Friech Boeir Yacht "SPERWER" by Kortes -1:30 scale
Uwek
Admin
Administrative
Blandford Group Build
Vienna, Austria
Very good work on the sails and the sail-rigging with small blocks etc. - amazing good appearance !
Did you buy these small wooden "balls" shown in the first photo of your last post? or did you made them by yourself - would be interesting!
Kortes
Well-Known Member
Kuznetsovsk, Ukraine
I have made the parrel - trusses by myself.
If anyone would find it interesting.
During the working process I have tried several modes of making parrel trucks. Taking into consideration the size of the elements I found that the following mode was the best. I have grinded out a template, in my case D = 2,3 and 2,1 mm , I cut it in required sizes. Then I have drilled the holes (I haven't spent much time on the hands free tool, made it out of the things I had on hand, the mode is the same as when I drilled the holes in dead-eyes).
95292
95296
95297
95295
Norway
Well-Known Member
Good technique Kortes, the simplest is often the best, the technique is now added in bookmarks, thanks.
