- Jun 17, 2021
very nice craftsmanship and outcome.
Looking good. Nice workSkylights on deck. It's very easy to assemble, just like LEGO:
View attachment 423774View attachment 423776
I just painted the deck with black paint under the hatches:
View attachment 423777View attachment 423778
A rescue boat is placed on top of the hatches.The set includes a boat made of metal. I don't really like it, but unfortunately I don't have enough experience to make it out of wood. So I just painted and assembled what I had:
View attachment 423781View attachment 423782
Hallo @almoiseyHello. This is my first attempt in wood modeling, therefore, I don’t know much, I’m trying to repeat how it was done on Youtube. frame glued with glue Moment-wood:
Looks like you long and through work on the hull paid off. Nice job! With a little luck I should be able to begin sanding my 2nd planking within the next few days.Finally i have finished planking ( with Bison clue ). It turned out to be more difficult than I thought. In the process I ruined approximately 5-8 planks (fortunately there were a spare).In the end I sanded and polished the hull.
View attachment 393358View attachment 393359View attachment 393361
I'm not sure if there are enough slats for the inside parts of bulwarks. I hope that the 0.6x5mm sapelli slats from www.occre.com will fit.
Thanks for the pic… After reading your build log, I’mi going to add the 4th set of stairs plus a railing similar to the other ones. Great build.it seems to me that there should be a ladder here too:
Otherwise the upper deck will not be accessible.
That is a beautiful ship! Great workI see a lot of people here building Buccaneers. I started making masts. Unfortunately, I still can’t figure out how to ensure their correct position relative to the deckView attachment 447085View attachment 447086View attachment 447087
I discovered a problem when installing the foremast-I don't know if it's a design problem or mine, but the fence is preventing the mast from being installed:
I had to trim the railing a bit.This is the result of about a month of working with masts:
Now I'm wondering what the next one will be.Please, can someone tell me which manufacturer is better to choose - Amati, Occre or Artesnia Latina?
Generally speaking a bollard is located on a dock . Aboard I would call them bittsNext will be deadeyes and bollards (if I understand the nautical terms correctly):
View attachment 441196View attachment 441197View attachment 441199
I waxed the threads on the deadeyes and painted the bollards.
and I'm trying to improve the model a little according to this book.
Those are cavils.Next will be deadeyes and bollards (if I understand the nautical terms correctly):
