How did you get the glue to release without bending the brass strips? I understand that you glued the hardwood strips perpendicular to the brass strips, locating those between the 3/16" o.c. hole spacing, right? I do have some Buginga from Africa that is in thin widths that I can cut and may try it in the manner that you describe. Clamping the "mat" down will still require getting it parallel to the inverted T grooves in my XY table on the drill press. I have receive several recommendations/suggestions from other members so I have a spectrum to work from. Thanks for your reply. Rich
