Happy Holidays to you and your family, Hammer80! Can we know what list you are looking for? Files (tools) used to build Le Coureur?it would a great help to have a list of files that is use more often .
Happy holidays to all
This is question is more to members who are building the Le Coureur. However, I would consider at least one of the files is 'barrette' 6.3″ - cut 0. This is a very coarse file (cut 0). To fair the frames notches this should work perfectly. Alternatively, you can get a cut 1.What would be a basic Corradi files set for le coureur I have some files but not good quality .
The best one are French, of course ;-))it would a great help to have a list of files that is use more often .
hammer80
a bronze brushAny ideas to stop clogging when filing aluminium? (chalk doesn't help much)
1. Get yourself a good binocular microscope. Use a scalpel to remove all the "cutter clogging" stuff with a #11 blade. The sharp tip of a #11 blade will clean a needle file to new condition; but it will not sharpen a dulled file, obviously.Thank you, but tried that and a proper hardened steel file brush, to no avail.
The fincrpscope. Remove everytthing in the file with a #1er the file the worse the problem.
