Brig Le FAVORI 1806 M1:55
Dear Uwek, the result of the grinding is not yet very presentable. Beauty will appear only after coating with oil. I slightly moistened the hull to show the pins. It looks like this.
Very good result - Bravo
On these photos we can see, that you also slightly chamfered the edges of each plank, or?
So the individual plank is a little bit more accentuated - looking very good
It is obvious, Sanya, you have your acceptance level high, and you are always with the expectations you set, even if it required a more than few tries to do it! Looks awesome.
Very good endresult - you have now a perfect bow - completely symetrical left and right -> BRAVO
Very good results - How did you make the decor line (with the rings) around the stern?
