I already have more than you can probably imagine from reading through the build logs, but I guess I'll wait until I have it in my hands and then maybe some will answer themselves.Welcome aboard! Best of luck and feel free to ask questions!![]()
Thanks. The waiting is always the hard part.Hi Rodney.
Nice to see you have started your build-log. Hope your BN will arrive soon. That is always a great moment, you can see, feel and smell all the parts.
In the next up-date of the BN-list, I will ad the hyperlink to your log (the 22nd).
I hope thay say: Aha, another BN, let it pass quickly!
Thanks for the tip.Only three days to wait, and maybe you will have a fun busy weekend ahead of you.
I am sure you have a spot cleaned out in your shop just waiting for the sawdust to collect from the cleaning.
If you don't have a set already, suggest you get a set of picks to help clear out the CNC slots. It takes some time for that alone.
Makes sense. ThanksHere is what I was talking about, cleaning the grooves.
You can go to most any tool store and get cheap set of "dental picks" or what ever they call them.
They come in handy for other parts of build as well.
Photo copied from another build log, not mine.
Well, sandpaper and files I have plenty of. Maybe a lifetime supply of sandpaper. I used to do a good bit of woodworking and bought it in bulk. Can't say my files are "great" just run of the mill. Any suggestions there?Hi Rodney. It is great to hear that she is so close now. On Bluenose, you will not need any picks to clean out CNC debris, because the kit is laser-cut not CNC.You will, however, need plenty of sandpaper and a great set of files to remove the char and for beveling the frames.
Oeps Heinrich. The deck beams are! But I did not have to clean the grooves. Just cut them loose.Hi Rodney. It is great to hear that she is so close now. On Bluenose, you will not need any picks to clean out CNC debris, because the kit is laser-cut not CNC.You will, however, need plenty of sandpaper and a great set of files to remove the char and for beveling the frames.
I've been following your log since I'm not that far behind you, but already I can see you are making faster progress than I likely will.You are #47, I'm #46 .... I hope we may meet somewhere in the seas sometime ...
