If you are talking about CA glue, is there a reason you are not using acetone?
I also found the following with a quick search.
To remove super glue from wood, use acetone (found in most nail polish removers) to soften the glue, then gently scrape it off with a plastic scraper or dull knife; be sure to test the acetone on an inconspicuous area of the wood first as it can damage the finish on some types of wood.
Key points:
- Acetone is the best option: Acetone is the most effective solvent for breaking down super glue.
- Apply with a cotton ball: Soak a cotton ball in acetone and dab it onto the glue.
- Scrape gently: After the glue softens, use a plastic scraper or a dull knife to carefully remove the glue.
- Test on an inconspicuous area: Before applying acetone to a large area, test it on a small, hidden part of the wood to ensure it doesn't damage the finish.
Alternative methods if acetone is not suitable:
- White vinegar:
Apply white vinegar with a cloth and let it sit for a few minutes before gently scraping.
- Vegetable oil:
For delicate woods, try applying a small amount of vegetable oil to the glue and then scraping it off.
- Fine-grit sandpaper:
If some glue residue remains after using a solvent, lightly sand the area with fine-grit sandpaper.
