Best bronze paint?
Have a couple of prop struts and rudder support on my Pilar scratch build that I had 3D printed. Now I need to choose a realistic bronze color paint for them.
Been trying to research but I'm seeing a wide variance in shades.
Any advice ? Not looking for a weathered or bright finish.
Dave
I hope someone has a great answer. Did you try printing them in bronze colored resin? I would love to see photos of samples made it to see how it looks.
Thanks
This is the color I think would look good. Of course it's a real bronze strut.
Thanks
Allen, did you mean pictures of the 3D parts before or after they're painted?
Modern Masters makes a line of water base acrylic paints that contain the actual metal.
Copper or darkened bronze may be it for you. There is a primer that is a protective barrier.
The cost for even 6 oz might not work for such a small job
There is a good chance that shellac would work as a primer.
A search on Amazon for bronze paint may turn up something
or
Blick Artists' Acrylic - Iridescent Bronze, 2 oz tube $11
Is there really such a thing as a "realistic" bronze color? Just do an online search for bronze patina images and you will see colors from bright brassy to deep coppery to brown to green. It all depends on what stage in the part's life and what elements it has been exposed to that you want to try to represent. You probably won't go wrong with most any color (other than fire engine red or hot pink, obviously). ROTF
It's uncanny, If that sculpture is made by that resin, then I'm totally convinced and would use it. All it would need is a little noise or imperfections on the surface.
While no expert by any means, I do know that using different resins will result in different textures.
Yesterday I was able to obtain a small sample of marine grade bronze. After I clean it up it will be much easier to match it to the correct paint color.
Good point! Since my build will represent the craft as new from the shipyard, I'll use the cleaned piece of marine grade bronze color as my standard.
OK, let's go down the rabbit hole. Different bronze alloys are used for marine applications. These include MTEK 230 / C95500 and MTEK 230-N / C95800. Which may account for the different color shades.
And that is far more than I need to know. OCD can be fun! LOL
I second the Rustoleum idea. I've recently had good luck with their "Sunlit Brass" matte metallic spray paint on 3DP parts. It dries more like a yellow bronze than brass, IMHO, very close to the color in your picture of an example shaft strut. The matte finish doesn't amplify surface imperfections the as much as the gloss metallic colors did when I compared them on test parts.
Ill add that color to the list. Thanks!
