G'day MikeThanks Knut and Dave.
Hi Greg, thanks for the compliment. I took the easy way on the ledges. Maybe Mike41 could show the mortises for thinner ledge on the Ontario build. He was detailing that build more. I'm looking forward to doing that one also.
Thanks Zoly.Nice sharp work!
Nice job. Hope mine turns out half as good. Looks great.Here's a few progress pics. I turned a couple posts supporting the lower deck beams. Worked on the hatches, frame is made of bloodwood grating is boxwood. I used the method Mike41 showed and it worked out well. Waterways are installed they are made of boxwood. Spirketting is bloodwood. I don't know if I will put treenails in spirketting or not. Made cistern with brass wire to simulate nails. I'm not sure if I like how it turned out may paint it. To make the wheel covers I just shaped scrape wood leaving wheel pieces undersized to allow for planks.
Next is to do the deck planking in Holly. I will probably use tooth picks for deck treenails.View attachment 86743View attachment 86744View attachment 86745View attachment 86746View attachment 86747
Thanks! Your doing a fine job on your build and it will turn out very nice because YOU DID IT! Keep at it.Nice job. Hope mine turns out half as good. Looks great.
