- Jan 30, 2025
Can anyone tell me if there is a difference between paint bought in a craft shop to those supplied the model manufactuer. I am having trouble with patches in the paint work
If you're experiencing patchiness, the craft paint may be the culprit. You might want to experiment with:Can anyone tell me if there is a difference between paint bought in a craft shop to those supplied the model manufactuer. I am having trouble with patches in the paint work
You've got questions, we've got answersCheers lads looks like a trip to the model shop
Exactly what Smithy said. In addition, you may get differences in color if you are painting on wood and there is a spot that has glue on it. The paint will somewhat penetrate the wood but will only lay on top of the glue. Or different kinds of wood if you have some parts that are balsa and others that are plywood or parts that are wood and parts that are plastic or metal.
An undercoat of primer will help with these situations.
That is where a seal coat of shellac helps. It will stick to most anything (sometimes pre-wiping with alcohol or acetone helps with oily wood), and you can cover shellac with most any type of primer/topcoat.Exactly that and some wood types of my (unfortunate) acquaintance are oily and will resist water based paint to the death.
