Great Lakes Sailing Canaller...now with photos
Ennismore, Ontario
My second post...
Not really intending a full build log, but maybe people around the Great Lakes will be interested in our project. During an archaeological dig at the old Shickluna shipyard site in St. Catharines, Ontario, along the shore of the second Welland Canal, I became interested in the three masted schooners that were built to maximize their cargo capacity through the Canal and found that there are very few models and no drawings of the period to really portray those vessels. There were thousands of wooden schooners built, hundreds at the Shickluna yard alone. So my ship modeller brother suggested I do a set of drawings and he would build the hull. I was assigned masts and as much of the running rigging on them as possible.
He has built several POB models, Halifax, Rattlesnake, etc., but never a scratch build. I had never done a ship or model ship drawing, but I could see how they were done and I can do manual mechanical drafting. So, a lot of FOAK aspects, and we would do some things a bit differently next time. Of course!
I had seen drawings of a schooner online, and figured I only had to adapt them to make bulkhead and false keel drawings, but it turned out that the museum holding the drawing had moved recently and misplaced the drawing! After checking with several possible sources, collections and museums on the Lakes and striking out, I started a process of research and drawing development based on period photos, modern day shipwreck detailed reports, almost exclusively from the US side, and one or two academic theses.
I also was provided with a partial hull drawing, i.e. a hull body plan from an unknown (at the time) source of the St. Louis, a three-n-after canaller from the late 1870's , built at the Shickluna yard. Knowing from other records that the St. Louis was 128 ft long , after a few iterations and comparing the hull lines to period photos and rare shots of ships in drydock or still on the ways waiting to launch, we settled on lines that we thought would work.
We started with 1/96 scale, but settled on 1/72. The curve of the bilge on these things is quite tight and the larger size made rounding that a bit easier. So the hull is just under 22" long.
There were several interesting features that we had to research. For example, the bowsprit and/or jib booms of the ships were raised to about 45 degrees and the stern davits and catheads were hinged and flipped inboard to help to prevent fouling the lock gates as the ship rose or fell in the locks. So it ended up taking about 2-3 months to get a set of drawings that were adequate to build from. And changes were ongoing as better or more persuasive data came available.
To test the design, I first took the false keel and bulkhead drawings and made the parts out of 1/8" white foam board and mocked it up. Made a few tweaks, figured out how to incorporate a retractable centreboard, and how, from wrecks info, it had been hinged and controlled, and we started cutting wood.
I was never quite sure about the transom and counter under the stern -- a lot of curves there that are hard to represent in 2D (I don't know Autocad and wasn't going to buy and learn it for one project). So, I learned how to make a half hull to view it before we go too far into the hull construction. Made this 1:100, just to be a bit more manageable and frankly to be within the capacity of my scroll saw when it came to cutting the sheer line on the top layer of wood, as well as the bow and stern profiles. It turned out very, very well and it was a great aid to the model builder.
Rigging design research was a whole other project in itself. You can only see so much detail on old photographs, very few of which show deck and bulwark level rigging details, and shipwrecks generally don't have helpful amounts of rigging surviving.
Here is a photo of where we are today. The model is sitting on my arrangement drawing as it happens, so you can get a glimpse of it. Not using CAD, and incorporating changes as we learned more, it is a good thing I used good quality vellum and still have my old erasing shield (for any old craftspeople in the crowd). I have all three masts made, with gaffs and booms, and the foremast and mainmast rigged as much as they can be before installation. Even figuring out what rake to give the masts took many hours. My brother has gotten this far in the hull. He is just checking where to put hatches, windlass, pawl post, etc. Note that bowsprit is articulated into the pawl or Samson post with a mortise and tenon arrangement that allowed it to pivot upwards in the canal. In the photo it is well aft of where it actually sits. This is just a snapshot. Bulwarks are going on now I think. Hull colour comes from research also. Leaden gray below and emerald green above. The deck cabin is for galley, captain, mate and cook quarters. Crew lived in the forecastle via a scuttle just aft of the windlass, keeping company with the anchor chain lockers.
I know this is a long post. I will post more if there is any interest as we go. And I see at the end of all this typing that the pdf photo is too big to post. I will work on that tomorrow. Meanwhile, here is a simplified pen and ink sketch of the ship to give you an idea...
Uwek
Administrator
Administrator
Vienna, Austria
Very interesting project you and your brother are doing.
You mentioned a photo of the model in the Text, would be great to see the model.....
Ennismore, Ontario
Yes, I am on the road and was trying to upload a photo from an email, but the image file is too big. I will try and get another attempt posted tomorrow. It's an interesting design.
zoly99sask
Administrator
Administrator
Saskatoon,Canada
you tried to upload a Pdf file not an image file,Pdf displayed differently and has an upload size limit,I converted your file and added to your post
Ennismore, Ontario
Thanks Zoltan. I see you are in Saskatoon. I am visiting my daughter and her family in Regina right now. Enjoying the warm weather. Not what I'm used to here in February! I still hope to post the photo of the model in progress later today if I get it from my brother in a different format. The pdf I posted is just a piece of sketch artwork, not a working plan obviously.
Ennismore, Ontario
Here is the photo that I was trying to post last night...
The deck hardware is just roughly placed, sitting loose. The bowsprit would be well forward of where it is sitting here. The mizzen mast will come up through the deck cabin roof, just about in line with the stove pipe. The hull is designed to maximum cargo capacity within the dimensions dictated by the size of the canal locks. By memory, locks were just over 26 ft wide and 150 ft long in the second Welland Canal. This ship's hull is 26.2 ft beam x 128 ft long between perpendiculars. Draft limited to 9 ft over the lock sills, so just forward of the mainmast is a retractable centreboard, about 25 feet long.
Ennismore, Ontario
This is where we were last fall. I wanted to do a check on the hull contours before committing to cutting out all of the bulkheads and false keel, so I made a prototype put of 1/8" foam board. The transom wasn't on yet in these photos, but this helped me to figure out how I wanted to do that. I don't know how common this approach is but it was very helpful, along with a quick half hull.
Ennismore, Ontario
Thanks. BTW, although we didn't model it on the foam board prototype, you can see where we planned the cutout for the pivoting, retractable centreboard, which is on centreline in this ship. That was tricky as it temporarily seriously weaken the false keel -- a problem that we maybe didn't fully overcome.
Ennismore, Ontario
Thanks Uwe. It was remarkably quick to make, although I have done a solid wood hull many years ago (over 30!) So some of that came back to me. I used a satin varnish and do intend to mount it on a board. I appreciate the encouragement.
Ennismore, Ontario
Here is the finished half hull model, mounted and varnished. I'm pretty happy with the result for a first off. My 30 year old experience with a solid hull Eastport Pinky helped and gave me confidence to try this. I am working on a second one, as you can see.
Ennismore, Ontario
Here is a photo of the ship partly rigged now. After my brother built the hull, I added the deck furniture and cabin that he had made or we bought, and then mounted the masts, which had been partially pre-rigged with lifts and halyards. I made cardboard triangles from the drawings to set the rake more or less to accurate angle. It is different on each mast. Then added basic fore-and-aft centreline standing rigging between masts and bowsprit and jib boom. Then back to brother for shrouds and ratlines (he lives about 2 hours away). I did not want to tackle that for the first time on this ship. Unfortunately we had a small setback as with all this back and forth the mizzen got snagged and broke. A bit of a gumption trap, and Covid19 isolation makes handoffs a bit tricky, but since I made the masts, I will fix it here. Meanwhile, he finishes shrouds and ratlines on fore and mainmast. So far we are pleased with the result and are accomplishing what we set out to do! Great
20200427_094539.jpgexperience!
Ennismore, Ontario
We didn't really have the opportunity to post a lot of photos during the build, for various reasons, not the least of which we were sending the model back and forth 150km from Toronto to my home depending on who was working on what stage, and my brother didn't take many photos until the end, when a friend of his got involved. So, here are the photos of the finished model (except in looking at it I realized that we forgot to put on the fenders that were always seen hanging over the sides -- clearance in the Welland Canal locks versus the ship beam were just a few inches). I posted these on a few FB pages dealing with the Canal, Shipwrecks (the source of a lot of design data) or Great Lakes marine history.
D3.jpgD4.jpgD7.jpgD13.jpgD15.jpgD16.jpgD18.jpgD20.jpgD21.jpgD23.jpgD24.jpgD26.jpgD33.jpgD36.jpgD37.jpgDD01.jpgDD02.jpg
Uwek
Administrator
Administrator
Vienna, Austria
Very good looking model of a very interesting subject - Many thanks for sharing the actual status.
Would be happy to see much more often some news......
Ennismore, Ontario
Thank you. Well, the Driftwood is finished now but I started one for the Lady Nelson. I will try to be more faithful with that one. I expect lots of questions for the members so I will be motivated!
