Kit review Four-oared Yawl-Scale 1:72 Master Korabel
Jimsky
Administrator
Administrator
Forum Moderator
Brooklyn, New York USA
"The yawl boat - a small four-oared boat carried over the main hatch -was missing, suggesting that at least some of the missing people could have left the Mary Celeste in it"
Russian Tsar and his family retreat in a "Yal-4" (4 oars)
Yal (from Dutch: jol to Russian: ял) – Russian and Soviet Naval transom stern lightweight rowing-boat with one removable mast and set with the sail. A small yal is sometimes called a yalik, the diminutive form of yal. Yals were used as life-boats, mooring boats, boat for kedge operations, supply boats, boat for works alongside the ship (painting, e.t.c.), boat for communication with the shore and for personnel transportation, small fishing boats since the 19th century. Yals are popular for sport and tourism purposes also.
This is rather mini-kit, however with the quality of timber and detailed assembly instruction makes it a pleasure to build. As many Russian manufacture kits, it comes with Ste-by-Step colored photo instruction and an English text explanation accompanying it. The kit doesn't provide recommendations as to who this kit is suitable for, but from my own experience, I would not recommend for the beginner, mainly due to small size.
The Kit: ART. MK0103
Make: Master Korabel (Milaniya, Russia)
Scale 1:72
Model size: 68mm length, 25mm wide, 12mm height
Unboxing
Simple plastic box 180x120x19mm
3 timber frets and brass wire pieces wrapped with plastic, and hold by folded manual and specification.
This is all parts 'a-la-carte' provided with this kit: 2 frets with laser cat Pearwood and 1 plywood containing bulkheads (formers) as well as building the jig.
Close view of each.
The instruction and Text"
Conclusion: Personally, I have enjoyed assembling this mini-kit, as it spotted very nice details. Hence I really pleased with the end results. The instruction is very intuitive and the Pearwood timber is high grade. Anyone who builds in the 1:72 scale can add it as a ship's boat. It made a really nice model of itself. The only drawback - it is really small. I made photos with a pencil so you can compare the size. But...who said it will be easy? I did not! ;)
amazing amount of detail for a wee boat. I see there's a 95mm one by the same company - better for my failing eyesight. I'm tempted
Managed to order 2 of the 1:72 versions
AND 2 of each of the 6 and 10 oared versions, based on this review, thanks.
EDIT
Just realised this is the Master Korabel kit.
My orders above are for the FALCONET kits in Pear wood.
This is the first time I have seen this thread and must say the kit looks superior to most. What stands out for me are the following:
Frames to are not too large in siding and thickness
Floor boards that have a space between for water to drain below the rower's feet
There is a keelson
Properly placed tholes for single banked rowing
Well shaped mast step
Spiled strakes of planking
EDIT
It is not easy to acquire those kits now, unless they are stock items for a long time. How did you get them, where?
This is the first time I have seen this thread and must say the kit looks superior to most. What stands are the following:
There is a keelson
Yes, Allan, it is a nice little kit, a model, if you want. All parts are precision alignment and fun to assemble. At the end, it makes a very nice ship's boat.
I built one of these boats a while ago :)
Dirk
