Gluing speed tool.
Englewood,FL
#1
White glue can be dried faster with a small amount of heat from a mini iron
Used to apply covering to model planes ( monokote sealing iron). This tool can also help
Shape wood strips in hull planking as is dries the glue. Just hold the tip on the strip
For a few seconds (30 to 45) depending on the amount of glue used. Work your way
Down the strip and in less than 2 min the job is done and on to the next strip. No
pebbleworm
Active Member
#2
Better yet, it is re-activated by heat. Paint it on, let it dry and iron on your strip wood! No drying time involved.
