USS Constitution "Old Ironsides " 1:93 Scale Mamoli
Aussie048
Active Member
Melbourne Australia
#1
I bought the kit on the ‎26 ‎May ‎2014
I started the build of the of the Mamoli USS Constitution about around June of 2015 :D
The Mamoli USS Constitution's are in multiple languages including English but the :angry-banghead: parts list is not unfortunately.
Cheers
Geoff
Aussie048
Active Member
Melbourne Australia
#3
Thanks Graham
The kit is pretty good but I may scratch build gun carriages as they are metal and also few other parts.
Mamoli was burnt down a year or two ago but Daniel Dusek has bought the rights and wish him well.
Cheers
Geoff
GaryM
Well-Known Member
Citrus Heights, California
#4
So with him buying the rights, will he be replacing parts and making their rigging line? What is the name of the company he will be selling them under. I like his 0.4 mm line and would like to get some more.
Aussie048
Active Member
Melbourne Australia
#5
Gary
I think you should go to Dusek and ask the question about the Mamoli rigging line.
There is a contact page on there website with an email address
http://www.dusekshipkits.com/home
Also google mamoli rigging line
Try this website http://www.historicships.com/Rigging/Rigging%20Menu.htm
I hope this will help. I wish you luck. I only found out about this at the end of May
Cheers
Geoff
Aussie048
Active Member
Melbourne Australia
#6
The length is 973 mm and height is 667 mm.
I hope it is not to large as I would love to see another Mamoli USS Constitution build log done. :D
I know of one partial build log done.
When I was looking at buying the kit, one of my friends said to get something good that you can really get your teeth into.
I got it off Model Expo eBay website at auction for under half the normal price and landed in Australia.
Cheers
Geoff
Aussie048
Active Member
Melbourne Australia
#7
The firsts step was to cut out the bulkheads and the false keel and glue the false keel together
The next step was to build a keel clamp with bow and stern posts to hold the Connie square. I think I can improve on the keel clamp on my next build by using 2020 aluminium extrusion with t Slots on the board and then started to dry fit the bulkheads. I did have problems with the bow with a warp to one side that I had sorted out.
I proceeded with the dry fitting of the false keel. The cut outs in the false keel was about 0.5 mm wither than the thickness of the bulkheads, so I was advised to put a packer in and then dry fitted the bulkheads again and measured the height of the bulkhead with a waterline marker to make sure that the port side matched the starboard side.
Aussie048
Active Member
Melbourne Australia
#8
After dry fitting the bulkheads it was time to glue them in. I was not happy with one of the bulkhead alignments so I got out the Isocol and softened the PVA glue and pulled it out, cleaned it up and refitted the bulkhead and continued on. The use of aluminium angle helped square the bulkheads to the false keel. I have always like to show how I go about making pieces just in case there is a better way of doing thing. This will help me and maybe other builders. P1010028D.jpg P1010029D.jpg P1010031D.jpg P1010033D.jpg
Aussie048
Active Member
Melbourne Australia
#11
Know that I was happy with the alignment of the bulkhead it was time to fix the main rails in place and start on the fitting the lower deck. I did recheck the height of the bulkheads after the main rails were fitted P1010035D.jpg P1010036D.jpg P1010038D.jpg P1010039D.jpg
GeeJay
New Member
Staffordshire England
#12
Hi Geoff, That looks like a very versatile work bench you have there. Old Ironsides is coming along fine, I'll look out for the planking see how you get on with it, i'm just starting to plank the vic now.
Cheers
Graham.
Aussie048
Active Member
Melbourne Australia
#16
Seadog
I made it myself out of white melamine and two pine strips down the centre. The pine loosens up after a while, so a hardwood could be better or some 2020 aluminium extrusion with tee slots. Check that out on eBay.
I am thinking on what do do so I can make a gantry, maybe waterline maker better, but have not worked it through yet
Cheers
Geoff
Sgtmik
Active Member
Las Vegas, NV
#17
Hi Geoff,
I have a constructo version of the USS Constitution . I haven't started it yet I want to hone my skills before I give her a go. Nice looking project. :handgestures-thumbup: :music-rockout: :handgestures-salute:
