General about sails
calahonda, mijas costa, malaga- spain
I do not know of your interest in this matter, but I will add a file with quite some images from a finished Model standing in Copenhagen. If of interest I have more. (there is about 30) covering all mast
I do have a lot of info. how to make the sails correctly and the tools needed- if not of interest delete them.
Why deleting? This is very interesting subject. Please provide as much information as you have on these sails modelling.
What is the name of this ship?
HERE IS THE NEXT BATCH. The needle is for fasting the LEACH ROPE. It must stay directly on the Edge on edge of each sail. hence using a needle to go through the middle leach rope. it can help to use some paper clips on the edge. As it cannot de fastened mechanically, it us hard el capi manual work-
RELINGE igual as LEACH ROPE
Sorry to everybody that the text I made has apparently disappeared. RELINGE in Spanish is UK known as LEACH Rope. The Leach Rope you do not see on many sails, as it is a very difficult process to add RIGHT to the Edge of the sail, as it cannot be done by mechanical means. It has to be done with a Needle in a Cross Stitching over and back again (through the middle of the Rope)
om the images of the sails the grey part = RELINGE is the Leach Rope. Doing the process it can help a lot with the use of Paper Clips..
Hope that this can clear up some of the images--sorry again
el capi
Just tried to make a research based on the photos of the model and the visible data on the drawing
seems to be british and launched in 1813
There was only one 74 gunner launched in this year, which is the HMS Vindictive, an Armada class
But maybe @El Capi has another photo or higher resolution where some more text is readable at the drawings pinned to the wall
hi Uwe, no I do not have any drawings, only the images -about 20 in total cover Bovsprtit-for mast , main mast, mizzen mast with the gaffel/ Bom sail. I must admit I can remember from where I got it
https://www.rmg.co.uk/collections/object?vessels%5B0%5D=Vindictive%20%281813%29
I've seen very similiar ship ,but @El Capi's looks much better. That's why I asked for a name
HMS Wellesley of 1815
That would be great if you could post them
Thanks for your help. As far as I member -more than 20 years - the model is standing in Copenhagen, but I lost all the data from where it got it
Impressive model and very documented. Excellent work
Muchas gracias desde malaga
