everything smooth and even get the second planking down and remove planking material from the Keel area to fit the Keel on. I use a dremel with a cut off blade for that taking my time so the Keel fits the groove nice a with a slight snug fit. I usually epoxy the Keel on with pins I make from the remaining nails. Ill show that Process when I get to it. The nails give extra purchase for the epoxy to hold onto.
epicdoom
Well-Known Member
#13
Very neat planking, you are building this quickly,
Cheers Andy
Thank you, I have a few years building under my belt. I try to get the planking as clean as possible it makes for a lot less work sanding. I do the best I can with it but Planking is my least favorite thing to do on a ship. I like doing the frame work for Plank on frame kits and rigging most of all
epicdoom
Well-Known Member
#15
Most of modelers hate the rigging works - so you are a lucky guy :cool:
BTW: very good work -> looking forward to see your work on the second planking
Thank You for the complement. I like difficult and I don't know why, I just do. I work smart when I can, but that's not always an option. I love ships with a ton of rigging. Provided I get decent instructions and can find enough Pictures and Info on the rigging. I don't really find that job to difficult, but I also work with hundred + wire bundles in the some of the equipment I work on so I guess I'm just used to spaghetti.
I sanded everything even and now I just have to do some fill work and sand it smooth, then prep for second planking should happen later today if the Grandson manages to fall asleep early enough. I try to wear him out when he comes for an overnight, but he usually ends up wearing my old Butt out first.
epicdoom
Well-Known Member
#16
Hull smoothed low spots filled and second planking going down, second planking complete and Smoothed and Keel installed 20180817_102439.jpg 20180817_133035.jpg 20180819_164521.jpg 20180820_043540.jpg
Worked on the stern got it second planked smoothed and ready for Rudder 20180820_043609.jpg
trim installed on main deck, some inner rail work done Needs cleaned up. Still needs trim on second deck edge 20180820_175621.jpg
Rub Rails installed trimmed out stern installed Rudder and ports and window frames needs cleaned up and then ready to clear coat 20180820_185302.jpg 20180820_185335.jpg 20180821_135642.jpg
Got a lot of clean up to do before I move on to the next parts. I try and keep all glue cleaned up as I go but I get antsy to get more done so now it will be a few hours of cleaning up glue and prepping for more fun.
epicdoom
Well-Known Member
#18
Not sure what happened to some of my progress pictures I just know I don't have them in my phone, But here is what I do have and I'm and now ready to work on the Masts getting them tapered, rigged and Installed is my next step.
I like to Pin all rails and anything else that will have tension from rigging lines so I take the extra step to drill and pin the uprights down onto the deck
20180822_203618.jpg 20180822_203706.jpg 20180822_223550.jpg 20180822_223544.jpg 20180825_204535.jpg 20180825_204543.jpg 20180825_221845.jpg 20180825_221914.jpg 20180825_221924.jpg 20180825_221822.jpg 20180825_204617.jpg 20180825_221811.jpg
zoly99sask
Well-Known Member
Administrative
Moderator
#19
How do you taper the masts,I had fun with an electric drill ,tucked into it and vrapped sandpaper arround the mast.
Aginvicta
Well-Known Member
Moira N.I.
#20
You are making good progress, the finish is very neat and tidy. I always have problems making Masts and Spars so I'll be interested to see how you go about making them,
Cheers Andy
