Maybe you are suprized by reading this topic. Building 17th century ships from recycled plastic??? Who is so crazy of doing this, actually it is Edwin ter Velde and I met him last week at his shipyard in Hoorn.
Edwin is an entrepreneur and a free spirit who has been travelling with his wife in his own build solar powered expedition mobil from recycled plastic to the geograpical South Pole.
And now Edwin has a new project with his non profit organization Clean 2 Anywhere.
Edwin want to build a fluit schip from recycled plastic (HDPE) and sail the world with it. But before this is possible a lot of engineering and also exprience in building is needed.
The engineering part is that his recycled plastic needs to be comparable with the nature of wood, this as he want to build ships originally build from wood.
This problem seems to be overcome by using fibers also made from recycled plastic in his extruded recycled plastic planks and beams.
To start the first ships build were 17th century work boats. These were made to test materials and building methodes. Except for the mast everything is build from recycled plastic. The ships are conventionally build according 17th century shell first methodes.
The HDPE is supplied in large sheets used for planks or stacked for creating thicker knees etc.
Large beams are from extruded beams.
See below some knees welded together from sheets.
Behind it a new work boat in progress.
The whole process of building the sloops and work boats is already flawless and before starting with something so big as a fluit first an intermediate project was started to build a 17th century speeljacht. A speeljacht was the ultimate 17th century richman's toy.
Ab Hoving helped Edwin to start with the build of the speeljacht. Again the speeljacht is fully build from recycled plastic and according the shell first methode.
In the meantime she is already a full grown ship looking out to her launch end of this summer.
You won't believe it but everything here is recycled plastic. And not wooden beam resulting in a nearly maintenance free ship.
The planks are welded to each other and Additionally nailed. All liggers, zitters and oplangen are bolted to the planks.
The upper transome "hakkebord" is a mock up for the final plastic version.
The hakkebord is being carved and coloured again with recycled plastic which is welded to the surface.
The next project is a fluitschip, based on the ghost ship. This was my reason to visit Edwin, as I am currently working on a model of the Ghost ship. He will be doing the same only in full scale in recycled plastic.
A remarkable project in which Edwin helps young people to learn a proffesion and to devellop their skills for the future.
Secondly the project devellops new materials based on recycled plastic. One spin off of that is that they already build tiny houses from recycled materials.
See below the wesite and the youtube channel.
Home - Clean2Anywhere
Wij bouwen schepen uit afvalplastic. Een knotsgek experiment in onze zoektocht naar een circulaire samenleving. Doe je mee?
www.clean2a.nl
