I know the feeling Peter. But then, I probably would not have known how to work properly with a lathe in any case ...Sometimes the guns within kits are very good and you don't need to make any. The method @Jimsky shown in his mini tutorial are absolute beautiful, but I don't have a lathe nor permission to place one on the dining table... just checked....
You underestimate yourself.I know the feeling Peter. But then, I probably would not have known how to work properly with a lathe in any case ...
That may be a better way of putting it, realizing I just don't have the x factor (tools and skills) to work at such a high level so look for an alternative.Richie I do not think that it is a question of being lazy per se. I simply know that I cannot make scratch gun carriages in this scale that will look as good as those supplied by a good kit or as an aftermarket option.
...my teacher always told me: If you want to make it happen - you will look for ways to accomplish it, and not for excuses. All you need is to try...I know the feeling Peter. But then, I probably would not have known how to work properly with a lathe in any case ...
Exquisite detail Pete. Especially the canon barrel elevators. I know your carving skills comes in handy on those tiny pieces.Hi guys,
I'll continue with the gun carriages. This time I fabricated all wheels. I use two different diameters on the wheels. The front wheels are bigger that the ones on the rear axel. I have only one diameter of walnut and so I fabricate the smaller wheels by hand with a knife, file and some elbow grease.
Wheels done, time to move on to the fabrication of all the axles. I made them out of toothpicks.
All the carriages are rolling now but I need to make all the parts that support and aim the guns.
Well, still not finished, to be continued...
regards,
Pete
I agree wholeheartedly with you - however my situation is a bit different. Due to my work permit (which will expire in 18 months' time and which I cannot renew because of my age) I may have to leave China. I am already in a predicament as to what to do with my models - let alone expensive power tools....my teacher always told me: If you want to make it happen - you will look for ways to accomplish it, and not for excuses. All you need is to try...
Hi Ptèr
Bernard FROLICH
modelisme.arsenal.free.fr
Image enlarged from the above website. Even with the French, the "thick cable" did not always go through the carriage.
Photo: Wolfram zu Mondfeld, Schiffsgeschütze 1350 bis 1870, page 78.
Spanish gun carriage after 1780 with cast iron wheels, before that with wooden wheels.
Best regards
Thomas
Hello Pter- Zoly from drydock models has really good blocks. Check his website. Cheers GrantAs work on Cazador continues, I'm looking for alternatives blocks for her. The kit contains 4mm single blocks and 4mm double blocks. Does anyone has a good source for alternative blocks? For this model I would like "boxwood" versions because I can use dye to stain it into the color of the rest of the model. Your help is being appreciated!As work on Cazador continues, I'm looking for alternatives blocks for her. The kit contains 4mm single blocks and 4mm double blocks. Does anyone has a good source for alternative blocks? For this model I would like "boxwood" versions because I can use dye to stain it into the color of the rest of the model. Your help is being appreciated!
Wow- just incredible modeling!Hi guys,
Some progress on the yard I made some improvements at the focsle construction that holds the fore-mast. To do so, I had to put my saw into the current construction. A bit nerve breaking kind of work.....The part I inserted is a slightly different color. Both walnut, so in time the color difference will be less visible.
The mast is on a certain angle and the fit is just what I was looking for.
From fore to aft. Some scratch build parts made and placed on deck. And yes, it's not being placed in the center of the quarterdeck due to the place of the mizzenmast.
The supportive "arch" I made out of a single piece of solid walnut was a difficult job. The amount of angles this thing has is ridiculous.
It's an add on I see on other Xebecs and I kind of liked it. It supports the spanker boom.
Regards,
Pete
Thanks Grant, not as great as your Victory!Wow- just incredible modeling!
