Gaeta Falcata (Gajeta Falkusa) by jack.aubrey - Marisstella - 1:20 Scale [COMPLETED BUILD]
Friday, July 28, 2017
These days I've done a lot of work on this model, but unfortunately I don't have adequate pictures to show. So I just show these three images where you can see the original support provided with the kit.
Anyway I have a somewhat different kind of presentation in my mind . . I will explain it as soon as possible. So I'll meet you soon. Regards, Jack.
y4mRBw8M1dK75EtE-OUYeIz9bk4Qwne71ISBHolU
y4m-nQuDSajn4Lgff6TFkg7o0FS-nEV_pVQ33aSF
y4m0-MdH2X9oZIpErjRvcOyk5GzA5iv43P9wkKyU
Saturday 29 July 2017
I started some tasks for sailing equipment.
Let's begin with the mast, wedged in the keelson and embedded in a half-rounded niche of a seat. Here, of course, it's just positioned. Then we have the boom that will house the jib.
y4m2awSfB__Y_3rZ-bOxUcGAzwJXgP1LYcOtnavP
y4mMHART8FpjXGV6FbB8tgjzXFyXZLqaPIasR0Gr
y4m-6v9oKzBMtpIV_58OfShFmr5GrBvBqboBeNCo
Here, instead, the antenna for the triangular sail. This boat features two types of triangular sail, one high and one lower. Because of the height of the display case, I chose the sailing with the lowest antenna. It was a tough choice but I think it's necessary.
y4m9lwsnoz_O3zQSXn_myXpjWZFxhVRgiFNj9QU3
And now let's come to the showcase basement of our model. Although the support provided with the kit is nice and original, I had in mind a kind of presentation like the image 08 20160924_110111.jpg, in my opinion very realistic. Then the base of the case is ready to contain this kind of bed made of stones/sand.
With this in mind, I asked my daughter, Silvia, who went on holiday to Elba Island to "steal" (I remember that it is not allowed by law) sand and gravel from a couple of Elba beaches . . Now the stolen material has to come in my hands.
For now I release some images of the showcase base . .
y4mtc1L38OBqKgIDYNZRrb0aTNtSvqMEWhXLjipY
y4mVmK5VR__yiMafjVDEc3tQw0mLJDEcmU1x1vzs
y4mNRRLWgWd4WFONJ-TnMNntnkVHMohHN--mw3If
y4m5Uz_sHmoupzSWeCYTBVETZEdWfk6-LBVy_gTD
Regards, Jack.
Thursday, August 3rd, 2017
I'm working on many small details with little to show individually: rudder hinges, mast support, crates for fishes, painting of the "falke" sides, etc.
The only things worthy to be seen at the moment are the outside paintwork, now black and the crates for the fish, to which I am still working.
This is the prototype: measurements mm 30 x 20 x 15.
y4m8L82avdXAaa-HHq5pIAqfh-9zeoP9_L418UZV
Below the hull with the "falke" painted in black . .
y4m4tB2oaVeu60S6QcglFtsWsZGbDQYnxZZjFxkN
y4mMwaAzTpbohrW7YiRb1FRUJbUimjZfnSgEJYrU
y4mJ122rGAWZLuMvwh8Tfts12Aaf21rNYJis_fDj
Considerations about the sails of the Gajeta . .
The Gaeta (Gajeta) Falcata (Falkusa) seems to be a very versatile boat. We learned how this boat can be used with two hull configurations, one with high sides, optimized for sailing and one with lower sides, most suitable for fishing with nets.
But its versatility also manifests itself in its sails. Let's think about them.
The following image shows three Gaeta configurations, from left to right:
a- sails with "high" main sail; the main sail is very high, probably suitable with light winds;
b- sails with "low" main sail; the sail is not triangular and mounts a beam even belo
c- no masts/beams and sails; configured with low sides suitable for fishing; the rudder has been removed.
y4mXs78TVnBiexnWXUr0bfQolawWN5f6sVZMYOAv
The following image shows a Gaeta in configuration type (a); for my taste this is the most beautiful and majestic. And here we can also look at another variant: the double jib, interesting . .
y4m8tB-HobmzxIk9P5_oGLMcGfsom6XpCfKChqZB
Here below the boat is in the configuration type (b): lower sail, jib fastened half way on the bow beam, although we have seen that it can be fastened on the top of the bow beam. The main sail may seem triangular but seems to be rolled on the lower beam and for this reason doesn't look like in the image 01 . .
y4mItzZjsFegFDT_5PZqjcCXPyoaLRCi3b09UF1h
Here are other images with an apparently "low" sail but with a real triangular shape. Images 04, 05, 06 and 07. Let's say this is a new type . . we'll define Type (d); obviously this is another sails configuration !!
y4maEkqG55LogEGlUwFhEWy1Kq8kj7JrhRUKSfLP
y4mKywSi0RuJ5GkeAGi8_emhhdkc0FPDrGNp7-yV
y4mMzschrT-pa1GV4ej2QYGoVI2VPTll9IRboybc
y4mVJV-UOAPY7FCu5yUZ7gjqxwD7RNApSxSvM5_D
For now I have not found more configs, but it's not said that they do not exist.
For reasons related to the size (height) of the plexiglass cover for the showcase, although my preference goes to the sails type (a), I decided to adopt the configuration type (d).
The kit features pre-sewn, well-made sails. Unfortunately they are for the configuration type (a) and to transform them into sails type (d) there is some work to do: the main sail needs to be ex novo rebuilt. But here some problems arise: I do not have the same fabric and so I should also redo the jib; but I'm also a dud with the sewing machine, so the result could be bad if not worse.
So ? Simple, I will install the original jib and the main sail tied to its beam as in the images below . . With this solution I just need to cut the big sail to the right extent and the game is done; once rolled on the beam its wrong shape will no longer be visible . . Hyper-pragmatic solution . .
See you next time, Jack.
08 Alla fonda 01
y4mS1LBagsQqYbpWMgRSCFoWW9OUQQsNvl8XqLug
09 Alla fonda 02
y4mnmbXpch3tQhhKJZCFc7ac4fQN6FtjnX7hpWSA
10 Alla fonda 03
y4mAdRQp9cyjif94fByo6Ys-w7BwKrHNLZ2LgwnI
Tuesday 15 August 2017
I almost finished the buckets !! Now it just miss the painting of the brass handles with "gun metal" and they're over.
Today my wife did a very good job with sails that are almost finished . . I need now only to hold the wire knots with a drop of glue.
Two photos of the buckets where you can see also a small detail of a sail.
y4mDGWthgo6iy5P78ixdbPaDYyA49tsNqQUeJuU_
y4mQUfjQhownuWV9SgtZqK7uo6P5tLuC-S2wkpT6
Goodbye, Jack.
Thursday 17 August 2017
Having finally finished all the various detail components, yesterday and today I was able to begin working on the masts and its rigging. The pictures below show the work done so far . . far from being near completion. However, the goal is behind the corner, maximum another week, then it will be time to setup the beach of Comiso on the displaycase . .
See you soon, Jack.
y4mNDVGQWOMWishgWG6bJxczGZn09fmXt_2CbruA
y4m8eNUcVJtdSzGI8cIu7SfqdpA4BTHFqKQXt5Tr
y4m-eKy38gIsxwnQvoVEZjEb5CeOC86Vi--HchBR
y4mi3ADhBErVSzNeV7PMXUZIlgC67yf0jTBKB3SN
y4muJwK0jB4SK4K0sW5ppiEw0X5FvLHIU0gyk-02
y4m5oqTGTa9rV_yniT_IAVOvMnwRxtibgoWdPDdM
Tuesday 22 August 2017
At this point the model is practically finished . .
Now I have to prepare and apply the rope curls to add realism to the edges of the running rigging and then there is nothing left to do.
In the next days I'll focus on the setup of the displaycase basement, according to the idea I described some time ago (rocky beach, various accessories left on the beach, etc.)
Soon, Jack.
y4mbet_oLTzhWmub0IlU0OfKmW_1lmmCE3MWshPL
y4mjKv5wA6QK9GY0ZN-u1xRYDeC6Qn-pfCoElI5G
y4mmPm2gYi6sc564FX8aEa9i3Kk6t4k4wNGsScGC
y4mbam0liievZy6c9jp5Gaa8EMUFpAOzd4K38sII
y4muYk8o6vbor7puvsffR7edsR8nUNj3GqPwlGLw
Wednesday, August 23, 2017
I've finished with the last rigging details, like the rope curls at the ending tips of the running rigging.
With this last activity, the model by itself is truly over . .
Now only the display case is missing in order to close the shipyard.
y4mNstSywkWVA9-Ovs0W49Yq8YMoZpUKYd44NGtx
y4m5LO9m-8GRgeB4ReEOIaoewQ-KOQGJMncgiVmb
y4m-OPoaNwOM4RHukI2UcWAyD_lWGpgFB3z9g3CF
y4mG26sDvUBRSjcVLamZ-s-kTZcbbi9mflS-CiZK
y4mqNpRlJIdsfu-d194ZAuFLCUiC7VH384OTN43N
y4mDqlBqChcRaZ6AF_8DLKPyhNoaUt7oI6p8eNiH
y4mpWGF6yPZQEtTYoysijS6WDQPuC-x0l2Who09l
Saturday, August 26, 2017
I put inside oars and a couple of accessories, just to understand that much of the material I prepared will be better if positioned on the (future) beach . .
The next images will show the model inside its display case . . probably by the end of next week, bye, Jack.
y4mSGLJdyA5p1SXA3jR50nWJ6udcNUVnH_SGf0Tc
y4mZ47PoAQl8WjJQ1NKD2LiyXl4wwVcD1ty0Qwrj
y4mUvU4nBZ-jB7-vws276EEAvKAsb49kwjdc9UE1
y4monV7eDaYAbXHBI4s0LEWHgNerNl423HKUQrLL
y4m2gGSgVIspvfR1i3DTUzdQRCbur0e5nt2bj1Cg
Monday 28 August 2017
I'm working on the display case base . . In particular I'm preparing the so-called "beach". To hold the small pebbles of the Elba Island beach called "200 steps" I used vinyl glue, laid abundantly on the wood basement.
The work is not yet finished because I think it is better to make another layer of this sandblast and then apply the larger pebbles individually. . I now have two new sizes . .
Interesting experience. We will see how the situation evolves.
See you soon, Jack.
y4m3PNP6JLGO1WkkAn3kzaI3-gmWHOwkoVOAQyBj
y4m7RljYIT5tKuXDIUkquawoxFFLtAChCMkAwQ1j
y4mmZ1zeXDlA5cfnBYWt1_aNwSwZxemwGMO-X7Uf
y4m6NT3gBthyf2f9Ecv48w5hF5D2eG4J8I43nTcE
Wednesday, August 30, 2017 - Finished
These four pictures show the finished project, under its plexiglass cover . .
Due to reflexions and low light the photos are rather poor, but they still make the idea of how the whole complex appears.
Now the adventure is really over.
A further batch of more detailed images, as my customary, will follow soon.
A warm greeting, Jack.Aubrey.
y4m-B-_nNkx3raTMy5fm6uxjFQHCPLbHwOwSfvEf
y4m6HcF-EEW4jhhJmO6F_Rs8HWFE1bzWxh_DsjOt
y4mO0IFrUJyLwois70cI0lKKqYCKJUmt0v7rfU8E
y4mL10CVzIBjiXwkG-8nNYDNvsyl1cFZiLqGxxFs
Some interesting questions about the diorama . .
As a northern European I am not used to these kind of "beaches"
, but the result is absolutely fabulous!!
Regarding the pebbles beach, I can imagine that in the Netherlands may be quite uncommon but here in the Mediterranean Sea we have a lot of them . . As old good swimmer I prefer them vs sandbeaches because in general the water is always clean and deeper and you may appreciate 100% snorkeling and swimming.
Anyway, thank you for the comment. Jack.
I can look through these pics over and over again, just amazing!
(Although I must admit, boat layed on the beach with set sail? Would be strange if not dangerous in case of wind blow... ?
Regarding your question, I recognize you are right . . It's not a good idea to leave a boat on a windy beach with the sails on !!
I discussed the matter with friends time ago and cannot disagree.
But I decided to proceed this way anyway because there are some right things in it: imagine a temporary situation when you let the sail dry while working on discharging your boat.
With a bit of imagination.
:rolleyes:
Thank you again for the comment. Jack.
Continues, as promised, the publishing of the last images.
And now the topic is over, Bye Bye to all of your. Jack.
y4mJ4ALgVhzWEmdVW7kFVKtfroJYiDTvSM2qsBUV
y4mhT5Eah511WZXJLTPpcgn_gyi7TvkVyTHKFuiI
y4mskGgwmeUOm2uMIq-FpJyv_IjKXeIEb6hLmcyU
y4mEAz-cNsR2WAPcXKrvm_yUIc_MUs-OVTh48XED
y4mq4kFuIRyxAWo2TonXITYhlOZ1fiw0NqgmxD85
y4m1cHiVNQM2vjD3eRRHMPgYqtb4gHaqgNJ_sRu4
y4mFS_V_2SKPU0cIbiWAioHtIwKYiir9X-wUkJFT
y4m20AN_EmHetk1wajAtklVwnpB1r46N1MqbdJnf
y4mGo0XJprf8K3nexaWpY1nFVzDYcOi5iMPuxpgW
y4mkDiHWywC7GtYO1ev2XFe5oqz2AeUej3ilJoSN
y4mCq8DGyNNGDDbi_LAlHV25hWkyWoZ7uHshnDVQ
