- Jul 27, 2021
Thanks for the likes, any comments and/or questions are appreciated
The shell room is done. A tricky part. In this small scale every angle and every 10th millimeter is important to have the whole ensemble look right. I think it's ok, not perfect but ok.
I did not used the kits upper & lower support beams as they should made of two parts which I did not like and I needed them a small bit higher.
I am adjusting the parts and the joints from the bottom to top so at the end it might be that the hull is a bit flatter than intended.
Cheers
Dirk
Cheers
Dirk
