Usually the problem is that the rigging lines are too stiff. They won't hang in natural catenary curves.
There's ONE in EVERY crowd..."If you experience a stiffness lasting four hours or more, contact your doctor."![]()
Be CAREFUL or else. . .You can stiffen rigging line and conform it to fixed shapes such as catenaries and coils, using thinned clear shellac. The line can be softened and reshaped as desired by applying alcohol, which is the solvent used in shellac. Shellac is also excellent for cementing knots in rigging line and as a general-purpose primer.
Although long a standard practice, the current thinking of professional curators and conservationists is that the application of beeswax to model rigging should be avoided due to its potential archival limitations (acidity) and its potential to attract and hold dust.
Removal of stray fibers ("fuzz") is best accomplished by "flaming" (passing quickly through a flame) the scale cordage prior to use. Some commercially available thread is sold already "flamed." "Fuzz" is, or should be, negligible in synthetic threads. Modernly, leading museum technical staff are reportedly specifying Gutterman Mara polyester thread for ship model rigging. (See: https://www.wawak.com/thread/thread...-wrapped-poly-core-thread-tex-25/#sku=gtdx800) This is due to the near impossibility of sourcing suitable linen thread, the formerly preferred archival material, following its being supplanted by polyester threads.
(Don't I wish........)"If you experience a stiffness lasting four hours or more, contact your doctor."![]()
Another idea - use white glue (Elmers, PVA) to stiffen cordage. Regardless of the method you choose, cut a couple of scrap lengths and try it out before committing to your model.....Where can I purchase a “stiffer” cord for my Endurance model? I am using wax however I noticed in the tutorial videos that the craftsman is using a somewhat more firm thread. Thanks
Ah. Bookbinders use linen thread a lot. You can get some at Talas, NY, NY.This is due to the near impossibility of sourcing suitable linen thread, the formerly preferred archival material, following its being supplanted by polyester threads.
Phil, if you're like me, the stiffness you feel is in your back and neck and lasts a LOT longer than 4 hours.(Don't I wish........)
