Hi everyone. I’m starting construction on ZHL’s Black Pearl. Not a lot of difficulties because the notice is very incomplete because I only speak French. The construction instructions do not respect the normal phases for the assembly of a kit. Moreover, the wood varieties used are not all of very good quality. Lots of breakage, lots of adjustments to redo. It is very complicated.View attachment 248539View attachment 248540
Adjustments are not accurate but almost normal
View attachment 248541View attachment 248542View attachment 248543
For the first bilge bottom bridge I decided to redo the wooden slats even if they will be painted black, the effect is more realistic
View attachment 248544View attachment 248545View attachment 248546
At this level of construction the problems start because it is difficult to adjust the cored couples which are too wide and in a wood of poor quality. There’s gonna be a lot of damage
View attachment 248547View attachment 248548
The arrangement of the bilge bottom is easy and fun.
View attachment 248549View attachment 248550
New activity for me: Lighting a model. The LEDs in the kit are practically unusable for a beginner. I was forced to buy other models of LED already cabled
Construction of photo-cut lanterns adjusted to the new LEDs without too much difficulty. Soldering with tin to maintain solidity
View attachment 248552View attachment 248553
The passage of the cables is not explained on the instructions and nothing is provided on the parts. So we have to improvise and find the best solution, which is complicated
LED cables are too short. I lengthened them with wire and soldered to tin covered with a heat shrink sleeve for safety
View attachment 248555View attachment 248556View attachment 248558
Installation of the second bridge very complicated to adjust because the torques have moved and must be modified
Satin black acrylic paint with an airbrush
The cable connections are made with very strong and discreet mini Wago connectors
Second deck lighting with yellow LEDs and white LEDs
To follow if you please. I will carry out the laying of the planks and build the rear castle. Please do not hesitate to make your remarks, which I will be pleased to do, and to ask your questions, which I will answer quickly. A thousand excuses for my English automatically translated by my PC software
